Ducati Revamps the DesertX for 2026
Ducati has completely revised their DesertX adventure bike with a new V2 engine and monocoque frame. The 2026 X model evolved from lessons learned while racing in some of the world’s toughest off-road events, such as the Erzbergrodeo and Mexican 1000 Rally. In Ducati’s words, “The new DesertX was created with the specific aim to further improve off-road performance without sacrificing the riding pleasure typical of Ducati motorcycles.”
Ducati Power
The twin-cylinder V2 boasts four valves per cylinder and variable intake valve timing (IVT) to broaden the powerband and enhance throttle response. Ducati claims 110 horsepower and 67.8 pound-feet of torque from the new mill, of which 70% reaches the rider’s wrist at just 3,000 rpm. That power runs through a 6-speed transmission, with the first four cogs close-spaced and sixth gear as a highway cruising overdrive. Longer service intervals, nearly 28,000 miles for valve checks and 9,300 miles for oil changes, indicate Ducati’s faith in the engine.
Body Work
A new monocoque frame uses the V2 as a structural element, while also saving space by acting as an airbox. The new system makes the air filter owner serviceable, a huge improvement over the former dealer intervention required on previous models. The rear frame is a trellis design that that Ducati claims will reduce maintenance costs by providing ready access to engine components.
Suspension and Brakes
Ducati spec’d new suspension to match the more powerful engine and improved frame. Progressive linkage, set up to improve both off-road handling and on-road comfort, now operates via a new aluminum swingarm. The front end received an upgraded Kayaba fork that Ducati claims rides smoother and tames the bumps better. Hydraulic adjustments on both legs allow customizing the ride for rider and load.
The DesertX V2 has Brembo brakes with monoblock calipers and 308mm discs up front to pull the X up short. The new system is aimed at supplying better brake modulation and lever feel while off-road, while retaining excellent braking power on the pavement. The rear stoppers are unspecified. Pirelli Scorpion Rally street rubber adorns the tubeless 21-/18-inch rims on the DesertX.
Fill ‘Er Up
The DesertX’s new fuel tank is a two-piece affair that carries a decent 4.6 gallons of gas. Made slimmer and constructed of polymer for light weight, it also carries the fuel load lower to reduce the bike’s center of gravity, improving handling. Crash pads protect the tank in a get-off, and updated side panels provide more grip for better control while standing on the high-traction pegs. Although the X’s standard seat height is 34.6 inches, a lower seat and suspension kit will bring it down to 33 inches.
Pilot’s Perch
Up front is a horizontal dashboard with a utility bar for adding nav and other instruments. Ducati says the new arrangement provides the rider a better view directly in front of the bike while standing, making it easier choose the right line.
The 2026 DesertX is flush with electronics. Topping things off is a new 5-inch TFT dashboard that includes two USB sockets. A rider can choose from three display modes—Road, Road Pro, and Rally—to view the data set corresponding to the current ride situation.
DesertX Performance Options
A six-axis inertial measurement unit enables traction control, ABS, cornering ABS, wheelie control and engine brake control aboard the X. All have several levels of adjustment for dialing in a desired amount of intervention. Cruise control is also included for those long pavement hauls.
There are four distinct levels for cornering ABS. The first two are for off-road riding, with level 1 aimed at faster riders and level 2 suitable for newer riders learning the ropes of rear wheel maneuvers. Levels 3 and 4 handle settings for pavement.
A DesertX pilot can choose from six ride modes: Sport, Touring, Urban, and Wet for pavement riding, or Enduro and Rally for the dirt. Each mode can be customized to suit a rider’s style and the road ahead, and ABS can be disabled in Enduro and Rally modes. Ducati’s new Quick-Shift 2.0 simplifies gear changes in both direction an has no external sensor to suffer damage. The 2026 bike also has steering damper, however it’s not adjustable like the unit on the previous model.
DesertXtras
Ducati’s range of add-ons allow DesertX riders to explore the hinterlands with confidence. Built to hit the ground first in a crash, their 2.1-gallon auxiliary tank increases the bike’s range significantly. Radiator guards will further protect the bike. Up front, a larger windscreen and beefier hand guards should keep the pilot protected from the weather. Ducati offers aluminum panniers with racks for those preferring a hard luggage solution. A soft luggage package made in concert with Mosko Moto caters to the light-is-right crowd.
Ducati calls their Multimedia System with Bluetooth phone navigation a “modern essential.” However, it is offered as an add-on for the X.
The End
Probably the biggest news about the 2026 DesertX is that it will cost $2,000 less than the previous model. When does that ever happen? MSRP for this re-imagined machine is $16,999, still in Star White Silk paint with a matte finish. Look for it in North American dealerships starting in June 2026.
Specifications
Engine type: Liquid-cooled, 890cc V-twin 4-stroke
Engine performance: (claimed) 110 horsepower at 9,000 rpm; 68 pound-feet of torque at 7,000 rpm
Fuel capacity: 4.8 gallons
Transmission: 6-speed
Suspension/front: 46mm KYB upside-down fork, fully adjustable with independent settings on both legs; 230 mm travel
Suspension/rear: KYB monoshock, fully adjustable with remote preload adjustment; 220 mm travel
Brakes/front: Brembo M4.32 radial calipers, dual 305mm discs
Brakes/rear: Floating, single piston caliper
Tires/front: 90/90-21 54V Pirelli Scorpion Rally STR, tubeless
Tires/rear: 150/70 R17 66H Pirelli Scorpion Rally STR, tubeless
Seat height: 34.6 inches
Ground clearance: not specified
Weight: 461 pounds (factory claim, no fuel); full fuel load is ~30 pounds
Read more: 2024 DesertX
Images: Ducati
A 1969 Yamaha 125 Enduro launched Arden into decades of off-pavement exploration and dirt camping far from civilization. His favorite haunt is southern Utah, where he has been a whitewater river guide and a National Park Service employee. He also enjoys horseback travel, having seen the backroads of a dozen countries from the saddle. His biggest equine thrill was being chased by elephants in Kenya. Arden has contributed adventure stories, gear reviews, and motorcycle tests to Rider Magazine and others for over 30 years. He believes in wilderness, wildlife, and being kind to the earth, and is happiest riding backroads and camping in the middle of nowhere. He currently rides a Ténéré 700 and a Honda CRF300LS.
