Nevada-based Autarky Campers builds marine-grade expedition vehicles for “long-term stays in primitive locations.” The company takes a hands-on approach to all aspects of the build, which ensures the same level of expertise is applied from the ground up. Cue their latest offering, the formidable Autarky Vehicles V4. This no-expense-spared rig is built on a 2019 Ford F-450 4×4, which has been optioned out from the factory and further uprated with a plethora of top-tier aftermarket components and a custom-built habitation box. An extreme-duty exterior is balanced with an exceptionally well-equipped interior, courtesy of a bespoke handcrafted camper conversion with redundancy integrated into all systems and generous amenities. Despite these credentials, today’s rig is priced at a competitive $230,000, which is a fraction of what you’d expect to pay some of the leading competitors for a comparable build. Learn more about V4 by watching the full-tour and backcountry demo on YouTube.
From the Seller:
“V4 is an international, overland-ready expedition vehicle built with the highest regarded industry components. The camper runs off a single fuel source; whenever you fuel up at a diesel station, you’re also able to ensure your cooking and heating sources are topped off as well. The camper features a drop-out shower stall and slide-out toilet, providing the benefit of a fully enclosed bathroom but utilizing far less space in the camper. The Power Stroke motor moves the truck along swiftly with more than ample torque for even the steepest of mountain grades. Rough terrain? Desert sand dunes? Deep water crossings? Don’t worry. With 42-inch Continental tires on beadlock wheels you can air down, engage your front locker, and continue to push though the most challenging terrain en route to your next dream overland destination. Once you’re back at home after a long adventure, you are free to simply lift the camper off the truck, using the Rico lift jacks, leaving you with an off-road ready, flatbed work truck/tow machine.”
2019 Ford F-450 4×4 Crew Cab
The F-450 is fitted with a 6.7-liter Power Stroke V8 that produces 450 horsepower and a considerable 935 pound-feet of torque (range provided by a Titan 65-gallon fuel tank). An exceptionally powerful motor is matched with impressive capability thanks to 4WD, high and low range, an uprated suspension, a winch, armor, front and rear lockers, a 360-degree camera system and Echomaster Off-Road Underbody 4-camera kit, and intelligent on-board systems such as Hill Descent Control. Inside, these rugged attributes are balanced with sumptuous luxury courtesy of the Lariat Ultimate Package with driver comforts that include:
- Remote start and keyless entry
- Extended chrome running boards
- Powered, heated, and cooled leather seats
- Tow Technology bundle
- Quad beam LED headlamps
- Auto dual-zone climate control
- Power moonroof
- Fordpass Connect 4G Wi-Fi hotspot
- Sync 3 infotainment system with navigation, 8-inch screen
- Menzel 4-camera networked remote view with GPS security system
- High-end aftermarket audio upgrade worth $15,000
- Powerscope Power Fold heated mirrors
- Speed IR Night Vision system
- weBoost Drive Reach OTR cell phone signal booster
- Dual extra-duty alternators
Distinguishing Features
The build specifications for this rig are extensive; reference the original listing for full details. Below is a selection of notable highlights:
- CM aluminum flatbed with 4 storage boxes and custom full-aluminum welded framed camper with riveted and Sikaflex adhesive exterior aluminum skin panels, bespoke interior, Rico Titan lift system
- DBL Super Single conversion with 20-inch beadlock wheels and Continental MPT81 tires
- Custom Fox 2.0 shocks, 2.5-inch lift kit, and rear suspension airbags with dedicated compressor and wireless remote
- Road Armor Stealth Lonestar front bumper and Smittybilt 17.5-pound winch
- Ampertime 400-amp-hour lithium battery bank, Spartan solar (800 watts total) with Victron Smart Charge controller, 1,500-watt Compact Cotek inverter, Redarc TVMS Bluetooth charge controller and BMS with shunt, various 120-volt and USB outlets
- Winterized freshwater (35 gallons)
- Timberline hydronic system providing hot water, heated flooring, and thermostat-controlled heater
- Fiamma side awning and Dometic RV Elite Oasis II 12-volt door awning
- Rigid Industries lighting
- Indel B marine 12-volt fridge/freezer
- Wallas diesel cooktop
- MaxxFan Deluxe with remote control
- Thetford Cassette Curve toilet on slider and stainless TetraVan custom shower stall
- Extreme Outback Magnum 12-volt compressor with 5-gallon air tank
- Cruise N Comfort 12-volt DC mini-split air-conditioning with wireless app thermostat
This Autarky Expedition Vehicles V4 is listed for $230,000 and is currently located in Nevada. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Email: dcrzach@hotmail.com
Phone: 775-200-3591
Instagram: @autarkyoverland
