  • 4WD
  • Ford’s Frostwarden Bronco Showcases a 1,200-Plus-Horsepower Megazilla V8
Yellow and black Frostwarden Bronco off-road vehicle with a roof-mounted spare tire and light bar, parked on a dirt trail.
How much power is too much for off-road driving? The answer depends on the terrain, the driver, and the task at hand. Set practical considerations aside, however, and there is a certain appeal to squeezing as much power as possible from an engine, particularly when the plan involves throwing snow rather than conserving fuel.
Close-up of a mud-splattered black and orange Ford Bronco door featuring a Snow Rescue Recovery decal, a Megazilla 2.0 sticker, and the iconic Bronco logo.
Ford has taken that approach with the Frostwarden Bronco, revealed at the 2026 SEMA Show. Pairing an Arctic search-and-rescue theme with a supercharged 7.3-liter Megazilla 2.0 V8, the concept explores the more extreme possibilities of a modified Bronco. Ford says the engine can produce more than 1,200 horsepower and 1,000 pound-feet of torque, with an important qualification: those figures are based on race fuel rather than ordinary pump gasoline.
Yellow rigid round LED off-road light mounted on the pillar of a dark Ford, with an additional light bar visible across the top of the windshield. Close-up of the front corner of a yellow Ford Bronco featuring a black grille, circular headlight, and a heavy-duty bumper equipped with two rectangular yellow Rigid fog lights.
Close-up of a Ford vehicle’s rear axle, wheel, and suspension components, showing a tire with BFGoodrich branding. A metallic textured Ford Dana 60 automotive differential housing. Close-up of a Ford vehicle’s Bilstein suspension system with a gold-colored shock absorber reservoir and coil spring.
Its equipment includes 42-inch BFGoodrich tires on custom 18-inch Weld beadlock wheels, 74Weld portal gear lifts, upgraded Dana driveline hardware, and custom Bilstein dampers. Ford describes Frostwarden as a demonstration of its crate engine and the work of its engineering and aftermarket partners. The rescue theme provides a setting for the build, rather than confirmation of an operational emergency-service vehicle.
Yellow Ford Bronco off-road vehicle with an extended roof rack carrying storage containers and a spare tire, parked on a rocky trail.
Carbon fiber Ford steering wheel with red stitching and a yellow MEGAZILLA badge. The interior of a Ford vehicle featuring front bucket seats upholstered in two-tone mustard yellow and black quilted leather.
For overland travelers, the project raises a familiar question: how much modification serves the journey? Large tires and portal conversions can be relevant to difficult terrain, but their usefulness depends on the complete vehicle, its intended route, and the compromises an owner accepts. Four-figure horsepower alone offers little indication of suitability for extended travel. Fuel availability, usable payload, service access, and manageable operating costs remain more meaningful considerations when preparing a vehicle for remote journeys. But we are judging this vehicle through a lens of practical travel, where this vehicle is much more about pushing the limits than crossing borders. Frostwarden is, after all, a show concept and will not be offered for sale.
A bright blue Ford Megazilla crate engine installed in a vehicle engine bay. Bright blue Ford automotive engine cover featuring the embossed name Megazilla.
The engine also represents a substantial departure from Ford’s existing naturally aspirated Megazilla. Ford currently lists that 7.3-liter crate engine at 612 horsepower and 670 pound-feet of torque on premium pump gasoline. Its specification includes a cast-iron block, CNC-ported aluminum cylinder heads, forged pistons and connecting rods, and a steel crankshaft. Ford lists peak horsepower at 5,580 rpm and peak torque at 3,920 rpm, with more than 500 pound-feet available between 2,500 and 6,000 rpm.
A yellow and black Ford Bronco parked on a rocky trail in front of a mountain.
That comparison illustrates the scale of the supercharged engine’s output, although the different fuel requirements prevent a straightforward comparison under equivalent operating conditions. Ford’s Frostwarden announcement specifies that its horsepower and torque ratings follow SAE J607 and may not be achieved simultaneously (SAE J607 is an older standard used to rate engine power and torque, including a method of correcting dynamometer results to standard atmospheric conditions).
The latest engine receives a stronger block, revised pistons, larger injectors, a supercharger-specific camshaft, and changes to the belt drive and damper. Boost comes from a 3.0-liter Gen 6 Whipple supercharger. These changes indicate a broader development program than simply adding forced induction to the existing engine.
Rear view of a yellow Ford Bronco on a dirt trail, equipped with a roof rack, cargo cases, a rear-mounted red fuel can, and a coiled red recovery rope.
Megazilla 2.0 itself was announced in January 2025, when Ford projected output exceeding 1,000 horsepower and described it as a competition-use engine for applications such as desert-racing prerunners and drag cars. The same announcement introduced a supercharged 5.0-liter Coyote alternative, then projected to deliver more than 800 horsepower and 615 pound-feet of torque. Ford positioned that engine as the street-legal option, with an available two-year or 24,000-mile limited warranty. Those distinctions matter for builders considering an engine swap: products within the same performance catalog can have substantially different intended uses and installation requirements.
A yellow and black Ford Bronco modified for off-roading, labeled Snow Rescue Recovery on the side, parked on a gravel mountain path.
Frostwarden therefore offers enthusiasts a demonstration of an extreme Bronco conversion, while prospective expedition builders will need to assess their own requirements separately. A show vehicle can demonstrate packaging and fabrication possibilities without establishing the endurance, range, or practicality needed for prolonged travel.
Ford has not supplied a price or an updated ordering schedule for Megazilla 2.0 in the Frostwarden announcement, and the concept Bronco has no retail price because it will not be sold. For comparison, the existing naturally aspirated 612-horsepower Megazilla carries a listed U.S. retail price of $25,295 for the engine alone.
Ford Racing Parts
Read More: Overland News of the Week, October 23, 2026
Our No Compromise Clause: We do not accept advertorial content or allow advertising to influence our coverage, and our contributors are guaranteed editorial independence. Overland Collective may earn a small commission from affiliate links included in this article. We appreciate your support.
