Renogy 12.8V Super Slim Solid State Lithium Iron Phosphate Battery :: Field Tested
Lithium batteries are evolving rapidly, resulting in tumbling prices and new products every few months. At the forefront of consumer lithium batteries for over a decade, Renogy continues to iterate on well-proven solutions, pushing the envelope of what is possible. Its latest super-slim solid-state battery provides 104 amp-hours of energy in a tough metal enclosure only 2.4 inches thick, making it ideal for space-constrained mounting locations.
In my testing, the EV-grade cells withstood the nastiest of corrugations, and thanks to new chemistry, they heat up nine times slower than traditional lithium batteries. I have charged the batteries all the way down to -14°F, much lower than previously possible, and even directly shorting the terminals of a fully charged battery barely induces a tiny spark before the internal safety systems shut down the battery, making thermal runaway and catastrophic fire concerns of the past.
With built-in Bluetooth and an internal shunt, monitoring battery temperature, state of charge, and real-time current flow is a snap with the free DC Home app. With an optional bus bar kit, I have chained two batteries to provide 208 amp-hours of energy, a setup that can be expanded up to a whopping 1,664 amp-hours at 12, 24, or 48 volts. Rated for 6,000 cycles and with an eight-year warranty, Renogy’s latest will keep you flush with power for years to come.
$1,000 | renogy.com
Editor’s Note: This article was originally published in Overland Journal’s Winter 2025 Issue
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland International may earn a small commission from affiliate links included in this article. We appreciate your support.
Dan Grec is an adventurer, snowboarder and photographer based in Whitehorse, Yukon, Canada. Growing up in Australia gave Dan a passion for travel and exploration, and years of family road trips around the continent re-enforced that passion. In 2011 Dan set out in his Jeep Wrangler and drove 40,000miles from Alaska to Argentina, passing through some 16 countries over 22 months. You can connect with Dan, and learn more about his developing adventures at: The Road Chose Me
