Loca Ceramic Pour-over Coffee Filter
When it comes to vehicle-based travel, I am always on the lookout for products that can replace consumable items—for instance, this ceramic pour-over coffee filter. Instead of having to rely on paper filters with your coffee system (which you might have to replace while on the road during longer expeditions), this device is the filter. Ceramics also have the unique ability to improve the flavor of certain things (I’ve experienced this with a ceramic stirring rod and orange juice). Because of this quality, the makers of the Loca suggest that it can produce an even more delicious cup of coffee than whatever your existing brewing method is. And if this filter gets clogged with fine particles, you can just hold it over your camp stove to burn the accumulated sediments away without any worry of damaging the filter. That’s pretty neat.
$55 | loca.hlj.com
Midland MXT 500 and 575
![](https://expeditionportal.com/media/2022/01/MXT575-with-mic-912912_5000x-e1642544611718-1500x904.jpg)
![](https://expeditionportal.com/media/2022/01/MXT500Radio_1_1720X1000_bf770da5-842c-42d5-87f9-fc89cb742461_5000x-1500x872.jpg)
The MXT500 and 575 50-watt GMRS two-way radios, part of Midland’s Micromobile lineup, are the most powerful that the company currently offers (and allowed by law). The MXT500 utilizes 15 GMRS frequencies and eight repeater channels to broadcast transmissions in sprawling terrains, like ranches and off-highway trail systems. The MXT500 carries an IP66 waterproof rating, has an auxiliary USB-C port for charging other devices, provides NOAA weather alerts, has hi/med/low settings, and is both wide- and narrow-band capable.
The MXT575 is very similar, offering all of the same features and performance as the 500, but with a low-profile, screenless base unit. The hand-mic of the MXT575 has an LCD screen for controlling the functions of the radio.
$400 | midlandusa.com
Snow Peak Extention IGT Table
Adding to their ever-expanding Iron Grill Table ecosystem of modular outdoor camp and kitchen furniture, the Extension IGT Table offers versatility for food prep, cooking, or dining, all in one relatively compact unit. Without the need for any connection tools or extension pieces, this table can be operated in the closed position, offering a solid surface featuring a bamboo tabletop or open position, allowing for the use of one or two integrated stoves. Note that stoves must be purchased separately.
$350 | snowpeak.com
Bajio Swash Sunglasses
Bajío sunglasses are named after the Spanish term for saltwater flats, the transitional zone between the beach and the deep blue waters of the ocean. This diverse area is home to a wide variety of aquatic life and also provides one of the most beautiful backdrops for saltwater angling for species like tarpon, permit, and bonefish, to name a few.
Bajío’s sunglasses protect your eyes with high-quality lenses as well as the bajíos of the world through sustainable business practices and by supporting ocean-based environmental conservation groups.
Their Swash model features a lightweight, oversized frame made from bio-based nylon, a material that biodegrades faster than conventional plastics yet is up to 10 times stronger. The Swash’s polycarbonate or glass lenses have an oleophobic coating to prevent scratching, are polarized, and feature blue light-blocking technology to ease eye strain and fatigue during long days in bright sunlight.
$249 | bajio.com
Helle Knives Temagami 14C28N Limited Edition
Les Stroud is Survivorman, a no-nonsense adventurer who shirks Hollywood-style antics in favor of presenting more realistic wilderness survival scenarios on his show. The limited-edition Temagami knife was created to celebrate the 10th anniversary of the collaboration between Helle and Les. This beautiful and versatile full half-tang blade hides cleverly inside the knife’s curly maple handle, where it won’t be uncomfortable on your bare skin in colder climates. The 14C28N blade steel used for this tool is offered in a Scandi grind, making field service easy and woodworking even easier. Finally, a true 90-degree spine provides added versatility for scraping tasks or striking fire-starting ferrocerium rods.
$189 | helle.com
Rago Fabrication Aqua Tank
Rago has a new piece of kit for your 4Runner: an aluminum windshield washer fluid tank that mounts snugly behind your vehicle’s grille. This pressure-tested TIG-welded tank utilizes the factory pump and connects to your factory hoses for an easy 10-minute installation (according to Rago). But why would you want to replace your stock wiper fluid tank? A common problem for 4Runner owners who have installed aftermarket bumpers and/or larger tires on their vehicles is that their factory washer fluid tanks end up being exposed, an issue that can result in damage on the trail. This replacement tank solves that problem with better durability and a footprint that provides improved tire clearance for vehicles with larger-than-stock tires.
$275 | ragofabrication.com
Turtlebox Audio Gen 2 Bluetooth Speaker
Taking music or a podcast along on your overland journey is easy when you are in your rig. But what do you do once you get to camp and want to continue listening? Instead of draining your vehicle’s battery, you could bust out the Turtlebox Gen 2 Bluetooth speaker instead. This powerful and portable sound system has a directional speaker, is fully waterproof, and features stainless steel tie-downs as well as a handle for easily moving it from place to place. It can charge your USB devices thanks to a powerful lithium-ion battery. As a bonus, it also has a microphone input so you and your bros can karaoke to your heart’s content in the woods, where no one will have to listen to your off-key attempts at reproducing Taylor Swift’s hits. **Turtlebox is currently taking pre-orders for Feb 2022 delivery.
$399 | turtleboxaudio.com
Flarespace Rear Window Vents
Good ventilation is a crucial element of any campervan build that can help reduce the likelihood of mold and rust, two common problems that should be avoided at all costs. Flarespace’s rear window vents can be a part of your solution, delivering improved ventilation in your 2007-2022 Mercedes Sprinter or 148 Ford Transit van. These fiberglass replacements fit just like your factory windows, making installation a snap. Integrated screens allow for airflow while preventing bugs from getting into your living space. The sliding windows come with integrated window covers with storage space. What’s more, these replacements will prevent you from breaking your rear window with your bike pedal accidentally (for those of you who have rear-mounted bike racks).
$1990 | flarespace.com
