Overland Classifieds :: 2015 Ford F-250 4×4 FX4 CrewCab Diesel
The “perfect” overland vehicle doesn’t exist, and what works for one owner may not work for the next. Hence, you could spend a fortune on a fully built-out camper and still come to realize that you need to completely reconfigure the layout to suit your needs. Only when you start traveling will you discover what works for you, and that can take years of fine-tuning! A truck is the perfect blank canvas for configuring your home on wheels because it’s completely modular and can be set up with a roof tent, canopy, camper, habitation pod, or simply used as is. This means you don’t have to get it right the first time and can switch things up along the way. The most important factor is the truck itself, ensuring you’ve chosen a suitable base vehicle for your needs.
This largely stock Ford F-250 could be for you, fitted with the long-lived 6.7-liter Power Stroke diesel with a mere 142,000 miles. Additionally, this example benefits from the desirable FX4 offroad package, which significantly improves all-terrain capability. If you’re looking for build inspiration, check out this recently featured F-250 with Flatbed Camper
From the Seller:
This truck is fully loaded with everything you ever want in a diesel truck. It is in excellent mechanical condition, the interior is in great shape, and the paint is great with a few pinstripes and some scratches. I am only getting rid of it because I am looking to downsize to an F-150 or a Tacoma.”
This 2015 Ford F-250 is fitted with a 6.7-liter turbo-diesel engine that produces 440 horsepower and an impressive 860 pound-feet of torque. A powerful motor is matched with impressive 4WD credentials thanks to the FX4 offroad package, which incorporates a limited-slip differential, uprated suspension, higher ground clearance, skid plates, and more.
Distinguishing Features
  • Pro Comp 18-inch wheels with BFGoodrich M/T tires
  • Road Armor front bumper with Warn winch
  • Rigid LED DOT fog lights and auxiliary driving lights
  • Custom Eaton Bussmann relay and switch panel
  • Upgraded Ford Sync 3 head unit
This 2015 Ford F-250 Lariat 4×4 diesel is listed for $46,000 OBO and is currently located in Austin, Texas. Check the full vehicle specifications via the original Expedition Portal forum post here.
Our No Compromise Clause: We carefully screen all contributors to ensure they are independent and impartial. We never have and never will accept advertorial, and we do not allow advertising to influence our product or destination.
