  • News
  • Overland News of the Week, November 6, 2026
Acela Truck Company Expands Severe-service Truck Chassis Offerings
Hest Nest Blanket and Sleep Goggles
Hest Nest Blanket and Sleep GogglesHest continues to elevate the camping experience with its new Nest Blanket and Sleep Goggles. The Nest Blanket is available in hydrophobic down or 100% recycled synthetic and is designed to keep you comfortable wherever you decide to sit. It features a cinch footbox to keep your feet and lower body toasty, a front hand-warmer pocket, and a wrap-and-snag closure for a poncho-style fit. The Sleep Goggles incorporate the company’s proprietary Frame Fit Technology; the soft foam naturally wraps around the face for light-blocking with less pressure/material to create better space and airflow around the eyes.
$39-149 | hest.com
Off Highway Van Unveils 2027 Lineup
Off Highway Van Unveils 2027 Lineup Off Highway Van (OHV) unveiled its 2027 lineup, which includes a fully redesigned Doc Holliday. Designed for families, this model boasts seating for eight, with DOT-approved seats and up to three sleeping areas. It also enjoys an updated galley with 50% more drawer storage, north-south sleeping, and 25% more onboard freshwater (while maintaining an average weight of 7,500-8,500 pounds). The range also includes the Pro-X, which is the brand’s flagship model with highlights that include radiant heated floors, a JL Audio package, and Fox Factory suspension.
offhighwayvan.com
American Expedition Vehicles Heavy-duty Adjustable Lower Control Arms for JL Wrangler and JT Gladiator
American Expedition Vehicles Heavy-duty Adjustable Lower Control Arms for JL Wrangler and JT GladiatorAmerican Expedition Vehicles (AEV) has introduced its heavy-duty lower control arms for the JL Wrangler and JT Gladiator, which maintain proper suspension geometry, durability, and ride quality across a wide range of lift heights. When paired with the company’s 4-inch DualSport suspension system, these lower control arms are required for 39-inch tire fitments and ensure correct axle positioning, tire clearance, and overall system performance. Unlike typical aftermarket solutions that prioritize maximum articulation at the expense of refinement and service life, AEV control arms are designed as part of a fully integrated suspension system.
$600 | aev-conversions.com
Outdoor Vitals Expanse Sleeping Bag
Outdoor Vitals Expanse Sleeping BagOutdoor Vitals introduced the Expanse sleeping bag (available in regular and long sizes), a hoodless, ultralight option for adventurers who want room to move without adding weight. It features a 15°F comfort rating, 900 fill power ExpeDry Muscovy down, 10D nylon inside and out, a wide footbox, a cinchable draft collar, a half-length side YKK zipper with draft tubes, symmetrical down distribution, and a roomy tapered cut with 30 inches across the shoulders and 27.5 inches at the knee. The sleeping bag weighs just 1 pound 13 ounces (or 2 pounds for the long variant) and compresses into the included stuff sack (also includes storage bag).
$500-520 | outdoorvitals.com
Garmin inReach Messaging Update
Garmin inReach Messaging Update If you’re an overlander or outdoor enthusiast who likes to explore the backcountry, it’s important to have failsafes in place for emergencies. With this in mind, Garmin has long set the benchmark for pocket-sized satellite communication and emergency response devices. The company has recently announced that when you send a message from an inReach-enabled device or compatible Garmin mobile app to a US mobile phone number, the recipient will no longer receive a clickable map link. Instead, they will receive your latitude and longitude coordinates. This change does not affect Garmin Messenger app users.
garmin.com
Dometic 60K Tankless Water Heater Essential
Dometic 60K Tankless Water Heater Essential Dometic’s new 60K tankless water heater Essential combines continuous hot water, intuitive temperature control, and flexible replacement options. It features 60,000 BTU tankless performance without the need for a traditional storage tank and delivers up to 2.4 gallons per minute and heats water up to 124°F. An intuitive digital wall controller makes adjusting water temperature seamless, while integrated antifreeze protection provides additional confidence during colder seasons. If you’re looking for a compact solution for everyday routines, back-to-back showers, and post-adventure cleanups, this would serve as a great option.
$tbc | dometic.com
Dissent Off Road LC250/GX550 Exterior Window MOLLE Panels for Dissent Roof Rack
Dissent Off Road LC250/GX550 Exterior Window MOLLE Panels for Dissent Roof Rack Whether you’re on an extended trip or living on the road, space inside a vehicle is at a premium, especially if you’re traveling in a relatively compact 4WD. This means maximizing wasted space to optimize storage capacity, and this is where the new MOLLE panels from Dissent Off Road come in. They integrate seamlessly with Dissent Roof Racks and cover the rear windows with utilitarian MOLLE panels, perfect for mounting RotoPax, tools, cases, and other accessories. Each panel is laser-cut, powder-coated, and features a lightweight aluminum construction. A great solution to keep your interior free of bulky items, while still ensuring they’re readily accessible.
$300-585 | dissentoffroad.com
Optima Batteries Announce New Redtop with hAGM+ Technology
Optima Batteries Announce New Redtop with hAGM+ Technology Optima launches Optima Redtop RH6 and RH7 batteries with hAGM+. The new technology means batteries perform beyond the engine compartment and basic operations, delivering longer battery life to support power-hungry tech and conveniences synonymous with modern vehicles. The latest batteries deliver up to two times faster charging between electrical demands versus standard AGM batteries. They also promise up to 3 times longer battery life and 15 times better vibration resistance. The new batteries are assembled in the USA and will be available for vehicles using the common H6 and H7 sizes.
$varies | optimabatteries.com
Acela Truck Company Expands Severe-service Truck Chassis OfferingsAcela Truck Company is expanding its severe-service chassis portfolio with new Class 3-5 Ford F-Series and Ram 4×4 platforms equipped with its proprietary DuraLink suspension system. Designed for demanding on- and off-highway applications. DuraLink is a total suspension solution that incorporates a multi-rate four-link suspension design with Bilstein coil-over and racing-tuned shock absorbers, along with optimized steering geometry and chassis control interfaces. The system is engineered to increase wheel travel, improve damping and rebound control, and provide the additional ride height and ground clearance necessary to accommodate larger defense-rated tires. Additionally, super-single wheel and tire configurations are available with tires up to 42 inches.
acelatruck.com
Method Race Wheels 711-HD Bead Grip
Method Race Wheels 711-HD Bead Grip Method Race Wheels has expanded its range with the new 711-HD Bead Grip wheel, built for heavy loads and featuring patented Bead Grip Technology (for increased grip at low pressures), race-inspired reinforced construction, and a load rating of 3,310–4,500 pounds. It showcases aggressive safety humps to protect against de-beading, a deep recessed lip, replaceable 12-point lip bolts, and a snap-in center cap. Forged Impact Rings are also available for added protection and customization. Constructed from solid A356 aluminum with T6 heat treatment, available in hub-centric fitments, and backed by an industry-leading lifetime structural and 5-year finish warranty.
$varies | methodracewheels.com
Defender’s Classic Division Launches New Upgrade Program
Defender’s Classic Division Launches New Upgrade Program Defender’s Classic Division launches a new upgrade program, crowned by the Works V8 Conversion. It applies to Defender 90 and 110 models built between 2007 and 2016 and includes various enhancements, such as wheels, suspension, brakes, and other performance upgrades. The range is headlined by the new Defender Works V8 Conversion, which lets owners reimagine their vehicle with a 405-horsepower, 5.0-liter V8 engine, upgraded chassis components, and enhanced braking. It’s a great option for those who want to rejuvenate their classic Defender without buying the overly complex, arguably luxury-focused modern generation.
landrover.com
Club Ride Apparel Kodiak Hoodie
Club Ride Apparel Kodiak Hoodie Club Ride Apparel has been my primary clothing for everyday riding and bikepacking since I discovered them half a decade ago. I love that they manufacture clothing that incorporates the latest cycling-forward technology while staying understated and stylish. The new Kodiak hoodie is no exception, combining stretch, weather resistance, warmth, and practical storage. Key attributes include a rugged outer shell, a side zipper (which makes the anorak easier to pull on or off), an adjustable bottom hem to seal out wind, and a soft brushed interior for warmth and comfort. In addition, it boasts a kangaroo-style front pocket, Ride Light reflective labels, and is available in two colorways.
$150 | clubrideapparel.com
 New Warn Evo Winches
 New Warn Evo WinchesThe Warn Evo and VR EVO series have been industry staples for more than a decade. The company has now introduced its EVO range, which carries forward the desirable attributes of the VR EVO, while introducing never-before-seen levels of customization and bold color options. At its foundation, it boasts a powerful series-wound motor mated to an all-metal three-stage planetary gear train for fast, smooth, and reliable operation, with the lowest amp draw and fast line speed under load in its class. It also boasts a first for the company: optional die-cast, removable, customizable armor, which is available in five colors and allows customers to match or accessorize their rig.
$varies | warn.com
Leitner Designs Fierfly Light
Leitner Designs Firefly Light Living in an overland vehicle, you pack everything you own into whatever storage you have available, whether that’s a drawer system, cupboards, or containers. With limited space, these areas can quickly get cluttered, and finding what you need in the dark can be challenging. To this end, Leitner Designs has introduced the Fierfly; a rechargeable light that snaps into a magnetic dock that can be mounted just about anywhere. It delivers up to 300 lumens and a considerable 10-hour runtime on its lowest setting (charges via USB-C in under 45 minutes). Constructed from anodized 6061-T6 aluminum and carbon-filled composite, it has an IPX5 rating and includes three mounts.
$30 | leitnerdesigns.com
Prinsu Propane Tank Mount
Prinsu Propane Tank MountStoring propane inside a rig isn’t recommended, and the canisters take up a lot of space. The new Prinsu propane tank mount solves this issue and integrates seamlessly with the company’s roof rack, bed rack, or rear bumper swing arm. This high-strength carrier provides a solid, vibration-free exterior storage solution for 10-pound aluminum cylinders from brands like Flame King and Howl Campfires. Highlights include a dedicated lock to deter theft and a heavy-duty construction built to withstand harsh off-road conditions. Finally, the product is backed by a lifetime warranty.
$169 | cbioffroadfab.com
Helinox Chair Zero LT
Helinox Chair Zero LTI’m not someone who obsesses over the latest and greatest gear, but I do appreciate products that replace old, heavy/bulky items with lightweight/compact alternatives, as someone who lives in a vehicle with limited payload and space. A great example is the Zero LT from Helinox; it’s ultra-lightweight and ideal for activities where every ounce counts. At just 1 pound, 1.5 ounces, it packs into a 14 x 4.5 x 4.5-inch carry case. Finally it features a proprietary DAC TH72M aluminum alloy frame, nylon resin hubs, and Ghostgrid (a translucent monofilament mesh and an X-strap for added stability on soft terrain).
$160 | helinox.com
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland Collective may earn a small commission from affiliate links included in this article. We appreciate your support.
