  • Motorcycle
  • Kawasaki Announces 2027 KLE650 ABS, Starting at $8,799
A rider in protective gear on a 2027 Kawasaki KLE650 kicks up a cloud of dirt while riding on a gravel trail.
Recently, we reported on Kawasaki’s 2027 KLR650 ABS, a motorcycle with a long history of global adventure travel and a dedicated following. Now Kawasaki has announced the 2027 KLE650 ABS and KLE650 SE ABS, introducing a 649 cc parallel-twin adventure motorcycle with standard electronic cruise control, traction control, and selectable ABS. Compared with the enduring KLR650, the KLE represents a substantial step toward modern adventure touring.
A motorcyclist in gear rides a green and grey 2027 Kawasaki KLE650 along an open road with mountains in the background.
The KLE’s strongest appeal is its promise of affordable long-distance versatility, with cruise control a welcome feature for extended highway travel. The SE adds tubeless spoke wheels, a quickshifter, a taller windscreen, and additional protection. Competitive pricing could make the KLE an alternative to Yamaha’s Ténéré 700, Aprilia’s Tuareg 660, and Honda’s XL750 Transalp.
Two motorcyclists in protective gear riding 2027 Kawasaki KLE650 adventure bikes on a rocky mountain trail.
The KLE650 builds on the adventure-focused foundation of the KLE500 while placing greater emphasis on highway comfort and long-distance travel. Its 21-inch front wheel and long-travel suspension accommodate unpaved routes, while a stepped seat, adjustable windscreen, and road-oriented tires reflect its broader touring role. For overland travelers, that combination could suit journeys linking extended pavement sections with gravel roads and less-developed routes.
Close-up of a Kawasaki KLE650 exhaust pipe, rear wheel, and green frame. Close-up of a Kawasaki engine featuring a bright green frame, metal exhaust pipes, and a silver skid plate. Silver Kawasaki motorcycle skid plate attached to the underside of a bike frame.
Power comes from a liquid-cooled, DOHC, eight-valve parallel twin developed from Kawasaki’s existing middleweight engine platform. Electronic throttle valves and revised intake and exhaust systems are intended to provide predictable response at low engine speeds alongside highway performance. Kawasaki says the engine has been tuned for strong torque below 4,000 rpm, with a broad delivery through the middle and upper rev range. Kawasaki has not provided horsepower or peak torque figures in the announcement.
A motorcyclist in riding gear and a helmet kicks up dust while turning a 2027 Kawasaki KLE650 on a rocky dirt path.
An assist-and-slipper clutch reduces clutch-lever effort and helps limit rear-wheel hop during abrupt downshifts. Electronic cruise control is standard on both versions, a useful inclusion for riders covering substantial highway distances. Kawasaki’s traction-control system offers two intervention settings, with the second providing greater intervention when excessive rear-wheel spin is detected.
The chassis uses a high-tensile steel trellis frame with the engine serving as a stressed member. Kawasaki describes its geometry as placing greater emphasis on paved-road composure than the KLE500. Fuel capacity is 4.2 gallons, although the company has not supplied a fuel-consumption figure or estimated riding range.
A rider in full gear on a 2027 Kawasaki KLE650 navigates a rocky, unpaved mountain trail.
A 43 mm inverted cartridge fork provides 8.3 inches of front-wheel travel. Kawasaki’s rear Uni-Trak suspension delivers 7.7 inches of travel and includes stepless spring-preload adjustment to accommodate changes in load. Seat height is 34.2 inches. A slim tank and smooth side panels are intended to allow movement between seated and standing riding positions, while removable rubber footpeg inserts expose serrated surfaces for additional boot grip.
Braking equipment consists of dual 300 mm front discs and a 230 mm rear disc. Riders can disable ABS for unpaved riding, but the system automatically reactivates at both wheels when the motorcycle is restarted.
Front wheel and disc brake of a 2027 Kawasaki KLE650 motorcycle, featuring a spoked rim and knobby tire. Rear wheel and suspension of a 2027 Kawasaki KLE650, featuring a distinct green frame and a spoked rim.
Both models use 21-inch front and 17-inch rear spoke wheels fitted with Dunlop Trailmax Mixtour tires. Kawasaki describes the tires as emphasizing paved-road grip, a relevant consideration for travelers planning more demanding off-road riding. The SE adds tubeless spoke wheels, allowing suitable tread punctures to be repaired without removing a wheel to access an inner tube.
A motorcyclist in riding gear sits on a stool reading a map next to a parked Kawasaki KLE650 ABS and an orange tent in a grassy clearing.
The standard KLE650 ABS receives a 5-inch LCD instrument panel, smartphone connectivity, and a windscreen adjustable through three positions. A plastic skid plate is standard, while luggage and its mounting equipment are accessories.
Digital instrument cluster of a 2027 Kawasaki KLE650 displaying a neutral gear, zero speed, and various system status icons. First-person view of the handlebars, controls, and digital instrument cluster on a 2027 Kawasaki KLE650.
In addition to tubeless spoke wheels, the SE’s $1,200 premium brings a 5-inch color TFT display, clutchless upshifts and downshifts through Kawasaki Quick Shifter, a USB-C outlet, metal-reinforced hand guards, and an aluminum handlebar. It also receives a larger aluminum skid plate and a windscreen 106 mm taller than the standard version. Compatible navigation and voice-command functions require a separately purchased license, with availability varying by market.
Front view of a 2027 Kawasaki KLE650 motorcycle featuring a tall windscreen, dual headlights, and green graphics. Front view of a gray Kawasaki KLR 650 motorcycle featuring green accents on the side fairing and a spoked front wheel with a disc brake, shown here as a 2027 Kawasaki KLE650.
Close-up of the gray two-tone seat and rear bodywork on a 2027 Kawasaki KLE650.
Kawasaki lists optional panniers, a top case, heated grips, a center stand, engine protection, and alternative seats. The standard model will be offered in Pearl Blizzard White, with the SE available in Pearl Storm Grey or Metallic Bluish Green.
A 2027 Kawasaki KLE650 motorcycle parked on a rocky overlook with a rider sitting on a stone wall nearby, gazing out over a mountainous landscape at sunset.
Scheduled to arrive in February 2027, the standard model carries a U.S. MSRP of $8,799, while the SE starts at $9,999.
kawasaki.com
Read More: Overland News of the Week, October 23, 2026
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland Collective may earn a small commission from affiliate links included in this article. We appreciate your support.
