2007 Ford E-350 Sportsmobile 4×4 V2.0 :: Featured Classified
Ford E-350 4x4
The E-350 has been in production for almost 60 years, which makes it Ford’s second-longest-running nameplate. During this time, it has remained in a constant state of evolution, with each iteration more dialed than its predecessor. With its range of powerful and long-lived engines, impressive payload, comfortable interior, and wide array of chassis/body styles, it’s a beloved commercial vehicle and a figurehead of both the vanlife and overlanding revolutions. It’s ideally suited to travel since it provides generous interior living space within a relatively modest external footprint, and thanks to almost unparalleled aftermarket support, it can be totally transformed from a 2WD workhorse into a legitimate 4WD expedition platform. The ability to upfit the chassis with a heavy-duty 4WD system, high and low range, solid axles, a lifted suspension, and even front and rear lockers ensures the E-350 is in a league of its own compared to other AWD vans within the segment. To this end, cue today’s 2007 Ford E-350 Sportsmobile (157,700 miles on a chassis/engine rebuilt and bulletproofed at 79,232 miles), which has been completely reimagined from the ground up (73,468 miles on rebuild) for backcountry exploration. Today’s seller, an active member of the community, realized that while the Sportsmobile served as a comfortable camper, it was not suitable for the rigors of overlanding. Subsequently, they endeavoured to build the ultimate Sportsmobile i.e. “V2.0,” and the result is exceptional. This well-appointed rolling home comprises a custom interior with welded frame cabinetry for optimal strength, a large house battery system, 25 gallons of freshwater with dual-stage filtration, dual fridge/freezers, climate control, and much more. If you’re in the market for a turnkey four-season-ready overland rig that’s built for off-grid domestic and international travel, look no further.
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 4x4From the Seller:
After a test trip to Baja in the stock Sportsmobile, I quickly realized it wasn’t built for real-world overlanding. Cabinet joints failed on washboards, wall panels were coming down, and the suspension was inadequate for anything beyond campgrounds. So, I stripped it down to the bare chassis and rebuilt it to be a true expedition platform—built for self-sufficiency in any terrain, any climate, and any country. Meet version 2.0, a complete ground-up professional rebuild with a focus on reliability and long-term serviceability. It’s not new anymore, but it’s incredibly well cared for, always stored indoors, and has been exceptionally reliable. If someone handed me a gas card and said, ‘Go drive the Pan-American,’ I’d leave tomorrow without a single modification. Ready to drive around the world. Title in hand. No trades.”
Ford Sportsmobile
Ford Sportsmobile
Ford Sportsmobile 2007 Ford E-350 Sportsmobile 4×4
The E-350 is fitted with a “bulletproofed” 6.0-liter Power Stroke diesel motor producing 235 horsepower and 440 pound-feet of torque (range provided via 46-gallon tank). An exceptionally long-lived engine and drivetrain is matched with impressive capability thanks to a heavy-duty 4WD system, Atlas II 2-speed transfer case, Dana 60 front and Dynatrac ProRock 80 axles, front and rear ARB air lockers, Yukon 4.10 gearing, a lifted and uprated suspension, detachable front sway bar, dual winches, and manual locking front hubs. Inside, these rugged backcountry attributes are balanced with driver comforts that include:
  • Captain’s chairs
  • Air-conditioning
  • Multi-function steering wheel
  • Cruise control
  • Power steering, windows, locks, and mirrors
  • USB and 12-volt outlets
  • Aftermarket stereo
  • Cup holders
  • Overhead switch panel
  • Premium aftermarket audio
  • Viper alarm
Ford E-Series
Ford E-Series
Ford E-350 4x4Distinguishing Features
See the original listing for full specifications. Below is a selection of notable highlights:
  • Custom interior with welded frame cabinetry, bamboo inlays, custom upholstery, full sound deadening and insulation, new wiring and plumbing, and electric actuators for pop-top
  • Deaver HD suspension and Bilstein shocks
  • Two sets of wheels; Hutchinson 2-piece bead locks with Toyo M/T tires (5) and Method HD wheels with Goodyear Duratrac tires (5)
  • Aluminess front bumper with Superwinch and rear bumper with Warn winch, swing-out tire carrier, and storage box
  • Extreme Outback air compressor
  • Duracell 4D wet-cell house batteries (600 amp hours total), Zamp solar (380 watts), TrippLite inverter (2,000 watts), Blue Sky energy MPPT controller, 120- and 12-volt outlets, and IBS dual-battery-management system with in-cab display
  • Freshwater (25 gallons), with dual-stage filtration and insulated for cold weather
  • Cassette toilet
  • Aluminess roof rack
  • Rigid Industries and Hella lighting
  • Outdoor shower with curtain
  • Big Brake kit
  • Climate control with Espar hydronic diesel heater with Rixen controller and fan heat exchanger
  • Isotherm 130-liter drawer fridge/freezer and ARB fridge/freezer
  • Underbody 25-pound propane tank with two exterior ports
Sportsmobile E-Series
Sportsmobile E-Series This 2007 Ford E-350 Sportsmobile 4×4 V2.0 is listed for $125,000 and is currently located in Big Sky, Montana. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 4x4 Learn more about this Ford E-350 Sportsmobile 4×4 V2.0
