Video Field Tested :: Gasper 4 Knife :: Rewild Gear
The premium Gasper 4 knife was built for the outdoors and designed to fuel adventures in the wildest of places. It’s made in the U.S.A. and backed by a Lifetime Warranty. The Gasper 4 handle is designed to model the shape of your hand in the field, so the ergonomic form is both comfortable and safe but won’t cause hotspots or blisters after long use.
Tech Specs: Weight: 4.5 oz Blade Steel: CPM-S35VN Overall Length: 8.85 in. Overall Height: 1.29 in. Handle Length: 4.78 in. Blade Length: 4.07 in. Blade Thickness: 0.125 in. Blade Angle: 20 Degrees Blade Style: Modified Drop Point Blade Grind: Flat, Bevel Grind Blade Hardness: 59 HRC Blade Finish: Tumbled Stonewash Handle Material: TeroTuf Sheath Material: Kydex Sheath/Belt Attachment: Kydex (Included) For more information visit: https://rewildgear.com/products/gasper-4-knife **Image From www.knivesillustrated.com**
