Featured Camper :: Scout Olympic
Scout olympic camper
If you’re looking for a small backcountry camper footprint, then the new Scout Olympic lightweight truck camper might be an ideal solution. This compact, weatherproof shelter has all the basics covered: water, toilet, heat, kitchen, and with its pop-top upper bunk, the Olympic sleeps up to 6 people.
Designed for Adventure
Scout campers were created to allow outdoor enthusiasts to break free from the limitations of conventional RVs and get way out there to remote destinations. Designed for “adventurous families, minimalist travelers, and weekend warriors,” the flagship Olympic truck camper certainly facilitates a quick getaway to the mountains. With its compact design and sensible, modular systems, which are all easily relocated outside of the camper, the Scout is designed for people who like to spend most of their time outdoors.
When the day is done, prep a meal for your crew on the slide-out storage which doubles as a work surface (and have your fridge outside too so perishable ingredients stay fresh and close at hand). Of course, you can also cook inside the camper if the weather doesn’t agree. When you’re ready to sleep, the pop-top hinges open, creating space for two adults (+one kid), while the main cabin of the Olympic has room for three more (two on the dedicated bed and one in the convertible dinette).
Modular Systems for Every Occasion
Perhaps the most unique aspect of the Olympic is its modular systems like the Dometic range, Goal Zero Yeti, or Lifesaver water storage/filter, all of which have been integrated for easy removal so you can take them on other adventures where you don’t need the camper. I’ll admit, I’m a little skeptical as to how many people will actually take advantage of this design element, but in concept, I think it’s a great idea.
K.I.S.S.
I think there is a lot of value in keeping things simple. A gravity-fed water system means no burnt-out pump in the backcountry. And the removable Goal Zero power system and Dometic fridge can easily be removed, upgraded, or repaired without digging into the guts of the camper. The compact cabin is optimized for sleeping, encouraging you to get outside to enjoy the great outdoors (because is sitting inside a camper all day even really living?).
The Value is in the Versatility
With a price tag of just under $20K, this camper isn’t inexpensive, but the value comes from its versatility. It’s lightweight, compact, and sleeps a lot of people giving its diminutive size. The removable systems beg to be taken out of the camper and put to use tailgating or at the lake. The one thing I’m left wanting is a bit more water storage, as the stated 4.9-gallon capacity seems inadequate for anything but the shortest outings. However, there is an add-on option for two Robo Pax 2-gallon water storage containers.
Specs
Base weight: 1,133 pounds
Floor length: 71.2 inches
Interior height: 78.25 inches
Exterior height: 81 inches (w/o opt tent)
Exterior width: 83 inches (w/o opt awning)
COG: 27 inches
Freshwater capacity: 4.9 gallons
Sleeps: 4-6
Amenities
160-watt Renergy Monocrystalline solar panel
4-person dinette with sleeper conversion
Dual 5lb LP Tanks with Vented Compartment
Fire extinguisher
LED ceiling strip lights with built-in switch
Lifesaver portable 4.9-gallon jerry can
Portable Goal Zero Yeti 1000 lithium power station
Smoke, LP, and carbon monoxide detectors
Solar-powered vent with intake/exhaust and light
Stainless sink w/direct exterior drain
Learn more about the Scout Olympic camper, or customize your own at https://www.scoutcampers.com/scoutolympic
Matt is a paragliding pilot and adventure seeker living in Boulder, Colorado. His love of the outdoors has driven him to explore remote destinations across North and South America in search of the most aesthetic peaks and beautiful flying sites. IG: @m.b.swartz
