  • Gear
  • The Boxo USA Off-Road Tool Bag and Tool Set
Image credits to Alex Zappile
An overland vehicle is not complete until it is equipped with a full set of high-quality tools. It is when you are stranded beside the trail, far from assistance of any kind, that you will fully appreciate the investment in quality. But, often, tool boxes are heavy and cumbersome; they take up too much space and can be difficult to pack and access.
The 80-piece Boxo USA Off-Road Tool Bag and Toolset are designed for those traveling outdoors, hence the name. It weighs a mere 31 pounds and contains professional-grade tools that come with a claimed no-hassle limited lifetime warranty. The tool bag includes a 61-piece tool roll, an 80-piece metric tool set with the most useful tools for most applications, plus five removable tool bags containing pliers, hammers, a pry bar, tire repair kit, electrical test and repair items, and a universal bag for your other favorite items and tools. With the addition of your own vehicle-specific tools, this tool set may be as useful in your garage at home as it would be out on the road.
The bag is stitched from high-quality Cordura nylon to ensure your tools stay organized and rattle-free on your journey. For ease of use, there are heavy-duty zippers on the outer tool bag. With the outside MOLLE webbing system, it is ideal for securing additional items to the exterior of the bag, and the compact size of the tool bag makes it perfect for storing when you have limited space.
The outer bag contains 19 individual tools and utilizes heavy-duty zippers for added security and ease of use, while the inner tool roll, which contains 61 individual tools, utilizes tool pouches and flaps for secure tool storage. The five inner removable tool bags are secured via hook and loop mounting; the Boxo USA off-road tool bag’s dimensions are 19.68 x 13.58 x 6.77 inches and is designed with ample space to add more of your own personalized items.
The tool set includes:
  • 12-point combination wrenches, 8, 10, 12, 13, 14, 15, 16, 17, 18, 19mm
  • 3/8-inch 12-point, standard sockets, 8, 9, 10, 11, 12, 13, 114, 15, 16, 17, 18, 19mm
  • 1/2-inch drive 6-point standard impact sockets, 16mm and 18mm
  • 2-inch drive 6-point wheel impact sockets, 17, 19, 21mm
  • 1/2-inch drive 6-point standard impact sockets, 33mm and 35mm
  • 3/8-inch ratchet
  • 1/2-inch ratchet
  • 1/2-inch breaker bar
  • 9-piece metric hex wrench set
  • 9-piece Torx key wrench set
  • Ball-peen hammer
  • Dead-blow hammer
  • Heavy-duty diagonal side cutter
  • Flush-cut pliers
  • Groove-joint water-pump pliers
  • Long-nose pliers
  • Combination pliers
  • Curved-jaw-locking pliers
  • Wire cutter, wire stripper, and crimper tool
  • Phillips screwdriver #2
  • Flat screwdriver, 100mm
  • 1/4-inch drive spinner handle
  • 1/4-inch spinner handle drive with ¼-inch drive, 5/16 socket
  • Adjustable wrench
  • 8mm pin punch
  • 12- and 42-volt compatible circuit tester
  • 6 3/8-inch drive medium extension
  • 5 1/2-inch drive impact extension
  • Extendable pry bar
Available at www.boxousa.com
