Tank Trap Trail, Santa Fe NM
Tank Trap Trail NM
This is a very new trail that sees a great deal of water, with deep standing pools and mud bottoms. The approach to the first obstacle requires driving through the mud, soaking the tires before an attempt to traverse the very cambered shelf. There is apparently a more direct approach, but it was under several feet of water.
    Tank Trap Trail NM 4 Wheel Drive Tacoma
    1. The approach
    2. This picture shows the angle of the shelf starting the climb
    Tank Trap Trail NM
    3. The start of the climb with wet tires made the truck want to shift towards the water
    Tank Trap Trail
    4. As the rear tires climb up the ledge shown, the truck approached a 25 degree tilt.  Still safe, but interesting nonetheless…
    Tank Trap Trail NM
    Tank Trap Trail
Overall the obstacle was a great cambered challenge, made slightly complicated by wet tires on smooth rock. After the side tilt, I turned down towards a narrow ledge that leveled the truck out and led to the exit up the canyon, and on to more of the trail.
Tank Trap Trail NM
After the shelf we came across a deep, muddy trench that blocked access to the rest of the trail. The water was so muddy that we could not make out the depth of the water or the size (and location) of any rocks below. At the point this picture was taken the front tires were on the edge of a rock or shelf. Moving forward even slightly, I felt the front end start to go deeper, causing the exhaust to hiss against the water in response. It was time to turn around…
Tank Trap Trail NM
Tank Trap Trail NM
Tank Trap Trail NM
We had to go back across the shelf, but this time the front of the truck was pointing down hill. Everything went fine until the last section when a wet tire slid off of the ledge and unsettled the truck. I just let off of the brakes and allowed the truck to straighten out and turn towards the decline. If I had hit the brakes the truck might have rolled. I was prepared to even hit the gas to right the vehicle if it had started to go over. It was an unsettling, but brief moment, and the truck was at the bottom safe!
Tank Trap Trail NM
While I was in the area, I also took advantage of the fall colors, which were at their peak!
Tank Trap Trail
Santa Fe, NM looking towards Aspen Peak
Tank Trap Trail
The Rio Grande towards Taos
Tank Trap Trail
NE of Taos along the Rio Pueblos de Taos
Trip Details
    Date: 10/22/2004
    Trail Time: 2-3 hours
    Location: Just west of Santa Fe, New Mexico and Ortiz Mountain. The route to access the trail starts just NW of Hwy 22 and Agua Fria Park. Use gps coordinates and track as there are many side roads.
    Trail Rating (1-5 scale): 3- There are some good challenges on this trail, made even more difficult by the deep water and cambered approach. We did not complete the trail due to the deep, muddy water (which made spotting impossible) and having only one vehicle. However, it was still very fun.
    Under dry conditions this trail would likely be a 2.5, but would still require good clearance.
    Major Obstacle: The cambered start of the trail could be a problem with novice drivers due to the wet conditions (tire slip)
    Brush (minor, moderate, severe): Moderate
    Scenic Value (1-5 scale): 3- Nice canyon bottom
    Attendees:
    Scott Brady- 2004 Toyota Tacoma
    Chuck
Trip Planning
    Santa Fe Information:
Scott is the publisher and co-founder of Expedition Portal and Overland Journal. His travels by 4WD and adventure motorcycle span all seven continents and include three circumnavigations of the globe. His polar travels include two vehicle crossings of Antarctica and the first long-axis crossing of Greenland. He lives in Prescott, Arizona IG: @scott.a.brady Twitter: @scott_brady
