Wander Voyager – Chevrolet Silverado 6500HD Crew Cab 4×4 :: Premium Feature Vehicle
Wander Voyager Chevy 6500HD
Based in La Verne, California, Wander Voyager is on a mission to create the ultimate luxury expedition vehicle. A disruptor to the segment, the company seeks to redefine vehicle travel with builds that seamlessly blend backcountry ruggedness, capability, and autonomy with class-leading interior comfort and technology. With this in mind, cue the Wander Voyager 6500 (seats 5/sleeps 4), which is the company’s flagship model “for those who crave comfort without compromising capability.”
Wander Voyager Chevy 6500HDThe foundation is a 2024 Chevrolet Silverado 6500HD Crew Cab 4×4 (3,xxx miles), which in all respects is a truck engineered from the factory for heavy commercial applications with a body-on-frame architecture, 4WD, solid axles, a considerable payload and towing capacity, and a powerful Duramax V8 diesel. This pinnacle full-size is then uprated with top-tier parts and accessories to optimize it for the road less traveled, including Kelderman air suspension, super single wheels with Continental MPT tires, armor, and a winch. This fit-for-purpose platform is mated to a composite habitation box that delivers exceptional strength and four-season comfort, thanks to a unique manufacturing process. It boasts 5-layer (full details here) 3.2-inch-thick composite walls bonded with glue and screws, premium XPS insulation, and wood studs between composites for added strength and to bear the weight of furniture/appliances. The result is a thermally efficient living cell that’s suited to the rigors of all-season international exploration, and serves as the perfect canvas for its marine-grade interior. Featuring teak wood floors, bespoke cabinetry, and brushed aluminium trim, it’s more akin to a luxury studio apartment or yacht than an expedition truck, ensuring that wherever you are in the world, you’re home.
Wander Voyager True off-grid freedom requires a rig to be self-sufficient, and to this end, the 6500 boasts generous amenities and redundancy to enable the ultimate autonomy when camping off-grid. A large lithium house battery system is supported by 2,600 watts of solar, 100 gallons of freshwater with multi-stage filtration and on-demand heating, climate control, and much more. It’s also worth noting that despite all of the above, this expedition goliath, when packed for adventure and brimmed with fuel and water, weighs in at 19,000 pounds, which is well within the chassis GVWR of 23,500 pounds. Finally, while this is not a budget rig, it’s almost half the price of comparable builds within the segment. So if you’re in the market for a turnkey, no-expense-spared expedition truck for adventures at home and abroad, look no further.
From the Seller:
“At Wander Voyager, we build premium expedition vehicles designed for comfort, durability, and freedom. From the rugged chassis of Isuzu and Chevy trucks to the refined living space inside, each camper is engineered for long-distance travel and all-season adventure. With thick insulation, residential-style climate control, and oversized solar and battery systems, our builds ensure you’re always ready to go—off-grid, off-road, and off-script. To this end, our flagship 6500, built on the powerful Chevy 6500HD 4X4 chassis, is designed for those who crave comfort without compromising capability. With rugged strength, refined interiors, and off-grid readiness, it’s the perfect home on wheels for bold, long-haul adventures.”
Wander Voyager
Chevy 6500HD
Chevy 6500HD
Chevy 6500HD
Wander Voyager
Wander Voyager Chevrolet Silverado 6500HD Crew Cab 4×4
The 6500HD is powered by a 6.6-liter Duramax turbo-diesel V8 that produces 350 horsepower and a considerable 750 pound-feet of torque; it’s mated to an Allison 6-speed automatic transmission (range provided via 65 65-gallon fuel tank). An exceptionally powerful motor is matched with impressive capability thanks to 4WD, high and low range, armor, a lifted and uprated suspension, super single wheels, a winch, solid axles, manual locking front hubs, and a rear Trac-Lok limited-slip differential. Inside these rugged backcountry attributes are balanced with driver comforts that include:
  • Climate control
  • Running boards
  • Multi-function steering wheel
  • Infotainment system with navigation
  • USB and 110-volt outlets
  • Keyless entry
  • Power steering, windows, and locks
  • Powered and heated seats
  • Auxiliary upfitter switches
Wander Voyager 6500
Wander Voyager 6500
Wander Voyager 6500
Wander Voyager 6500
Expedition truck for sale
Wander Voyager Distinguishing Features
The build specifications on this vehicle are extensive; below is a selection of notable features. Contact Wander Voyager for full details.
  • Composite habitation box with 3-inch thick XPS walls (learn more here), bi-ply residential quality glass, keyless insulated entry with deadbolt, and powered/drop-down entry steps
  • Super single wheels with 40-inch Continental MPT tires rated to 70 mph (5)
  • Premium marine-grade interior with brushed aluminum trims, teak wood floors, and ambient LED lighting
  • Exterior lockers (5) and additional insulated storage accessible from outside
  • Kelderman air suspension
  • Kelderman front bumper with Warn 16.5 TI-S winch and LED lighting
  • House battery system with dual 15-kilowatt-hour batteries (2), 3,000-watt inverters (2), multiple power outlets, 2,600 watts of solar, control panel/monitoring, residential-style electrical distribution panel providing individual breakers for each circuit
  • Winterized stainless steel freshwater tank, 100 gallons, with 8.5-gallon electric water heater, 43 gallons graywater, 23 gallons of blackwater
  • Climate control with residential-style split air conditioner (can also provide heating), 12,000 BTU, and 5,000-watt diesel heater
  • Awning
  • Rear spare tire rack, 1,000-pound capacity (this means a bicycle or lightweight motorcycle can be mounted in addition to the spare wheel)
  • Bathroom with macerating toilet, large sink, towel heater, mirror with integrated lighting, walk-in shower with 2-way faucet/shower head (and exterior spray port for outside use)
  • Kitchen with stainless steel sink (with integrated basket and cutting board), Empava electric induction cooktop (can be removed for cooking outside) with ventilation hood, and Toshiba microwave oven and air fryer combo
  • Indel convertible 75-liter fridge/freezers (2)
  • Queen-size over-cab bed with reading lights (2), power outlets, and storage built into access stairs
  • Dinette with adjustable table that converts to sleeping area
  • Exterior cameras with interior monitor
Duramax motor
Wander Voyager 6500HD
Wander Voyager This Wander Voyager – Chevrolet Silverado 6500HD Crew Cab 4×4 is listed for $568,000 and is currently located in La Verne, California. Check the full vehicle specifications via the original listing
Contact Information:
Email: w.sun@wandervoyager.com
Tel: 657-395-7760
Website: wandervoyager.com
Instagram: wandervoyager_official
Chevrolet 6500 HD
Chevrolet 6500 HD
Chevrolet 6500 HD
Chevrolet 6500 HD
Chevrolet 6500 HD
Wander Voyager
Wander Voyager
Chevrolet 6500 HDLearn more about this Wander Voyager – Chevrolet Silverado 6500HD Crew Cab 4×4
