Overland Classifieds :: 2022 Toyota Tundra TRD Crew Max Limited
 You really can’t go wrong with Toyota’s current 4WD line-up, whether that’s a Land Cruiser, Hilux, Tacoma, 4Runner, Sequoia, or a Tundra. With excellent reliability, capability, and comfort across the range, the main consideration is which model works best for you. The Land Cruiser is generally regarded as the ultimate overlander (check out Expedition Overland’s 200 Series for inspiration), but much like the 4Runner or Sequoia, it offers limited payload. The Tacoma is the most popular truck on our forum, providing just enough capacity for a lightweight canopy or camper setup. However, if you’re serious about long-term travel or living on the road full time, then the Tundra is arguably the best option. This truck provides a generous payload that can comfortably accommodate a fully equipped camper or habitation box with enough power and amenities for extended off-grid exploration. If you’d like to know more about the benefits of full-size trucks, I highly recommend checking out this informative piece by Scott Brady on the Full-size Revolution. Today’s Tundra is another epic build from Adventure Motors; featuring premium modifications, and an Alu-Cab canopy camper. It has covered just 6,121 miles.
From the Seller:
I am selling my 2022 Toyota Tundra Limited Crew Max 4WD. It is the highest-optioned Limited with TRD Package you can get. This was one of the first registered 2022 Tundras in the Midwest region, and I have personally built this truck from the ground up in partnership with some of the best folks in the industry. The truck has 6,121 miles as of today; however, it will continue to go up as it is my daily driver.”
The Tundra TRD is fitted with a twin-turbocharged V6 hybrid engine that produces 437 horsepower, 583 pound-feet of torque, and returns a combined 20 mpg. A powerful yet relatively economical motor is mated with excellent go-anywhere capability, thanks to the five-link rear suspension, body-on-frame design, Fox 2.5-inch internal bypass dampers, an electronic locking rear differential, and intelligent onboard systems such as Crawl Control and a Multi-Terrain Select. These rugged credentials are balanced with a well-equipped, comfortable interior, including:
  • Infotainment system with navigation, 14-inch
  • Premium 12-speaker JBL audio system
  • Leather upholstery
  • Power heated and cooled front seats
  • Backup camera
  • Dual-zone automatic climate control
  • Blind spot monitoring
Distinguishing Features
  • Fox front coilovers, Dobinsons rear coils and rear shocks, Pro Comp front upper control arms, airbags, and more
  • Method wheels with Toyo R/T tires
  • Adventure Motors skid plates, C4 Fabrication Overland Series front and rear bumper, and rock sliders
  • Battle Born 110AH battery with hood-mounted solar panel
  • Alu-Cab Alu-Cabin Canopy Camper
  • Baja Designs lighting
  • Front Runner roof rack
This 2022 Toyota Tundra TRD Crew Max Limited is listed for $127,500 and is currently located in Kansas City, Missouri. Check the full vehicle specifications via the original Expedition Portal forum post here.
