  • 4WD
  • Supertramp Campers Launches the Megatron: A Premium Flagship Expedition Vehicle
Long before Supertramp Campers rolled out its carbon-reinforced Megatron, another Supertramp was preaching the gospel of freedom—armed not with diesel torque but saxophones and guitars. The British rock band’s anthems (my old man’s favorites), like “Take the Long Way Home” and “Breakfast in America,” made wandering sound romantic, restless, and just a little bit rebellious. The Colorado company that shares its name seems to have taken that message literally and bolted it to a Ford F-550 chassis.
Both Supertramps riff on the same theme: escape the ordinary, go your own way, and do it with style. The band crafted sonic journeys for dreamers; the camper builder creates mechanical ones for the modern nomad. Where the rockers used melody to express wanderlust, the engineers use monocoque composites, LiquidSpring suspension, and a 900-amp lithium battery bank.
There’s irony, of course—the “super tramp” of old was a vagabond with nothing but a pack and a poem. The modern version features heated floors, filtered water, a California king bed under panoramic glass, and a starting price of $495,000.
Supertramp Campers, based in Golden, Colorado, has recently unveiled its latest creation—the Megatron, a fully integrated expedition truck that unites off-road capability, long-term livability, and advanced technology in a single, purpose-built platform. The name Megatron might sound more at home in the Transformers universe than in Supertramp’s melodic, piano-driven world. Still, the connection holds if you squint: both speak to power, transformation, and a touch of spectacle. Unlike the company’s earlier slide-in designs, the Megatron is a complete vehicle system built on a dedicated chassis, engineered to deliver the comfort of a high-end motorhome with the autonomy and resilience of a true expedition rig.
At its core, the Megatron is mounted on a Ford F-550 “Elevation Off Grid Black Edition” chassis, developed in partnership with Elevation Off Grid. The truck’s 19,500-pound gross vehicle weight rating leaves approximately 5,000 pounds of usable payload, striking a balance between heavy-duty strength and remarkable maneuverability. Despite its size, the company claims the turning radius remains comparable to that of a Ford F-150 crew cab, a key consideration for navigating wide trails or urban areas.
Supertramp’s camper structure is engineered from a carbon-reinforced, vacuum-infused monocoque composite—produced entirely in-house using marine and aerospace manufacturing techniques. By eliminating traditional wood or aluminum framing, the company achieves exceptional rigidity while reducing weight and the risk of rot or condensation buildup. The monocoque body is mated to the truck via Supertramp’s patent-pending “RockSteady Mount System,” which allows for frame articulation on rough terrain while minimizing body movement, ensuring stability even when the suspension flexes.
Power autonomy is one of Megatron’s defining features. The roof-mounted 800-watt solar array feeds a 910 amp-hour lithium battery bank through a 24-volt/12-volt Mastervolt electrical system. This architecture supports a 4.5-kilowatt inverter and DC-DC alternator charging, providing abundant power for extended off-grid living. A C-Zone touchscreen system manages every onboard function, from lighting and tank monitoring to automated features such as retracting awnings and leveling the truck with its LiquidSpring adaptive suspension. With the touch of a button, the Megatron can self-level or prepare for departure, automating traditionally manual steps.
Essential systems support long-duration travel in varied climates. The hydronic Rixen diesel heating system warms the floors and water supply, while air conditioning ensures comfort in summer heat. The Megatron carries up to 60 gallons of freshwater and 20 gallons of grey water, and employs either a cassette or dry-flush toilet, removing the need for a conventional black tank. Additional convenience features include filtered drinking water, a 14-inch sink, and a dual-burner induction cooktop paired with a six-in-one convection microwave.
Externally, the rig exudes an air of expedition readiness. It rides on 41-inch Goodyear MSA tires mounted to Hutchinson forged wheels and features dual Warn winches, one at the front and one at the rear, integrated into a Supertramp-engineered rear bumper with a spare tire carrier. LiquidSpring suspension not only improves ride comfort but also allows for height adjustment and automatic leveling, which is critical for setting up camp on uneven terrain. The vehicle’s stance measures 10 feet 11 inches tall, with an interior ceiling height of 7 feet 2 inches and an exterior width of 7.75 feet—narrower than many competing expedition trucks.
Inside, Megatron’s cabin combines practical function with understated luxury. A California king-size “Infinity Bed” sits beneath a skylight that also serves as roof access, surrounded by dual-pane panoramic windows. The living area includes an L-shaped lounge that converts into a guest bed through a motorized C-Zone-controlled table. The galley features a large refrigerator-freezer, quartzite or PaperStone countertops, and grain-matched veneer cabinetry. A spacious wet bath houses a sliding toilet and heated flooring, while hidden “airliner-style” overhead compartments and under-booth storage ensure equipment and clothing remain secure during travel.
Every detail in the interior reflects a focus on insulation and comfort for four-season use. The absence of thermal bridging and the high-density composite walls are claimed to reduce condensation and energy loss in cold climates. For adventurers traveling in diverse conditions—from mountain passes to coastal deserts—this attention to thermal management extends the camper’s usability far beyond traditional RV limitations.
At a starting price of $495,000, the Megatron enters the premium end of the expedition vehicle market, competing directly with offerings such as EarthRoamer’s XV-LTi series. Its appeal lies in pairing advanced automation and system integration with a lower price point relative to its high-end peers. According to early reports, the Megatron made a strong debut at Overland Expo West 2024, drawing significant attention for its design maturity and exceptional fit and finish.
For experienced overlanders, the Megatron presents a study in trade-offs. Its 5,000-pound payload, large water and power reserves, and advanced suspension enable long-term self-sufficiency and high towing capacity—Supertramp notes it can pull an 18,500-pound trailer or boat. However, its overall size and cost place it outside the reach of many travelers who prefer compact, field-repairable rigs. The Megatron is better suited for continental expeditions and high-comfort base camp travel than for narrow forest tracks or technical trails. Take the long way home (forgive me, I could not resist.)
Supertrampcampers.com
Read More: SEMA 2025 :: Innovation, Heritage, and Performance Unite in Las Vegas
