Grab your CDs, VCR tapes, and favorite grunge shirt, because we’re taking a trip back to the 90s. Not just any trip mind you, but one in this insane off-road camper. It’s called the Revcon Trailblazer, and this part RV/part limo/part yacht is about as close to a modern EarthRoamer as we could get back in those days. Sure, it’s a little ridiculous, but at the same time we can’t help but love it. I mean, it’s got a lift, all-terrain tires, a winch, bathroom, shower, air conditioning, TV, four leather captains chairs, and best of all, only 64,000 original miles! Where else can you find something like that for $45,000? So go ahead, pull out those baggy jeans and lets take a look at this crazy truck.
Although we haven’t seen it in person, this Ford looks to be extremely clean. The interior especially seems immaculate and mostly original. The captains chairs are like new minus some cracking, and the sound system has certainly had an upgrade. The seller clearly states no rust in the ad, and based on the exterior photos I would say that’s probably true. The vehicle shows very little corrosion, and even the headlights appear to be in fantastic shape with no fading.
Given the fact that this is a gas motor, I’d guess that the fuel economy figures are pretty abysmal, but with an 80-gallon tank you could still travel one heck of a distance without issue. You’ve also got 80 gallons of fresh water on board, just in case you’re as thirsty as your truck. Other support systems include two batteries for the vehicle to run on, two deep cycle batteries for the camper, solar panels, and a generator for when things really hit the fan.
Maybe it’s the Texan in me, but I’ve already got a soft spot for this camper. If the Millenium Falcon were an RV, this would be it. We’d just add an ARB or Buckstop bumper to the front, point the truck south, and head for our next dream destination.
Specifications
MAKE: Revcon
MODEL: TrailBlazer
BODY STYLE: Class C
MILEAGE: 64,200
CONDITION: Used
PRICE: $45,000 OBO
FUEL TYPE: Gas
DRIVETRAIN: 4×4
TRANSMISSION: 4-Speed Automatic
EXTERIOR COLOR: White
INTERIOR COLOR: Light Gray
VIN NUMBER: 1FTJW36G2REA00199
EXTERIOR LENGTH: 32 feet
EXTERIOR WIDTH: 96 inches
EXTERIOR HEIGHT: 10 feet, 6 inches
Four-wheel drive
No rust
No smokers
No pets
Regularly serviced
Description From Seller
-Walk-through to coach
-Color-coordinated window draperies
-Pleated day/night shades
-Porcelain sink
-Faucet w/pullout hose, adjustable spray nozzle
-Two-burner stove
-Flush-mount 6-cu. ft. automatic refrigerator/freezer with three-way hookup (AC/DC/LPG)
-Convection microwave oven
-Vintage Color TV with DVD
-Fiberglass molded shower stall
-Adjustable spray shower nozzle
-Three-speed exhaust fan
-Sink and counter located in bedroom for dual use
-Cabinets and cabinet doors constructed of oak with matching Formica trim
-Comfort controls for heat and air conditioning
-TV antenna hookup
-Safety escape window in back
-Built-in air pump system with controls for air bags
-Front off-road shocks
-Pull-out mirrors
-Speed control/tilt steering
-Air conditioning
-Clairon CD player with Sirius satellite radio
-Power locks/windows
-Tag axle with air bag suspension
-Hydro brake boost system for extra braking safety
-Sidewalls constructed of aircraft design
-All joints continuously welded
-Outer skin aircraft aluminum 6061T6 (0.50 think)
-Four leather captains chairs
-Toilet with dual pedal fill and padded seat
-Ford F-350 4×4 Crew Cab (4-door) XLT trim
Also, a full-size, over-the-cab bed (sleeps two people); there is also a second bed in the rear that can be made into a king-size bed, sitting area, or TV room. There is a dining area too that can be made into a bed for a small person or child.
The REVCON 4×4 Trailblazer is state-of-the-art and has been manufactured for the intent to be used in the backcountry and can be used with no hookups. REVCON made sure the Trailblazer 4×4 was all terrain and all season.
-Handles exceptionally well
-Custom box channel frame makes it much more rigid than C-channel designs used in most motorhomes.
-With a lightweight aluminum body, it further improves handling and fuel economy.
-The tandem rear axles reduce rear overhang, so the bumper/trailer hitch won’t drag as much as other RVs.
-Aircraft aluminum was used for the exterior skin, frame, and interior skin. The front and rear caps are fiberglass.
-2-inch, high-density fiberglass insulation makes the walls lighter than in most RVs, easy to clean and nearly impervious to moisture. Other RVs have laminated layers of fiberglass, wood, and foam so any water leaks will quickly rot the wood—NOT REVCON 4×4 Trailblazer!
-The underbelly is totally enclosed and stuffed with 6 inches of fiberglass insulation which also reduces road noise. It makes for a strong, light, efficient, and rigid body that has been placed on the frame of the F350 crew-cab, this rigidity keeps the cabin straight even when the Ford truck frame is bending and intended, when going over uneven terrain. There is also a working winch on the bumper.
-Water tank can hold 80-plus gallons of water. Gray water tank is approximately 25 gallons, and the black tank is 15 gallons.
-The fuel tank holds approximately 80 gallons.
-The propane tanks are under the cabin and can fit 10 gallons of propane.
The water system works in pressure and the pump is brand new (replaced May 1, 2018) and is in excellent working order. The ford truck has two 12- volt batteries and the cabin has 2 deep cycle, 6-volt batteries in a separate compartment. This rig is also outfitted with solar panels. The generator also is in excellent working order.
There were very few of these produced over the years and they are very hard to find on the market. These are sought after by a number of outdoor enthusiasts.
