  • Motorcycle
  • Kawasaki Adds $7,699 KLR650 DF ABS to Its 2027 Adventure Lineup
The Kawasaki KLR is, in the world of adventure vehicles, akin to the classic Land Rover Defender: widely loved, capable, simple, and iconic. Kawasaki seems to take an “if it ain’t broke, don’t fix it” approach to the KLR, and the latest addition follows that philosophy. The company has expanded its 2027 KLR650 lineup with the new DF ABS, a $7,699 variant that adds standard frame sliders, gray bodywork, and black-finished components to the existing dual-sport platform. Positioned between the standard KLR650 ABS and the luggage-equipped Adventure ABS, the new model gives travelers another factory configuration while retaining the existing engine and suspension.
The DF designation stands for Durable Force. Its main distinctions are equipment and appearance, with Metallic Flat Raw Graystone bodywork complemented by black finishes on the rear carrier, suspension linkage arm, brake caliper bracket, axle shafts, and various fasteners. Hand guards and a large rear carrier accompany the frame sliders, which Kawasaki also offers separately as accessories for other KLR650 models. The DF costs $400 more than the standard KLR650 ABS and $500 less than the Adventure ABS in its regular color.
For overland travelers, the announcement represents an additional choice within a familiar platform. The KLR650 retains its fuel-injected, 652 cc, four-valve single-cylinder engine and 6.1-gallon fuel tank. Kawasaki describes the engine’s delivery as focused on midrange performance, with a flat power curve intended to support low-speed off-road riding and highway travel. The manufacturer also identifies cold-weather starting and operation at altitude among the benefits of fuel injection. Its release does not provide a claimed fuel range.
Close-up of a Kawasaki KLR650 front wheel with a spoked rim, knobby tire, and disc brake assembly. Close-up of a Kawasaki KLR650 rear wheel, highlighting the chain drive, sprocket, and knobby tire.
Kawasaki’s published specifications list a 5-speed transmission and sealed-chain final drive. The DF uses a 41mm telescopic fork with 7.9 inches of travel and a Uni-Trak rear suspension system with 8.0 inches of travel, adjustable rebound damping, and adjustable spring preload. It features a 21-inch front wheel and a 17-inch rear wheel, with 8.3 inches of ground clearance. Braking comes from a 300 mm front disc and 240 mm rear disc, with ABS fitted as standard. Kawasaki lists the DF’s curb weight at 471.9 pounds, compared with 460.6 pounds for the standard ABS model.
Close-up of a Kawasaki KLR650 motorcycle seat featuring a rear cargo rack. Close-up of a Kawasaki KLR650 rear section, highlighting the black exhaust pipe, taillight, turn signal, and knobby rear tire.
The touring equipment remains central to the KLR’s appeal. A tall windshield offers two-position adjustment, while rubber-mounted handlebars and footpegs, together with dampers beneath the seat, are intended to reduce vibration reaching the rider. The high-tensile steel, semi-double-cradle frame incorporates an integrated rear frame, and the aluminum rear carrier provides a mounting platform for luggage. Optional side cases and a top case are available through Kawasaki’s accessory catalog.
Electrical capacity is another consideration for riders carrying navigation equipment or charging devices. According to Kawasaki, the 26-amp generator provides up to 80 watts for accessories, depending on usage. An LED headlight and digital multifunction instrument panel are also part of the package.
The remaining 2027 models give buyers several ways to prioritize cost, seat height, or touring equipment. The standard KLR650 and lower-seat KLR650 S both start at $6,999 without ABS or $7,299 with ABS. The S combines lowered suspension with a low seat, revised shifter-to-footpeg spacing, and a shorter side stand. Its 32.1-inch seat height is 2.2 inches lower than the standard model’s 34.3 inches.
The Adventure ABS starts at $8,199 in Metallic Bluish Green or $8,299 in its camouflage finish. Its factory equipment includes side cases, auxiliary LED lights, frame sliders, a tank pad, a DC outlet, and a USB socket. For a traveler who plans to add those items, the $500 difference between the gray DF and the green Adventure merits consideration when comparing complete travel setups.
A dark gray 2027 KLR650 adventure motorcycle with a tall windscreen and knobby tires.
Kawasaki lists availability for the entire 2027 KLR650 range as early December. US base prices exclude destination and other charges. The DF carries a $685 destination charge, bringing its listed price to $8,384 before taxes, registration, options, and dealer fees. Depending on those additional costs, the final bill could approach $10,000. For that investment, buyers get a practical adventure motorcycle with a long-established reputation for durability and the capability to carry them around the world.
kawasaki.com
Read More: Overland News of the Week, September 11, 2026
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland Collective may earn a small commission from affiliate links included in this article. We appreciate your support.
