New Sprinter-Compatible Method 901 Dually Wheels
Sprinter owners take note, Method Race Wheels, known for their high-performance products that promise to be “lighter, stronger, faster” has just released the 901 Sprinter dually. This matte- black front and rear wheelset is manufactured from solid A356 aluminum with T6 heat treatment construction.
The 901 Sprinter Dually has the iconic 12-window design, a bolt-on front center cap, and push-through rear center cap, both with embossed METHOD logos. The front and rear wheels have a 3,000-pound load rating, and according to METHOD, the “industry’s best lifetime structural warranty.”
**Aftermarket lug nuts and a valve stem extension kit are required for installation.
A full set of 901 Sprinter duallys in 16×5.5 with a 6×205 bolt pattern will set you back $1,294. Of course, if you don’t have a dually but still want some Method wheels, there are a handful of other Sprinter-compatible options including the following.
  • METHOD Race MR301 – A 10-spoke machined aluminum or satin black rim with push-through hub covers, removable stainless bolts around the lip, and the Method logo machined into one of the spokes. The MR301 will increase your track width with a 50-millimeter offset and is compatible with Method’s hub-centric spacer kit.
  • METHOD 701 – This 8-spoke design comes in black or bronze and is made from 356 aluminum and is T6 heat treated. METHOD’s bead grip technology ensures proper bead seat and reduces tire roll-off in low-air situations with reviewers confirming this functionality down to 10 psi.
  • METHOD MR305 NV – One of the higher-rated wheels that is Sprinter compatible, the MR 305 NV comes in silver, bronze, or black (all with a black lip). This 12-spoke design has a machined face and undercut outer lip. A machined Method logo surrounds the center wheel face and each wheel features a push-through hub cover center cap.
Check out the 901 Sprinter Dually on Method’s website.
Matt is a paragliding pilot and adventure seeker living in Boulder, Colorado. His love of the outdoors has driven him to explore remote destinations across North and South America in search of the most aesthetic peaks and beautiful flying sites. IG: @m.b.swartz
