Overland News of the Week
Mercedes Unimog Overland News
 Oyster Tempo Pro
Oyster Tempo ProNorwegian-based thermal company Oyster has unveiled the Tempo Pro, the latest addition to its high-performance cooler lineup. The new offering builds on the award-winning design of the Tempo Cooler with the introduction of an integrated temperature-monitoring system. It’s designed for those who require precise temperature control in demanding environments and is subsequently well-suited to the rigors of overlanding. Highlights include an internal cooler temperature (and ambient outside temperature), a removable/attachable lid for added versatility and convenience, shoulder strap, IPX5 rating, and an auto sleep mode that activates after 24 hours to preserve battery life.
$550 | oystercooler.com
Exped Launches New Ultra Backpacking Mats
Exped Ultra backpacking matsGetting a good night’s rest in the backcountry is critical, and to achieve this, a quality sleeping pad is essential. To this end, Exped first unveiled its DownMat in 2001, which delivered class-leading insulation and thermal efficiency to the segment. The new Ultra Series carries forward this legacy and promises to be the best yet. At the core of the new range is SynMat Technology, an advanced insulation system that pairs recycled synthetic microfiber with heat-reflective layers to create the highest warmth-to-weight ratio pad on the market. The new technology can be found in the Ultra 6.5R, Ultra 8R, and Ultra 10R
exped.com
Old Man Mountain Atlas Rack Pack (12-liter)
Old Man Mountain Atlas Rack Pack (12-liter)It’s always exciting when Old Man Mountain releases a new product to the segment, and its 12-liter Atlas Rack Pack is no exception. It builds on the success of the 9-liter variant and serves as a fantastic alternative to a seat pack. It sits lower on the bike so it doesn’t interfere with a dropper post, and thanks to four simple mounting straps, it seamlessly secures to your rack of choice. The 100% waterproof pack boasts a fully welded construction and incorporates quick-stash side pockets, a top-mounted bungee cord, and an air purge valve to make it easier to pack soft, bulky items.
$125 | oldmanmountain
Garmin Zūmo XT3 Motorcycle GPS
Garmin Zūmo XT3 Motorcycle GPSThe Zūmo XT3 is Garmin’s newest and most advanced motorcycle-focused GPS and was specifically engineered to endure vibrations, bumpy rides, and extreme weather. It features a bright, glove-friendly display with either a 4.7- or 6-inch screen, an IPX7 water resistance rating, and a military standard drop rating. Additional highlights include preloaded maps, Outdoor Maps+ compatibility, group tracking, a visual route planner, and a live lean angle gauge (informs riders how far they’ve leaned on each turn in real time). Finally, you can utilize Garmin’s Adventurous Routing to research moto-specific rides and enjoy “free ride” navigation with compass-only guidance.
$500-600 | garmin.com
ARB Unveils New Brushless Air Compressors
ARB Unveils New Brushless Air Compressors Industry leader ARB has announced a new line of brushless motor air compressors (fewer wearing parts, revving faster, and superior performance) that provide a 50% increase in output over the existing line of market-leading compressors. Key highlights include active cooling, smart features, electronic speed control, voltage and overload protection, quick-release mounts, and an efficient design that delivers class leading airflow-to-weight ratio. The new compressors will be offered alongside the existing range and similarly be available in four configurations (single and twin onboard models as well as single and twin motor portable options).
$560-1,380 | arbusa.com
AEV Crestone Dualsport Wheel for 2023+ Colorado/Canyon and 2019+ Silverado/Sierra 1500
AEV Crestone Dualsport Wheel for 2023+ Colorado/Canyon and 2019+ Silverado/Sierra 1500 Choosing the correct wheel for the backcountry is critical, and in this regard, AEV’s Crestone Dualsport is optimized for rugged adventures in the 2023+ Colorado and Canyon and 2019+ Silverado and Sierra 1500. Designed specifically for 35-inch tires, the Crestone’s 6×139.7-millimeter bolt pattern and 12-millimeter offset ensure proper clearance and handling. Further still, it’s built from heat-treated A356 T6 cast aluminum and validated to rigorous SAE J2530 standards, which means it’s both lightweight and exceptionally strong. Finally, it showcases a recessed valve stem pocket that shields against trail damage and is tire pressure monitoring system (TPMS) compatible.
$311 | aev-conversions.com
CBI Off Road 2024+ Toyota Land Cruiser 250 Series Covert Front Bumper
CBI Off Road 2024+ Toyota Land Cruiser 250 Series Covert Front BumperThe new Land Cruiser 250 bumper from CBI Offroad enhances off-pavement capability without sacrificing factory aesthetics and supplies essential front-end protection, recovery points, and winch readiness. Crafted from a combination of 7- and 10-gauge steel, the bumper is built to withstand the toughest environments without excessive bulk (weighs just 53 pounds). Additional benefits include precision fitment with a bolt-on design that requires minimum cutting, a corrosion-resistant finish, skid plate compatibility (whether CBI or OEM), and provisions for lighting. So if you’re looking for a quality front bumper that doesn’t detract from the OEM appearance, this would be a great option.
$882 | cbioffroadfab.com
Realtruck Retraxpro EZ-Off FRC-4000 Full Bed Access Manual Retractable Tonneau Cover
Realtruck Retraxpro EZ-Off FRC-4000 Full Bed Access Manual Retractable Tonneau CoverThe FRC-4000 is the industry’s first EZ-Off full-bed access retractable tonneau cover, which combats space-eating canister designs and provides 100% bed access. It’s effortless to remove when transporting oversized loads and integrates Coretrax stainless steel sealed ball bearing rollers that require no cleaning, lubricating, or maintenance. To deter wildlife and thieves, it boasts a bear-tested double-wall aluminum slat construction and is key lockable. To ensure durability across all climates and temperatures, it has been rigorously tested from -40°F to 180°F and features an all-new water-management system to keep your cargo dry.
$varies | realtruck.com
Arcade Adventure Mag Belt
Arcade Adventure Mag BeltA quality belt is an essential item in my pack list, with my favorite to date being the Austere Manufacturing Lock Belt. Arcade has now entered the chat with its new Adventure Mag belt, comprising proprietary Swiftlock technology that snaps into place with embedded magnets and a tension-lock design. The new offering is available in two styles (Aero and Polar), enables one-handed operation, and promises not to slip or release under load. The belt is finished in exclusive Performance Stretch Pro webbing made from recycled Repreve yarn and natural rubber, which supplies a higher denier for a sturdier hand feel and lighter stretch.
$50 | arcadebelts.com
Goose Gear 2024+ Ford Ranger Raptor Explore Series Second Row Seat Delete
Goose Gear 2024+ Ford Ranger Raptor Explore Series Second Row Seat DeleteThe new offering allows Ranger Raptor owners to replace rear seats with a flat storage platform. The seat delete incorporates hatches that allow access to the factory storage space below the rear seats and is “bolt-in.” Due to the unique configuration of the Ranger, this is only available as a 100% percent delete. But it does utilize a 60/40 split design, which allows a fridge/cooler to be fitted behind the passenger seat in a front-to-back orientation, while keeping the 60% space behind the driver free for storage. With the factory seats removed, this seat delete only adds 9 pounds to your vehicle.
 $1,795 | goose-gear.com
GP Factor INEOS Grenadier Bull Bar
GP Factor Ineos GrenadierThe INEOS Grenadier is one of a select few vehicles that was engineered from the factory with overlanding in mind, and this, in turn, has inspired impressive aftermarket support. To this end, GP Factor has unveiled its Grenadier bull bar grill guard, which is crafted from five separate pieces. This unique design promises elevated durability with the added benefit that sections can be easily replaced if damaged. Further still, the modular middle tube can be swapped out to enable a variety of lighting provisions. It secures to the vehicle with factory mounting points and is offered in four configurations, weighs 55 pounds, and is made in the USA.
$1,800 | gp-factor.com
Moon Sport Titan Max
Moon Sport Titan Max I’ve been using Moon lights on my bicycle for half a decade, and they’ve always provided industry-leading performance; the new Titan Max looks to be no exception. It can be top- or bottom-mounted and includes an out-front mount that’s compatible with your bike computer and/or an action camera. It provides multiple modes, a max output of 1,700 lumens, and can be fully charged in 2 hours via USB-C (2-way, so it can also serve as an emergency power bank) or a wireless charging pad. It’s sold with a Bluetooth handlebar remote, allowing you to effortlessly switch between modes.
$90 | moon-sport.com
Step 22 Trash Panda Trail Pack
Step 22 Trash Panda Trail PackThe Trash Panda trail pack features a durable all-weather UV stable design with a fiber-reinforced rigid base and laser cut rigid back panel, which promises no sagging, bouncing, or collapsing. Additional attributes include a dual YKK zipper front access panel, a roll-top/fold closure, an exterior MOLLE panel, integrated bottle opener, side compartments with mesh pockets, an internal zipper pocket, and a front zipper flat pocket. It’s worth noting that while the Trash Panda was optimized to mount to the spare wheel, it also incorporates laser-cut mounting slots so it can be fitted to campers, trailers, MOLLE panels, or other rigid surfaces.
$325 | step22gear.com
Salomon’s Latest Footwear
Salomon’s Latest FootwearA quality pair of lightweight technical shoes is a great addition to an overlanding pack list. In this regard, Salomon has you covered with three new offerings: the Ultra Glide 4, S/Lab Phantasm 3, and Aero Glide 4/GVRL. The Ultra Glide 4s are ideal for technical mountain trips or ultra-distance and are designed for optimal comfort over time. The S/Lab Phantasm 3s are a road-running shoe tested in a wind tunnel to reduce aerodynamic drag and weigh just 7 ounces. Finally, the Aero Glide 4/GVRLs combine the cushion and rebound of the brand’s road-running shoes with the extra grip necessary for trail adventures.
salomon.com
Mercedes-Benz Special Trucks and Hellgeth Engineering Unveil Ultimate Luxury Unimog
Mercedes-Benz Special Trucks präsentiert luxuriösesten Unimog aller ZeitenMercedes-Benz Special Trucks unveils the most luxurious Unimog ever
Mercedes-Benz Special Trucks celebrates its 80th anniversary this year, and to mark the occasion, the company has collaborated with conversion partner Hellgeth Engineering to create the most powerful off-road Unimog to date. Based on the ultra rugged U 4034, it features portal axles, a flexible frame, and differential locks on both axles. The standard engine has been replaced with a 6-cylinder OM 936 delivering 300 horsepower and an almighty 1,033 pound-feet of torque. Inside, the interior is more akin to a luxury SUV with heated and leather ergonomic seats, premium infotainment, and digital cameras/monitors for exterior visibility.
daimlertruck.com
Vision X Offroad, CR Pro Lighting
Vision X Offroad, CR Pro Lighting Vision X has long been a pioneer of auxiliary lighting, and its latest offering, the CR Pro, looks to continue this legacy. The lineup promises to last a lifetime thanks to a robust heat sync, IP69K Dryseal construction, a 21 grms vibration rating, and 5-millimeter-thick steel mounting brackets. The CR Pro is available in 4.5- and 6.7-inch pod sizes and delivers 20% more light than the base CR range. Users have the option to run center LEDs as daytime running lights or switch to all on high beam, while the modular X-Lens system allows customizable beam and color options (including clear, amber, and selective yellow).
$varies | visionxoffroad.com
