1986 Volkswagen Syncro Westfalia :: Classifieds
Vanagon Syncro
The Vanagon Syncro is something of a rarity, with only a small selection posted to our forum, including this 1986, a 1987, and a 1989. I’ve owned and lived in a Syncro for more than a decade, and while they have their quirks, I retain that it’s a fantastic vehicle for travel. Alongside the iconic Volkswagen T2 the Vanagon is undoubtedly the vanlife pinup, while the 4WD Syncro model is favored among overlanders. The boxy dimensions provide ample interior living space within a modest exterior footprint, which makes it a joy to live inside and easy to drive in town and on narrow trails. Further still, it’s the aftermarket darling with a huge catalog of parts, accessories, and services available from the likes of GoWesty, Van Café, Simpler Ways, and Venture Libre. If you’d like a better idea of how this platform can be upfitted for exploration then check out inspiring builds from Rad Rides, Just Buggin VW, and Roaming with Rohmer. Alternatively, check out my features on expedition Syncros built by Alika Vaquer and Guanabana Overland. Cue today’s 1986 Vanagon Syncro Westfalia, which boasts over $100,000 of work and includes a desirable Boxeer engine conversion.
Vanagon Syncro
From the Seller:
This is my beloved 86 Syncro with tons of modifications. Please message if anyone is interested. The paint is 90% original under the wrap with very little rust, some clear coat failure, and some filler in the bottom corner of the windows in the normal spots, but I wanted to keep it original and not mess with it.
GPS speedo
Today’s Syncro benefits from a Boxeer 2.0 TDI conversion, which provides impressive performance and economy (seller reports 35-40 mpg) and is mated to an uprated transmission. A dependable motor is matched with legendary capability thanks to 4WD, front and rear lockers, decoupler, “Gelande” crawling gear, armor, and lifted and uprated suspension. Inside these rugged attributes are balanced with the following driver comforts:
  • LED headlight conversion
  • Air conditioning
  • Heated seats
  • HalTech LED dashboard
  • Garmin GPS with backup camera
Vanagon overland
Distinguishing Features
  • Boxeer 2.0 TDI conversion with custom transmission with taller gearing
  • GoWesty Long Travel Fox Reservoir shocks, rear airbags, and extended trailing arms
  • ARB air compressor
  • Big Brake disc conversion
  • Dual rear swing aways with spare tire and rack
  • GoWesty locking center console
  • ARB awning
Vanagon Syncro overland
This 1986 Volkswagen Syncro Westfalia is listed for $52,995 and is currently located in Boise, Idaho. Check the full vehicle specifications via the original Expedition Portal forum post here.
