2024 Toyota Tacoma Trailhunter w/ Go Fast Camper V2 Pro :: Featured Classified
The Toyota Tacoma continues to dominate the mid-size category, and for good reason. From the factory, it boasts class-leading reliability, build quality, and capability, and is a truck you can depend on whatever the climate or terrain. It’s beloved by the overlanding community and has been a figurehead of various Overland Collective expeditions. Toyota has taken note and continued to evolve its out-of-the-box overland packages, with the fourth-generation flagship model being the coveted Trailhunter. This iteration was co-developed with industry leader ARB and is highly specialized for overlanding. Highlights include a rear locking differential, stabilizer disconnect, tuned suspension, armor, recovery points, heavy-duty bumpers, high-mount air intake, intelligent assists, and more. In short, this is a pinnacle option for long-distance, self-support, overland travel. To this end, cue today’s one-owner, low-mileage 2024 Toyota Tacoma Trailhunter (20,216 miles), which showcases a plethora of premium aftermarket modifications and is topped with a well-appointed Go Fast Camper V2 Pro. This rig was professionally assembled by industry leaders such as Wicked Creations (suspension and chassis), Zero Declination (lighting), Go Fast Campers (camper and storage), and is dialed for rugged exploration. It’s been meticulously maintained with comprehensive Toyota dealer service history and is sold with a transferable 10-year/100,000-mile factory powertrain warranty.
Tacoma overland build
Toyota Tacoma Trailhunter From the Seller:
For sale is my 2024 Toyota Tacoma Trailhunter, thoughtfully built as a reliable, self-sufficient expedition vehicle for extended travel, backcountry hunting, and family camping. The guiding philosophy behind this build was simple: maximize capability while preserving Toyota’s factory engineering, reliability, and long-term serviceability. Every modification was selected because it solved a specific problem—not because it looked good in a catalog. Whenever possible, I chose components that utilized factory mounting locations and avoided irreversible modifications to the truck. The engine, transmission, transfer case, and drivetrain remain completely stock, preserving Toyota’s transferable 10-year/100,000-mile factory powertrain warranty. The truck has been professionally built by some of the most respected names in the overland industry. Components were installed correctly the first time, and the vehicle has been meticulously maintained throughout ownership. This truck has taken my sons and me on unforgettable trips from Minnesota through Nevada and California, exploring deserts, mountains, national parks, and remote backcountry. It has performed exactly as intended and has never left us questioning its reliability. I’m only selling because my business and family no longer leave me enough time to use it the way it deserves. I have documentation, receipts, installation information, and maintenance records for the build and am happy to answer detailed questions about any component. Serious buyers are welcome to reach out for additional photographs or specific information.”
Trailhunter overland
Trailhunter overland 2024 Toyota Tacoma Trailhunter
The Tacoma is fitted with an i-Force Max 2.4-liter turbocharged hybrid motor that produces 326 horsepower and 465 pound-feet of torque and is mated to an 8-speed automatic transmission. A powerful engine is matched with class-leading capability thanks to 4WD, high and low range, a lifted and uprated suspension, armor, an electronic rear locking differential, front stabilizer bar disconnect, and intelligent on-board assists such as A-Trac, Multi Terrain select, Crawl control, Hill Start Assist, Downhill Assist, and a panoramic monitoring system. These rugged attributes are balanced with driver comforts that include:
  • Powered, heated, and ventilated seats
  • Dual-zone climate control
  • Heated steering wheel
  • Infotainment system with navigation (14-inch screen)
  • Premium JBL audio with integrated portable Bluetooth speaker
  • QI wireless charging pad, multiple USB-C ports, 120-volt power outlet
  • Smart key system with push-button start and remote start capability
  • Rearview camera and reverse sensors
  • Power sliding rear window
  • Heads-up display
  • Adaptive cruise control
  • Wi-Fi hotspot
  • Automatic emergency braking, Lane Departure Assist, Blind Spot Monitor, and Rear Cross Traffic Alert
Toyota overland build
Toyota overland build Distinguishing Features
  • Go Fast Camper V2 Pro with insulated roof, interior LED lighting, powder-coated MOLLE panels, removable mattress covers, flush-mounted L-track, Freedom Coast tie-down system, and telescoping ladder
  • WC Manufacturing long-travel suspension, King 2.5 remote-reservoir coilovers, bypass shock hoops, heavy-duty rear control arms, cam gussets, King sway-bar disconnects, forged CV shafts, Dobinsons heavy-duty rear springs, and heavy-duty panhard bar (approximately 3.5 inches wider track width per side)
  • Relation Race wheels with Toyo Open Country R/T tires
  • Baja Designs lighting with OEM Toyota auxiliary switch integration
  • C4 Fabrication low-profile front bumper with Warn VR Evo 12S synthetic rope winch (and Agency 6 recovery shackle) and Expedition One dual-swing rear bumper with fuel/water can carriers and Hi-Lift jack mount
  • Premium custom wrap and ceramic-coated exterior
  • Battle Born lithium battery system with Victron DC-DC charger, 525 watts of Renogy solar, Victron SmartSolar MPPT controller, monitoring system, Blue Sea Systems power distribution, Anderson Powerpole connections, heavy-gauge marine wiring, and Starlink Mini pre-wire (everything is professionally wired, fused, labeled, and designed for serviceability)
  • Espar gasoline heater
  • National Luna NL70 dual-zone refrigerator/freezer on drop-down slide-out
  • Custom CAD-designed and CNC-manufactured drawer and kitchen system (full details here
  • Integrated water storage
Toyota Tacoma 4x4
Toyota Tacoma 4x4
Toyota Tacoma 4x4
Toyota Tacoma 4x4This 2024 Toyota Tacoma Trailhunter is listed for $95,000 and is currently located in Saint Louis Park, Minnesota. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Email: [email protected]
Want to sell your vehicle? Contact us: [email protected]
Trailhunter overland build
Learn more about this 2024 Toyota Tacoma Trailhunter w/ Go Fast Camper V2 Pro
