The Ford F-250 Tremor is undoubtedly one of the most desirable full-size platforms for overlanding. In 2022 we awarded it Full-Size Truck of the Year with Expedition Portal and Overland Journal’s Chairman and Publisher Scott Brady stating: “The Tremor won the Editor’s Choice because it delivers on everything we need a full-size truck to be: capable and durable, with the payload to haul any reasonable overland load or camper.” In terms of capability, only Ram’s Power Wagon was a match for the Tremor but was eclipsed in other key areas such as the ability to specify the latter with three times the payload. It’s a vehicle that from the factory is outfitted with just about every attribute required for rugged backcountry adventure. Highlights include Warn winch, high-clearance front bumper, rear locker, limited-slip front differential, 2-inch lift, sliders, and much more. Crucially, these upgrades are not simply bolt-on accessories but have been carefully evaluated and approved by Ford as being both safe and optimal for the F-250. Needless to say, it’s one of if not the ultimate full-size platform for overlanding and today’s offering is a testament to this statement. This super low-mileage (12,900 miles) 2022 F-250 is in many ways the ultimate Tremor build. Showcasing Ford’s “Godzilla” motor, desirable factory options, extensive premium aftermarket upgrades, and a top-of-the-line fully-equipped camper. If this wasn’t enough it was built with the expertise of Basil Lynch (a.k.a. Basil’s Garage), whose exceptional overland vehicles are regularly featured on our website. This rig is better defined as an “expedition” rather than an “overland” build due to the huge list of amenities and comforts and is priced accordingly. If you’d like to understand the merits of exped builds then listen to Principles of Overlanding :: Expedition Campers on the Overland Journal podcast.
From the Seller:
“These opportunities do not come around very often. This is a turnkey expedition vehicle based on a 2022 Ford F-250 Super Duty Tremor (with the Lariat Ultimate Package) carrying a highly modified Mits Alloy flatbed and features a nicely upgraded, high-end Supertramp Flagship LT camper. The eye-catching design of this entire vehicle is unique and confidently reflects its capabilities. The entire build was put together with the idea of extensive off-road travel and going to places not easily accessible – all while bringing luxury and certain creature comforts along for the ride. There is nothing else to figure out – it has been done for you, tested out in the wild, and then further improved. Scared of fuel range issues? Rest assured, the upgraded 58-gallon tank takes the range anxiety out of the mix. Air Conditioning to keep your pets safe while out on a day hike? Check. Shower and toilet? Check. Satellite Internet? Yep, it’s got that as well. The list of features, functionality, and amenities is long – as you would expect for a well-thought-out expedition vehicle. All parts and components are of high quality. The Ford Super Duty platform is known for its strength and durability, while the 7.3-liter Godzilla engine has been designed by Ford for longevity and is easy to service and maintain. The Supertramp camper is top-of-the-line; made from composite material in a highly sophisticated building process (vacuum-infused carbon fiber reinforced shell). Putting an expedition vehicle together requires a vision but also a team that can make it a reality. All the heavy lifting a.k.a work has been done by Basil and his crew at Basil’s Garage here in Vista, CA (San Diego). Lifting the truck by installing the high-end Carli Pintop suspension – yep, done by Basil’s Garage. Upgrades to the solar and electrical system? Same. The list goes on and on. The idea behind this build is to provide full off-road capabilities and get you deep into the backcountry, up and down steep mountains, conquering rugged terrain as if it were the road to the country club. This rig has everything you need for long-term travel and allows you to stay off-grid for an extended amount of time. Your limits are food, trash, and dirty laundry.”
2022 Ford F-250 Tremor
The F-250 is fitted with the 7.3-liter “Godzilla” gas motor that produces 430 horsepower and 475 pound-feet of torque. A powerful engine is mated with class-leading capability courtesy of 4WD, high and low range, rear locking differential, front limited-slip differential, vented differential for water fording, 2-inch factory lift (since increased), rock sliders, high clearance front bumper, winch, and intelligent systems such as hill descent control, off-road cruise control, trail turn assist, and more. These rugged credentials are balanced with an exceptionally well-equipped interior with driver comforts that include:
- Heated, cooled, and powered leather seats
- Panorama moonroof
- Heated steering wheel
- LED headlights
- Rain sensing wipers
- Infotainment system with navigation, 12-inch screen, and Sirius satellite radio
- Console Vault
- Wolfbox G930 4K rearview mirror
- Premium 10-speaker B&O audio
- Tinted windows
- Climate control
- Cruise control
- Builtright Industries center dash mount with 12-volt outlet
- Remote start
- Off-road 360-degree cameras
Distinguishing Features
This is a high-end build with extensive upgrades. Below is a list of notable features but we suggest referencing the original listing linked below for further details.
- Method Race Wheels 305 NV-HD with Falken Wildpeak AT III tires
- Carli Pintop 2.5-inch lift suspension and rear XHD leaf spring pack, Hellwig sway bar, and Firestone airbags
- Mits Alloy EVO aluminum flatbed with Mule Expedition upper storage, 8-gallon water tank with spigot, lower storage boxes, and custom mounts for blind spot monitoring and parking sensors
- ARB Twin-Compressor with Viaair 2.5-gallon tank
- Battleborn heated lithium batteries 400-amp-hour, 1,500-watt inverter, 660-watts of solar, and two Redarc BCDC1250D controllers
- Supertramp Flagship LT camper (2023)
- Freshwater, 24-gallon, with Acuva ArrowMax 2.0 water filtration
- Dometic RTX 2000 air conditioning with remote and Truma Combi Eco Plus heater
- Starlink high-performance in-motion satellite dish
- Trelino EVO M toilet and inside shower
- Morimoto and Diode Dynamics lighting
- Sherpa Thunder roof rack
- TransferFlow full-replacement tank, 58-gallon
- Maxxair Deluxe 7,500K fan with remote
- Ford Performance Warn winch
This 2022 Ford F-250 Tremor with Flatbed and Supertramp camper is listed for $195,000 and is currently located in Vista, California. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information
Email: netservicesusa@gmail.com
Tel: 303-525-5059
Instagram: dtadventure4x4
