  • 4WD
  • Oregon Trailer Teardrop Trailers Combine Style, Practicality, and Affordability
When it comes to teardrop trailers for overland travel, Oregon Trailer has made quite a name for itself. We first encountered their range of teardrop trailers at the Overland Expo just outside Bend, Oregon, and the trailers left an impression (keep an eye on Expedition Portal for a comprehensive review of the DoDrop trailer in the coming weeks). Not only do these trailers excel in design and construction, but they also offer a range of features at an affordable price point. The five trailers share very similar DNA but are each slightly different and cater to a variety of needs; for instance, all trailers feature a “Baltic birch interior, high-quality stainless steel fasteners throughout, and a dado-joined floor.”
The Terradrop Alpha
The Terradrop Alpha, known as TDA, is the premium of Oregon Trailer’s offering. It features an innovative alpha coating that promises exceptional exterior durability. Built on a robust yet lightweight 2 x 2 x 0.120-inch square-tube steel frame, the TDA ensures ease of handling with its A-style tongue welded onto a wheeled tongue jack. For off-road adventurers, it boasts a multi-axis off-road coupler package and a 5.2k off-road independent torsion suspension package, providing the stability needed for challenging terrains. With 16-inch, black powder-coated wheels and all-terrain tires, this trailer is ready for the rugged outdoors. It also includes a 7-blade RV-style connector and rear leveling jacks/stabilizer jacks for added convenience.
The Terradrop Alpha’s body maintains the iconic Oregon Trailer original Terradrop profile shape, measuring 60 (w) x 48 (h) x 96 (l) inches, and a custom flat-top fender design enhances its aesthetics. The trailer is constructed with plywood components made from high-end marine-grade birch and solid hardwood cross-members/spars. Rigid foam insulation keeps you comfortable inside, while two 26 x 36-inch standard teardrop doors with tinted glass and screened opening windows provide accessibility and ventilation. High-quality stainless-steel fasteners are used throughout (including exterior fasteners), ensuring longevity. And the dado-joined floor, partitions, and bulkheads add structural integrity. A custom heavy-duty roof rack system provides practicality (with space for a rooftop tent), and a rear 2-inch accessory receiver is included for added versatility.
Inside, the Terradrop Alpha offers a Baltic birch interior with a stylishly designed cabinetry system. Electrical outlets include a 12-volt accessory outlet/plug and a 120-volt AC duplex outlet. The queen-size sleeping area features a high-quality, custom-made foam mattress with a custom cover, and a small overhead storage shelf adds convenience.
The galley is well-equipped with birch storage/shelving complemented by hardwood trim and a Formica countertop. Under-counter storage space ensures you have room for your supplies. A deep-cycle AGM battery, powered by a USA-made Progressive Dynamics power center battery sled, ensures the galley is well-lit with warm white LED dome lights. The galley lid locks securely with a hurricane hinge.
From $24,000 | Terradrop Alpha
 FronTear
The FronTear (FT) offers a personalized outdoor adventure experience with various customization options. Its design includes an A-style tongue welded onto a wheeled tongue jack for effortless maneuvering. You can choose between a 2-inch or 1-7/8-inch ball coupler mounted to the tongue with grade-8 hardware. The rubber torsion axle ensures smooth and well-mannered towing characteristics, and deluxe alloy wheels, tires, and leveling/stabilizer jacks complete the chassis package.
The FronTear’s body dimensions measure 60 (w) x  48(h) x 96 (l) inches. Its construction features high-quality plywood components, and the exterior boasts a powder-coated aluminum finish, with white/black vein as the default color option and LED lighting components to illuminate the exterior.
Inside, you will find a queen-size sleeping area that features a high-quality custom-made foam mattress with a custom cover, and a small overhead storage shelf adds convenience. The galley storage and shelving are complemented by hardwood trim and a Formica countertop.
Under-counter storage space offers plenty of room for your supplies. A deep-cycle AGM battery, powered by a USA-made Progressive Dynamics power center battery sled, ensures the galley is well lit with warm white LED dome lights. The galley lid locks securely with a hurricane hinge.
From $18,000  |  FronTear
FronTear Alpha
The FronTear Alpha (FTA) takes the classic FronTear model and elevates it with exceptional capabilities. It features an overbuilt chassis, a robust alpha coating, and a formidable suspension system.
Its off-road multi-axis coupler and 5.2k off-road independent torsion suspension package ensure stability on rugged terrain. The 16-inch, black, powder-coated wheels, paired with all-terrain tires, provide dependable traction. Built-in leveling/stabilizer jacks further enhance its capability, and a 7-blade RV-style connector and industrial-strength powder-coated chassis are also part of the package, along with a rear 2-inch accessory receiver.
The FTA maintains the distinctive Oregon Trailer original FronTear profile and shape, with body dimensions measuring 60 (w) x 48 (h) x 96 (l) inches. Its construction features the same high-quality components and solid hardwood cross-members/spars as the FronTear and a powder-coated aluminum finish, with white/black vein as the default color option. LED lighting components illuminate the exterior.  The interior and galley are identical to the FronTear trailer.
From $24,000  |  FronTear Alpha
The DoDrop
For those seeking simplicity, lightweight design, and affordability in their camping adventures, the DoDrop is the perfect solution. This camp trailer offers all the essentials without needing a large tow vehicle.
The DoDrop is constructed on a custom, lightweight, square-tube-steel frame and features an A-style tongue and tongue-mounted stabilizer jack for convenience. You can choose between a 2-inch or 1-7/8-inch ball coupler mounted to the tongue with grade-8 hardware. The rubber torsion axle ensures smooth towing and a 4-pin tow connector simplifies connectivity. The chassis is protected by industrial-strength powder coating.
The DoDrop’s body adopts the signature Oregon Trailer original profile teardrop shape, measuring 48 (w) 42 (h) and 84(l) inches. The exterior skin is coated with powder-coated aluminum, with white/black veins as the standard color option (other choices are available with deluxe and custom configurations).
Inside, LED dome lights powered by AA batteries create an inviting atmosphere. An integrated storage shelf and passive roof vent provide additional functionality.
From $8,500  |  Dodrop
DoDrop Alpha
The DoDrop Alpha (DDA) is Oregon Trailer’s answer to off-road capability in a compact package. Its smaller size, lighter weight, and simplified configuration translate into extraordinary off-road capabilities for adventurers seeking rugged terrain.
The off-road chassis is, as with the other trailers, constructed with a 2 x 2 x .120-inch laser-cut square-tube steel frame featuring an A-style tongue welded onto a wheeled leveling jack. The inclusion of an off-road multi-axis coupler, long-travel off-road suspension with separate compression and rebound springs, and 29-inch diameter off-road wheels and tires elevate its off-road prowess. Industrial-strength powder coating ensures durability, and a 4-pin tow connector simplifies connectivity.
The body of the DDA measures 48 (w) 42 (h) and 84 (l) inches, reflecting its compact yet rugged nature. A unique black exterior alpha coating adds a distinct touch (other color choices are available with deluxe and custom configurations).
Other than the upgraded suspension and exterior coating, the DoDrop Alpha features are similar, if not identical, to those of the DoDrop trailer.
From $13,250  |  Dodrop Alpha
oregontrailer.net
Read more: Portable Power Stations :: Buyer’s Guide
