2021 Ford E-350 4×4 Field Van Classic :: Featured Classified
Field Van Classic
This remarkable rig was engineered from the ground up by industry legends, Field Van. The company, founded in 1989, has been building adventure-ready campers for over 30 years, and their flagship Ford Classic 4×4 is truly a masterpiece. Despite appearances, it’s far from a standard Ford E-350. They begin with a Ford E-350 cut-away chassis and convert it from 2WD to 4WD using a proprietary 4×4 system. From here, they add a custom fiberglass steel cage-reinforced body that is 4 inches wider and 4 inches taller than the original Econoline, yet at a glance looks completely standard. This bespoke habitation box, combined with a pop-top roof, creates a generous interior living space well-appointed for long-term trips or full-time living. The specifications for this build are extraordinary and documented in this Google Doc. It’s in a different league to the 4WD Sportsmobiles and similar we’re accustomed to seeing, and is better understood as a scaled-down luxury expedition camper. Amenities include a large house battery system, 15 gallons of freshwater with on-demand hot water, 4-season climate control, a bespoke camper interior, considerable interior and exterior storage, and redundancy built into all systems. At $225,000, it’s less than some off-the-shelf Sprinter AWD camper conversions and provides key advantages. The seller provides a full breakdown of costs, indicating that new, this vehicle would set you back $275,000 with an 18-month lead time (not including the $25,000 in post-build upgrades). With just 37,000 miles, this $300,000 build is barely run in and would serve as the perfect international travel companion or rolling home for the upcoming season.
Field Van Classic
Field Van Classic
Field Van Classic
Field Van Classic
Ford E-350 overland
E-350 overland
overland trucks for sale
From the Seller:
Meticulously cared for one-owner vehicle. Recently designed Field Van Classic 4×4 S1 floor plan loaded with options. The original owners put 37,000 miles on the 2021 Classic in four years and were on the road camping out of it 50 percent of the time. They will miss their van and the adventures it brings; however, they are moving to a larger expedition-style, off-road RV. The 5-year warranty ends May 2026. Subsequently, $265,000 gets you on the road in a $300,000, fully optioned-out, awesome rig. The van has been returned to the factory at least once a year for inspection, a maintenance check, and re-torquing of suspension fasteners to the specified torques. Regular service has been performed, including fluid changes, tire rotation, and maintenance of the water and heater system. Receipts and service records are available for interested buyers.”
Ford E-350
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 overland
E-350 overland
Field Van Classic
The E-350 is fitted with a 6.8-liter V10 that produces 205 horsepower and 420 pound-feet of torque, mated to a Torqshift 6-speed automatic transmission (with selectable tow/haul for ascents/descents). A powerful and long-lived motor is matched with impressive capability thanks to a heavy-duty 4WD system, rated recovery points, high and low range, manual locking front hubs, a lifted and uprated suspension, manual locking front hubs, front and rear ARB lockers, Dana axles, armor, and a sway bar disconnect. Inside these rugged attributes are balanced with a well-equipped interior with driver comforts that include:
  • Heated Scheel-Mans seats (passenger side swivels)
  • Air-conditioning
  • Yaesu FTM-400DR radio with high-gain external roof antenna
  • Premium Kenwood stereo and speakers
  • GTR LED headlights
  • Compustar alarm with three keyfobs and Ravelco and LoJack anti-theft devices
  • Fiamma side sun shades
  • Driver side coded keypad
  • Havis dash mount combined with MyGoFlight tablet mount
  • Scan Gauge 3
  • Tire Minder A1As tire pressure monitoring system
  • Rolef windshield kit
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 4x4
Ford E-350 4x4
Ford E Series overland
E-350 overland
Field Van Classic
Distinguishing Features
The specifications for this build are extensive and meticulously documented here.
  • Field Van custom steel and fiberglass body with electric pop-top roof, Arctic Penthouse insulated curtains and top bed
  • AGM house batteries (420 amp-hours) with battery monitor, Zamp solar (230 watts plus 400 watts of remote panels), Magnum inverter (2,800 watts), 12-volt/USB outlets
  • Truma Air propane/110-volt furnace and water heater, onboard propane (Extend-A-Stay adaptor), Danhard air-conditioning, extreme weather insulation
  • Freshwater (15 gallons)
  • Aluminess front bumper with Warn 12,000-pound winch, rear bumper with built-in storage, rear swing-aways with Deluxe box, spare wheel, expedition kit, and 1UP bike racks (2)
  • Fiamma awning with sun shade adapters and center rafter
  • ExtremeAire Magnum air compressor with 2-gallon tank and air up/down tool kit
  • Starlink Mini and Insty Connect dual SIM card cellular mobile router
  • Aluminess roof rack with LED utility lights and 50-inch Rigid Industries light bar, front cab rack, and side ladder
  • Field Van lockable XL storage box on the floor of the chassis
  • Aluminess Nerf Bars
  • Method 305 NV Race wheels with BFGoodrick KO3 tires (upgraded F-550 brakes)
  • Lifted suspension (6 inches), Dynatrac ProRock 60 front axle and factory Dana 70 full float rear axle, with custom Bett’s springs, Fox shocks (and steering stabilizer), and Sumo springs
  • Geyser shower system and outside shower with hot/cold water
  • Kitchen with sink (hot and cold water), Diva cabinets, Isotherm Cruise 130-liter refrigerator with intelligent remote temperature control, Lagun table, Jetboil Halfgen camping stoves
E Series overland
E Series overland
E Series overland
E Series overland
Ford E-350 overland
Field Van Classic
This 2021 Ford E-350 4×4 Field Van Classic is listed for $225,000 and is currently located in San Jose, California. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Email: emmettdonohue@gmail.com
Ford E-350 overland
Ford E-350 overland
Ford E-350
Ford E-350
Field Van Classic
Field Van Classic Learn more about this 2021 Ford E-350 4×4 Field Van Classic
