Ducati Unveils Desmo450 EDS Dual Sport
Ducati’s 2026 Desmo450 EDS takes desmodromic valve timing into the outback with their first modern street-legal enduro/dual-sport machine. Per Ducati, the EDS was “born with a clear vision, one that speaks of passion, technology, and exploration.”
The Goal
Based on Ducati’s Desmo450 MX motocross bike, the EDS is built to take on the natural world instead of a track. With the goal of enhancing traction and acceleration, the company preformed a major re-design of the MX. The result is a new engine that combines a flatter torque curve at the low and mid-ranges with a high redline for powering through rough terrain.
The Result
Ducati credits several engine mods that enable this Desmo450 to generate “smooth, progressive, and always manageable power delivery, combined with excellent overall acceleration.” Reducing the throttle body from 44 mm to 42 mm leads the list. Other changes include new camshafts, a lower compression ratio piston, and a heavier crankshaft and flywheel. An exhaust system tuned for the new motor completes the package.
Ducati claims 42 horsepower at 6,750 rpm and 33 foot-pounds of torque at 5,750 rpm for the stock powerplant. If that’s not enough for you, there are 12 more ponies waiting to be unleashed with Ducati’s performance kit. The upgrade includes new engine mapping and intake components, plus an Akrapovič silencer. Two ride modes, and defeatable traction control are also included.
EDS Gears and Cooling
A 6-speed gearbox puts the power to the ground, with first gear being short for acceleration and enhanced control in tricky situations. The middle gears are spec’d for enduro riding, with sixth being on the overdrive side for “greater efficiency in long riding sessions.”
Like the MX model, the 450 EDS sports two rhomboid-shaped radiators for cooling, one tucked in on either side of the tank. An electric fan kicks in when necessary to keep coolant temps down in hot weather and slow going. The fan shape and translucent 2.2-gallon tank keep a slim profile for better rider control. Climbing atop the 38-inch-high seat to enjoy that control will be a challenge for some riders. There’s been no mention of a lower seat.
Running Gear
Like the engine, Ducati based the Desmo450 EDS frame on the perimeter design of the MX, looking at every component from the enduro perspective. The result is an aluminum structure comprising only 11 parts and weighing just under 20 pounds. Ducati credits the frame for keeping the bike’s dry weight down to just 264 pounds.
The EDS features fully adjustable long travel Showa suspension at both ends, with 12.2 inches of travel up front and 11.8 inches at the rear. The swingarm is a cast-aluminum piece. Ducati shod the bike’s 18-/21-inch Takasago rims with Metzeler 6 Days Extreme rubber for super grip off the pavement while still being legal on the street.
Desmo450 Maintenance
Ducati has taken the guess work out of maintenance intervals by fitting the EDS with an algorithm that calculates wear based on usage. The data can be viewed on their X-Link app. There are two categories of maintenance, mid and full, with the former necessary at 90 to 120 hours. Among other things, the bike comes away with a new piston and spot-on desmodromic valve clearances. At 180 to 240 hours the 450 gets the full treatment complete engine overhaul.
In Summary
By now it’s obvious that the Desmo450 EDS is not, and never will be, an RTW platform. On the other hand, it looks like one heck of a machine for fun in the dirt, with the caveat that you carry fuel or limit your riding.
Ducati is pricing the EDS at $12,995 and says it will be in selected European dealerships in July, 2026. Stay informed at Ducati.com.
Specifications
Engine type: Liquid-cooled, 449cc single 4-stroke Desmo
Engine performance: (claimed) 42 horsepower at 6,750 rpm; 33 pound-feet of torque at 5,750 rpm
Fuel capacity: 2.2 gallons
Transmission: 6-speed, quick shift up only
Suspension/front: 49mm Showa upside-down fork, fully adjustable, 12.2 inches travel
Suspension/rear: Showa mono shock, fully adjustable, 11.9 inches travel travel
Brakes/front: Brembo 2-piston floating caliper, Galfer 260mm single disc
Brakes/rear: Brembo 1-piston floating caliper, Galfer 240mm single disc
Tires/front: 90/90-21 Metzeler Karoo 4 M/C, M+S
Tires/rear: 140/80-18 Metzeler Karoo 4 M/C, M+S
Seat height: 38 inches
Ground clearance: not specified
Weight: 264 – (factory claim, wet, no fuel); full fuel load is ~13.4 pounds
Read more: Affordable Dualsports
Images: Ducati
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland Collective may earn a small commission from affiliate links included in this article. We appreciate your support.
A 1969 Yamaha 125 Enduro launched Arden into decades of off-pavement exploration and dirt camping far from civilization. His favorite haunt is southern Utah, where he has been a whitewater river guide and a National Park Service employee. He also enjoys horseback travel, having seen the backroads of a dozen countries from the saddle. His biggest equine thrill was being chased by elephants in Kenya. Arden has contributed adventure stories, gear reviews, and motorcycle tests to Rider Magazine and others for over 30 years. He believes in wilderness, wildlife, and being kind to the earth, and is happiest riding backroads and camping in the middle of nowhere. He currently rides a Ténéré 700 and a Honda CRF300LS.
