Fridge freezers are by far one of the most welcomed additions to any overlanding kit. They absolutely change the way you eat in the back country and can raise your culinary game to the next level. True, you can certainly live without one, but once you take the plunge you’ll wonder why you didn’t break the ice leash sooner. There are several advantages, and very few disadvantages to switching from a cooler to a fridge/freezer. However, we won’t be arguing for or against either here, instead we have compiled an alphabetical list of quality fridge freezers that are sure to accommodate your beer payload and provide you with years of dutiful service. If you are interested in a head to head comparison of fridge versus coolers, you can find that in a previous article here.
Below, you will find several high end refrigerator manufacturers. Each brand was carefully chosen for this list based on quality factors such as construction, compressor manufacturer, and overall durability. Many of the examples listed below have been owned and/or tested by Expedition Portal staff at some point. However, we hold no specific allegiance to any particular brand and have chosen our personal fridge freezers based on our own specific tastes and needs. We suggest that you do the same.
Things to consider:
- Amperage draw: The higher the draw, the greater the demands on your electrical system. If power draw is too great, you will need to consider supplementing your starting battery. If voltage drops below a specified amount, the fridge will turn off to ensure that you can start your vehicle. Obviously, this can spoil your food and trip. You can avoid this issue by either choosing a fridge with a relatively low amperage draw, by adding a second battery, solar, or both. A jumper pack can also rescue a dead battery.
- Clearance: The mechanical/electrical components of the fridge freezer require airflow to function properly. This requires leaving space around the fridge to maintain this airflow *Consult your user manual for specific space requirements -you may find it helpful to review the online PDF manuals where available to determine if this is a limiting factor for your setup.
- Wiring: This goes back to number 1 above. Factory wiring is often too small to handle the current draw required by almost all fridge freezers on the market -which tend to start at 2.5 amps and increase from there. This means you will likely need to run a separate wire from your battery to the fridge in order to accommodate the increased electrical demands.
- Compressor: With the exception of a few brands and models listed below, all use the same brand and model of compressor: Danfoss, particularly, the BD35F. This means that the proprietary advantages of one fridge over another primarily comes in the form of insulation materials and thickness, compressor controls, temperature monitors, electronics, and construction materials. Many claim to use “higher quality compressors than the competition” when in reality, they likely share the same brand and model. To help with you make an informed decision, we have provided the compressor brand of each brand and model listed below.
This is by no means an exhaustive list. In fact, there are countless 12 volt fridge freezers popping up all the time. We chose to provide the following brands based on two factors: availability in the United States, and high quality. If find that we have missed any key models or brands, please drop us a note in the comment section below.
ARB
“ARB Fridge Freezers are the ideal way to keep your food and beverages chilled or frozen on your 4×4 adventures, regardless of ambient conditions. Not to be confused with less effective 12 volt ‘coolers’, the ARB unit is a true refrigerator/freezer. Own one and you’ll never again find your lunch water- logged by shifting ice, and there’ll always be a cold drink on hand during the sweltering summer months.” -ARB
Price: $849
Model: 10800351
Capacity:
-37 qt
Features:
-Integrated digital control panel
-Drain plug
-Internal LED light
-Recessed powder coat steel fixed carry handles
-Integrated battery protection system
-Removable lid; removable internal basket
-Separate dairy/fruit compartment
-Right angle power plug for additional clearance
-Operates at angles up to 30*
-Optional transit bag adds insulation and physical protection
-3 yr warranty
Weight:
-46.6 lb
External Dimensions:
-H16.9” x W15” x L27.8”
Current Draw:
-0.7 to 2.3 amp/hr @12 volts
Compressor Manufacturer:
-Danfoss BD35F
Power Source Compatibility:
-12, 24 volts DC; 120 volts AC
Construction:
-Powder coated zinc steel cabinet shell; UV stable, injection molded lid
Price: $924
Model: 10800472
Capacity:
-50 qt
Features:
-Drain plug
-Internal LED light
-3 yr warranty
Weight:
-53 lbs
-H20” x W27.76” x L14.96”
Current Draw:
-Danfoss BD35F
Construction:
Price: $1092
Model: 10800602
Capacity:
-63 qt
Features:
-Drain plug
-Internal LED light
-3 yr warranty
Weight:
-54 lbs
-H16.9” x W19.7” x L33.3”
Current Draw:
-Danfoss BD35F
Construction:
Price: $1294
Model: 10800782
Capacity:
-82 qt
Features:
-Drain plug
-Internal LED light
-3 yr warranty
Weight:
-59.7 lbs
-H20” x W17.7” x L33.3”
Current Draw:
-Danfoss BD50F
Construction:
Dometic
Dometic recently revealed the 26 liter fridge freezer at Overland Expo West. This smaller unit is part of the company’s expansive line of heavy duty CFX model fridge freezers. Dometic has been producing cooling equipment since 1968. They produce refrigerator and freezer solutions for home, boating, trucking and yes, overlanding applications.
Dometic: 26 Liter Fridge/Freezer
Price: $608.99
Model: CFX-28
Capacity:
-27 at
Features:
-Soft touch digital controls
-Quick chill/turbo function
-Strong hinges, latches, and drop-down handles
-Memories maintains preset temperatures when shut off
-Internal LED light
-Holds 31 12 oz cans
Weight:
-36.4 lbs
-H16.75” x W13.5” x L24.5”
-Waeco
Construction:
-Polypropylene exterior
Dometic: 35 Liter Fridge/Freezer
Price: $525.56
Model: CFX-35
Capacity:
-37 qt
Features:
-Internal LED light
-Holds 47 12 oz cans
Weight:
– 39 lbs
-H16” x W16” x L27”
-Waeco
Construction:
Dometic: 41 Liter Fridge/Freezer
Price: $679.99
Model: CFX-40
Capacity:
-43 qt
Features:
-Internal LED light
-Holds 60 12 oz cans
Weight:
– 41 lbs
-H15.7” x W18.1” x L27.2”
-Waeco
Construction:
Dometic: 50 Liter Fridge/Freezer
Price: $585
Model: CFX-50
Capacity:
-53 qt
Features:
-Internal LED light
Weight:
– 44.97 lbs
-H17.9” x W18.5” x L28.5”
-Waeco
Construction:
Dometic: 61 liter Fridge/Freezer
Price: $681.62
Model: CFX-65
Capacity:
-65 qt
Features:
-Internal LED light
Weight:
-51 lbs
-H26” x W22” x L18”
-Waeco
Construction:
Dometic: 94.5 liter Fridge/Freezer
Price: $1049.99
Model: CFX-95
Capacity:
-100 qt (57 qt fridge compartment; separate 43 qt freezer compartment)
Features:
-Internal LED light
Weight:
– 84.9 lbs
-H26” x W22” x L18”
-Waeco
Construction:
Edgestar
Edgestar provides a myriad of products from recreational refrigeration to commercial. Their extensive knowledge and experience of cooling products is passed on to their fridge freezer line. Whether remodeling the bar in your man cave or simply chilling some beers in the backcountry, Edgestar has you covered.
Price: $699
Model: FP430
Capacity:
-43 qts
Features:
-Interior wire basket
-Variable temperature control
-Flash freeze function
Weight:
-45 lbs
-H20 13/16” x W11 7/16” x L17 11/16”
Current Draw:
-2.5 amps
Construction:
-Plastic external shell, metal insulated internal walls
Price: $799
Model: FP630
Capacity:
-63 qts
Features:
Weight:
-57 lbs
-H20 11/16” x W28 1/8” x L17 7/8”
Current Draw:
-2.5 amps
Construction:
Price: $899
Model: FP861
Capacity:
-83 qts
Features:
Weight:
-66 lbs
Current Draw:
-2.5 amps
Construction:
Engel
“The heart of every new Engel fridge/freezer is the next-generation F-Series Sawafuji Swing Motor compressor. This extraordinary compressor motor provides the refrigeration you need without placing unreasonable demands on your batteries. With just one moving part, this motor is the epitome of efficiency. Its piston-action is powered by electro-magnets. Start up power draw is minimal, with piston moving just a fraction of an inch and gradually gaining speed. (Just the opposite of a radial motor compressor which places an enormous power draw on your batteries every time it starts up.)
Spring-mounted in a steel cocoon, the Sawafuji Swing Motor is maintenance-free and designed to do its job in extreme conditions. Vibration-resistant and capable of unaffected operation at inclines of up to 30-degrees, you can count on refrigeration virtually wherever you roam.” -Engel
Price: $814
Model: MT17F-U1
Capacity:
-16 qts
Features:
-Internal rubber mat
-Heavy duty handles (removeable)
Weight:
-40 lbs
-H14.2” x W12” x L21.2”
Current Draw:
-2.5 amps
-Engel
Construction:
Price: $840
Model: MT27F-U1
Capacity:
-22 qts
Features:
Weight:
-45 lbs
-H18.2” x W12” x L21.2”
Current Draw:
-2.5 amps
-Engel
Construction:
Price: $868
Model: MT35F-U1
Capacity:
-34 qts
Features:
Weight:
-60 lbs
-H16” x W14.3” x L25.5”
Current Draw:
-2.5 amps
-Engel
Construction:
-Galvanized steel exterior
Price: $849
Model: MR040F-U1
Capacity:
-40 qts
Features:
Weight:
-48 lbs
-H18.5” x W15.5” x L25”
Current Draw:
-2.5 amps
-Engel
Construction:
-ABS plastic external shell
Price: $910
Model: MT45F-U1
Capacity:
-43 qts
Features:
Weight:
-66 lbs
-H20” x W14.3” x L25.5”
Current Draw:
-2.5 amps
-Engel
Construction:
Price: $1320
Model: MT60F-U1
Capacity:
-64 qts
Features:
Weight:
-85 lbs
-H17.4” x W19.3” x L31.1”
Current Draw:
-2.5 amps
-Engel
Construction:
Price: $1436
Model: MT60F-U1-C
Capacity:
-34 qt (fridge), 26.5 qt (freezer)
Features:
-Split fridge/freezer compartments
-Removable hinged lid
Weight:
-85 lbs
Current Draw:
-2.5 amps
-Engel
Construction:
Price: $1635
Model: MT80F-U1
Capacity:
-84 qts
Features:
Weight:
-100 lbs
-H21.7” x W19.3” x L31.1”
Current Draw:
-2.5 amps
-Engel
Construction:
Indel B
“In 1982 Indel B was selected by NASA to create a refrigerator for use aboard the Space Shuttle Columbia.” -Indel B It’s not known whether the rigors of backcountry travel can match that of a shuttle launch, but with NASA’s backing, the Indel B is should be high on your list of contenders.
Price: $430
Model: TB31a
Capacity:
-32 qt
Features:
-Integrated digital display
-Interior light
-Interior basket
-Eco function to conserve battery life
-3 level battery protection system
-Max cool function to speed up cooling
-0-41F temperature operating range
Weight:
-35.2 lbs
-H15” x W13.75” x L23”
Current Draw:
-2.5 amps
-Danfoss DB35F
-12, 24 volts DC; 115/230 Volts AC
Construction:
-Outdoor grade plastic interior/exterior
Indel B: 40 Liter Fridge/Freezer
Price: $530
Model: TB41a
Capacity:
-42 qt
Features:
-Interior light
-Interior basket
Weight:
-37.4 lbs
-H17.5” x W13.75” x L23”
Current Draw:
-2.5 amps
-Danfoss DB35F
Construction:
Indel B: 50 Liter Fridge/Freezer
Price: $570
Model: TB51a
Capacity:
-52.8 qt
Features:
-Interior light
-Interior basket
-Turbo mode, when surplus power available
Weight:
-40.7 lbs
-H21” x W13.75” x L23”
Current Draw:
-2.5 amps
-Danfoss DB35F
Construction:
National Luna
“Originally designed to meet World Health Organisation specifications for transporting medicines in harsh African conditions, National Luna fridges are now the preferred choice for safari operators, caterers, mining companies, camper manufacturers and serious 4×4 enthusiasts. National Luna refrigerators boast superior cooling power and exceptional efficiency in the harshest environments. All models are tested and guaranteed to freeze to a minimum of -18 in tropical conditions of 43 degrees celsius.” National Luna
National Luna: 40 liter Fridge/Freezer
Price: $1550 (aluminum exterior) $1835 (stainless exterior)
Model: National Luna 40
Capacity:
-42 qt
Features:
-Internal LED light
-Lockable latch
-High strength carry handles
-Digital thermostat
-Up to 3 baskets
Weight:
-50.5 lbs
H20.25” x W16.5” x L25”
Current Draw:
– 2.5 amps
Danfoss BD35F
-12, 24 volts DC; 100-240 Volts AC
Construction:
-Rigidized stainless steel exterior; smooth aluminum interior or structured 3004-H44 aluminum exterior
National Luna: 50 liter Fridge/Freezer -Weekender
Price: $1650
Model: Weekender 50
Capacity:
-42.25 qt fridge; 10.5 qt freezer
Features:
-Internal LED light
-Lockable latch
-Digital thermostat
-Battery monitor
-Dual-direction hinging lid (customizable)
-Separate freezer compartment with internal lid
-3 food grade plastic baskets
Weight:
-58 lbs
H20” x W15” x L28”
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 52 liter Fridge/Freezer -Weekender
Price: $1470 (aluminum exterior) $1650 (stainless exterior)
Model: Weekender 52
Capacity:
-55 qt
Features:
-Internal LED light
-Lockable latch
-High strength spring loaded handles
-Digital thermostat
-Battery monitor
-Optional fridge freezer compartments
-Holds 84 12 oz drink cans without basket
Weight:
-51 lbs
H33.25” x W20” x L28”
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 60 liter Fridge/Freezer
Price: $1720 (aluminum exterior) $1950 (stainless exterior)
Model: Twin 60
Capacity:
-36.87 qt fridge, 25.57 qt freezer
Features:
-Internal LED light
-Lockable latch
-Digital thermostat
-Battery monitor
-5 food grade plastic baskets
Weight:
-57 lbs
H21” x W17” x L30”
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 72 liter Fridge/Freezer
Price: $2535
Model: 72 Liter Dual Door
Capacity:
-36 qt right bin, 40 qt left bin
Features:
-Internal LED light
-Dual independent digital thermostats
-Battery monitor
-Dual lids with lockable latches
Weight:
-95 lbs
H21” x W19.5” x L32.87”
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 80 liter Fridge/Freezer
Price: $2125
Model: National Luna 80
Capacity:
Features:
-Internal LED light
-High strength handles
-Digital thermostat
-Battery monitor
-Lockable latches
-4 food grade plastic baskets
Weight:
-90 lbs
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 90 liter Fridge/Freezer
Price: $2535
Model: Weekender 90
Capacity:
-95 qt (dual compartments, one 50 liter, one 40 liter)
Features:
-Internal LED light
-Digital thermostat
-Battery monitor
-Lockable latches
Weight:
-73 lbs
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
National Luna: 125 liter Fridge/Freezer
Price: $2525
Model: National Luna 125
Capacity:
-135 qt
Features:
-Internal LED light
-Digital thermostat
-Battery monitor
-Lockable latches
-7 stainless steel baskets
Weight:
-105 lbs
H29.5” x W19.5” x L32.87”
Current Draw:
– 2.5 amps
Danfoss BD35F
Construction:
Smittybilt
Rock-rails, sliders, lift kits …Smittybilt is well known for their Jeep upgrade components. However, the company also offers a breadth of items to make your camping experience more comfortable. This list includes everything from tools to roof top tents to …well, their new Arctic fridge freezer.
Smittybilt: 52 qt Fridge/Freezer
Price: $799.99
Model: Arctic
Capacity:
-52 qts
Features:
-Fast cool capability
-Digital temp presetting and LCD display
-Interior LED
-Removable internal basket
-Separate dairy section
Weight:
-46.1 lbs
H21” x W13.5” x L22”
Current Draw:
-3.3 amps
-Danfoss
-12 volt DC, 120 volt AC
Construction:
-Aluminum lined interior, plastic exterior
Whynter
Whynter produces a host of fun products, including ice cream makers and humidors. They also produce refrigerators and freezers for commercial applications and 12/24 volt fridge freezers for marine and automotive purposes. They are possibly the most economical company listed on our list, but also have the highest amperage draw by almost two fold.
Price: $645
Model: FM-45G
Capacity:
-45 qt
Features:
-Fast freeze function
-LED temp display
-Low power indicator
-2 removable wire baskets
-Side handles
Weight:
-45 lbs
-H20.5” x W23.5” x L16.5”
Current Draw:
-4.5 amps
-Panasonic
Construction:
-“Tough and solid outer casing”
Price: $690
Model: FM-65G
Capacity:
-65 qt
Features:
-LED temp display
-Side handles
Weight:
-57 lbs
-H21” x W28” x L18”
Current Draw:
-4.5 amps
-Panasonic
Construction:
Price: $833
Model: FM-85G
Capacity:
-85 qt
Features:
-LED temp display
-Side handles
Weight:
-57 lbs
-H21” x W29” x L21”
Current Draw:
-4.5 amps
-Panasonic
Construction:
