KC Hilites Solar Charge Hub is a portable, weather-sealed solar charging system designed to power 12-volt battery setups in off-grid environments. This system seems perfect for those who require a rugged and simple solar charging system that offers flexibility and performance in an off-road environment. It may also be perfect for overlanders who outfit their vehicles with a “less is more” design mentality.
Built with a Victron MPPT unit, it ensures safe, efficient battery charging and integrates seamlessly with mobile devices through Bluetooth for monitoring. It also includes three SAE ports: one for the battery, one for solar input, and another for accessory output. The unit has a built-in power bank feature, allowing you to charge devices such as phones and laptops from your vehicle’s battery. The durable aluminum housing and IP67 weather seal make it suitable for rugged outdoor use, as the Solar Charge Hub can be permanently mounted to the vehicle’s exterior.
Additional features include magnetic feet for versatile mounting options and various accessory cables, which are long enough for customizable setups and relocating the solar panels to sunny spots while the vehicle is parked in the shade. Optional accessories, like KC’s 150-watt portable solar panels, enhance its utility, offering flexible mounting solutions that cater to multiple adventure setups. The hub can be a portable trickle charger for various applications, from charging a trailer’s battery to supporting off-road vehicles. It also serves as a reliable backup system for starter batteries. In various scenarios, the Solar Charge Hub should provide a convenient and efficient way to maintain power on the go, compatible with a wide range of battery types, including lithium, AGM, and lead-acid.
The Solar Charge Hub is compatible with a range of vehicles, from trucks and Jeeps to UTVs and campers. Its design prioritizes versatility, offering an optional mounting bracket for secure attachment to MOLLE panels or roof racks. Unlike permanently installed systems, this setup emphasizes flexibility and durability, adapting to various conditions while requiring minimal installation.
KC Hilites Solar Charge Hub bundle features the Solar Charge Hub with the mounting bracket and KC’s portable solar panels. This combination emphasizes simplicity and mobility, making it well-suited for off-grid adventures.
From $350 | kchilites.com
Read More: Van Conversion Companies :: Buyers Guide
