Overland News of the Week
Opinel Releases New Grilling Set
Fabricated in France, this grill set includes a stainless steel folding knife, a spatula insert, and extra-large tongs with a stonewashed finish. The No. 12B folding knife features a beechwood handle from sustainably managed French forests and is equipped with a bottle opener at the end, while the spatula is designed to be inserted into the knife handle by locking it in place. The tongs have notched tips for easy grabbing and a grill lift built into the handle.
$130 | opinel-usa.com
EGR Unveils New Tonneau Cover for Ford Models
EGR has expanded its RollTrac tonneau cover lineup to include new applications for the Ford F-150, F-250, and Ford Ranger models. Constructed from aluminum and designed to seamlessly integrate with each truck bed, RollTrac tonneaus feature a secure locking mechanism, a 700-pound weight rating, and accessory T-slots on bed rails for customization. The electric version comes with a key fob control for easy opening and closing of the cover at the push of a button.
From $2,849 | egrusa.com
Camp Eyewear Launches Limited Edition Smokey Bear Collection
Inspired by the iconic symbol of fire safety, Camp Eyewear’s Smokey Bear collection features five of the brand’s best-selling sunglasses, including the Cliff, Cove, Glacier, Topo, and Trail, all with a rustic, vintage-inspired color and design. Crafted from plant-based bioplastic, each pair features laser engraved wood accents, Smokey’s hat emblem on the temples, and “Only You” engraved on the polarized lenses. In partnership with the US Forest Service, Camp will donate a portion of every sale toward wildfire prevention.
$79 | shwoodshop.com
Overland News: Warn Industries Releases All-New Zeon XD Winches
The new XD 10-S and 12-S winches include a redesigned high-efficiency electric motor and gear train with speeds of up to 40 feet per minute. High-pressure tested IP69K waterproof construction prevents elements from entering the winch, while a UV-resistant bus bar cover prolongs its lifespan. The XD winch also boasts full-metal armor, which protects the motor and three-stage planetary gear train. Available in two capacities (10,000 and 12,000 pounds), the XD also includes the classic Spydura synthetic rope.
$1,900/Zeon XD 12-S, $1,750/Zeon XD 10-S | warn.com
Super Pacific Introduces Switchback X1 Camper
Inspired by aircraft design, Super Pacific has used aerospace fabrication methods to construct the X1, including laser-cut sheet aluminum and aircraft-grade rivets. Continuing the theme, the canopy portion of the camper (the “Fuselage”) uses composite material from the aerospace and transportation industries with powder-coated sheet metal finished with a UV-stable formula. The tent’s marine-grade material, Top Gun 9, is a polyester textile with a durable, weatherproof finish. The X1 is USA-made and sourced with standard features, including a mobile gear locker, Exped Megamat duo, no-see-um grade screened tent doors, and more.
$13,995/full-size, $13,495/mid-size | superpacificusa.com
The Fubi: Snow Peak’s Newest Multi-Room Modular Shelter
snowpeak fubi overland news
With three entry points, the Fubi shelter features an angled front, resulting in unobstructed views and the potential for ample airflow and visibility. The front door’s adjustable side panels can be arranged in several configurations to increase the awning courage area, while the transparent skylight is perfect for stargazing. An inner section comfortably fits two adults, but an additional room can be added for larger groups to create more sleeping space.
$2,290 | snowpeak.com
The Distance LT 1100 is Black Diamond’s Most Powerful Headlamp Yet
black diamond headlamp overland news
With a maximum setting of 1,100 lumens, Black Diamond’s latest headlamp is all about smooth, diffuse lighting for consistent visibility after dark or before sunrise. The pivoting three-color light has a multifaceted optical lens design and is constructed to minimize bounce and movement while running. The rechargeable 2200 mAh Li-ion battery charges via a USB-C port, while the headlamp is helmet-compatible with a submersible IP67 waterproof rating.
$120 | blackdiamondequipment.com
Overland News: Gerber Introduces the StrongArm Camp Knife
gerber camp knife overland news
Based on Gerber’s best-selling fixed blade, the StrongArm takes things to the next level with a full tang 420 high carbon steel blade and grippy, ergonomic handle. The multi-mount MOLLE compatible sheath houses a 4.10-inch corrosion-resistant blade that suits left- and right-handed users, as it is ambidextrous. The overall weight is 4.8 ounces, and the length is 8.98 inches—a nice size for anything from cutting paracord to slicing kindling.
$90 | gerbergear.com
Nestout Power Banks Combine Vintage Style With Engineered Resilience
nestout power banks overland news
Available in 10,000mAh and 15,000mAh capacities, Nestout’s power banks feature universal compatibility with smartphones, tablets, and USB devices and charge via USB-A and USB-C ports. Inspired by the shape of vintage fuel bottles, the power banks are dustproof, shock-resistant, and waterproof and can fully charge in around two hours and 45 minutes. Weighing 0.5 pounds (241 grams), the battery packs are easily transported, no matter where life takes you.
$60/15,000mAh power bank, $40/10,000mAh power bank | nestout.com
Eagle Creek Introduces New Packable Packs and More for Fall
eagle creek packable overland news
Eagle Creek’s new Packable collection includes a backpack, duffel, laundry sack, and hip pack, all constructed from 100 percent recycled materials that compress smaller than a beer can. With capacities ranging from the 38-liter duffel to the 1.75-liter hip pack, all are lightweight, feature a front zipper pocket, and are made of 70D PU-coated polyester. If these products aren’t what you’re in the market for, Eagle Creek’s Fall 2024 collection includes new packing cubes and its Explore pack series.
$59/backpack, $59/duffel, $35/hip pack, $30/laundry sack | eaglecreek.com
Introducing the Dometic CFX2 Electric Cooler
dometic fridge overland news
Available in Ocean Blue and four different capacities, the CFX2 keeps food items as cold as -7°F and can be controlled and monitored with the Dometic app via smartphone. Dometic’s latest electric cooler is designed with reinforced corners, self-folding tuckaway handles, and an integrated LED light for sundowners. Powering requires 12/24-volt DC or 100-240-volt AC sources and is compatible with Dometic’s battery and solar panel products.
$900/57L, $800/45L, $700/37L, $600/28L | dometic.com
Midland Releases Upgraded Two-Way Radio Bundle
midland radio overland news
Midland just launched the GXT3000VP4, a GMRS two-way radio bundle with increased battery life, rapid charging, water resistance, and an LED flashlight. Eight new repeater channels allow users to significantly extend their range and communicate better than ever over long distances. The GXT3000VP4 comes with a lithium-ion rechargeable battery that can rapidly charge in just over 4 hours and has 18 hours of battery life, while Selectable Bandwidth allows users to choose between narrow or wide bands to further enhance performance.
$150 | midlandusa.com
Overland News: These New Danner Sandals are Made for Life Outside
overland news danner sandals
New for Summer 2024, Danner has introduced the nylon and leather Joseph sandals. Inspired by the mountain range in Eastern Oregon, the Wallowa features quick-drying textile straps for water wading. The Joseph is named after the town of northeastern Oregon and is the go-to for day hiking with or without socks. Both sandals have a Vibram Traction Cascade outsole with texturized micro lugs for traction and cushioning that won’t wear down over time.
$140/Joseph, $130/Wallowa | danner.com
Hipcamp Partners with Sensible Weather to Offer Weather Guarantees
overland news weather guarantee
Hipcamp is now offering a Weather Guarantee powered by Sensible Weather that provides campers proactive reimbursement when it rains during a trip or experience. “Through this collaboration, Hipcampers can now plan their trips with confidence, knowing that if inclement weather impacts their plans, they’ll be reimbursed,” said Sensible Weather CEO and Founder Nick Cavanaugh. According to Hipcamp Founder and CEO Alyssa Ravasio, the most common cause of trip cancellation is due to bad weather. “We hope to inspire confidence in campers by making the decision to book their weekend getaway just a little bit easier,” she said.
Coming Soon: A New Portable Toilet from Joolca
In this week’s overland news, Joolca has designed a modular toilet that campers can use as a chemical toilet, bag toilet, or compositing variety. This non-flush toilet separates solids from liquids into an 11-liter chemical cassette, 9.4-liter eco cassette, or 4.6-liter urine container. The full toilet weighs 11 to 52 pounds, depending on which cassette you choose.
$251 | joolca.com
Gaia GPS Adds Enhanced Cell Coverage Layer
Gaia’s new cell coverage maps are based on carrier data, showing voice service, 4G, 5G, and areas with no coverage via color-coded tiles accurate to 100 square meters. The enhanced maps cover the continental US, Alaska, and Hawaii, with various indications such as voice service only to 35 Mbps minimum download. For those working remotely, dark purple tiles provide users with data regarding where they can expect to join video calls, download files, or communicate online. All cell coverage maps are available with a Gaia GPS Premium or Outside+ membership.
$8 per month/Outside+ membership, $5 per month/Gaia GPS Premium | gaiagps.com
Read more Overland News
Ashley Giordano completed a 48,800-kilometer overland journey from Canada to Argentina with her husband, Richard, in their well-loved but antiquated Toyota pickup. On the zig-zag route south, she hiked craggy peaks in the Andes, discovered diverse cultures in 15 different countries, and filled her tummy with spicy ceviche, Baja fish tacos, and Argentinian Malbec. As Senior Editor at Overland Journal, you can usually find Ashley buried in a pile of travel books, poring over maps, or writing about the unsung women of overlanding history. @desktoglory_ash
