2020 Ram 2500 Laramie Crew Cab 4×4 w/ Supertramp Flagship LT Camper :: Featured Classified
Ram 2500 overland build
We’ve featured several exceptionally well-considered and professionally outfitted overland builds recently, and today’s 2020 Ram 2500 with 61,500 miles is no exception. This full-size platform is a popular choice for overlanding thanks to its legendary Cummins diesel motor, well-equipped interior, backcountry credentials, and generous payload and towing capacity. Expedition Portal and Overland Journal Publisher Scott Brady stated, “While the Power Wagon gets all the off-road attention, the 2500 and 3500s have quietly overtaken the #1 seat in the full-size overland segment. With the combination of solid axles, the Cummins motor, and with the aftermarket support of companies like AEV, the Ram has consistently ranked as the most popular big truck for our audience.” These vehicles can be optioned from the factory with a suite of options, with today’s example showcasing both the luxurious Laramie trim and the Off-Road package. This 2020 Crew Cab 4×4 has been tastefully enhanced, and it’s clear that care has been taken to improve backcountry travel without compromising everyday drivability. The Bowen Customs’ 6-foot bed is a thing of beauty that transforms the truck into a legitimate expedition vehicle. The bed retains factory height while providing a high departure angle, a wide array of exterior storage cabinets that utilize previously wasted space, and is designed specifically for slide-in campers, such as the Supertramp Flagship LT camper. The award-winning four-season camper was awarded Truck Camper’s Reader’s Magazine’s Best Pop-up Truck Camper of 2023 and incorporates class-leading build quality and innovation alongside generous amenities. If you’d like a complete overview of this premium camper, check out Scott Brady’s comprehensive field test on the Expedition Portal YouTube.
2500 Bowen Customs
From the Seller:
“As an avid enduro rider and photographer, I’ve relied on a Sprinter van for many years. However, one major hurdle persisted: my garage. The constant struggle of not being able to store the van indoors due to my 9-foot garage door became a significant frustration. Initially, I considered a pop-top van as the only solution. However, when I discovered the Supertramp camper, I was immediately captivated. Already a fan of my Ram 2500’s ride and performance, I knew it could serve as the perfect base for the Supertramp. However, two challenges remained. The stock ride height of the Supertramp camper installed on the Ram 2500 measured 110 inches, while my actual garage door opening was 109 inches (less than 9 feet). This necessitated the installation of Kelderman Air Suspension, allowing me, at the push of a button, to drop the truck’s suspension to fit within my 109-inch height limitation. The added benefit was being able to easily level the rig at campsites by independently adjusting each airbag. Storage remained the final concern. The Bowen truck bed offered the solution, providing ample capacity without sacrificing the truck’s agility. A year later, my creation surpassed expectations, outperforming the van on all fronts.”
The 2500 is fitted with a 6.7-liter I6 Cummins that, in stock form, produces 370 horsepower and a considerable 850 pound-feet of torque. A long-lived motor is matched with impressive all-terrain performance thanks to 4WD, low range, a 3.73 axle ratio, an anti-spin differential rear axle, skid plates, and intelligent onboard systems such as Hill Descent Control. These rugged features are balanced with a well-equipped interior with comforts that include:
  • ParkView rear backup camera
  • Towing technology package
  • Powered, ventilated, and heated front-row leather seats and heated second-row seats
  • Wireless charging pad
  • ParkSense Park-Assist system
  • Surround-view camera system
  • Lane Keep Assist, Full Speed Forward Collision Warn Plus, Adaptive Steering System, and more
  • Adaptive cruise control
  • Engine block heater
  • Power-heated folding memory mirrors
  • Harmon Kardon 17-speaker premium sound system
  • Cold Weather Group
  • 4G LTE Wi-Fi hot spot
  • Uconnect infotainment system with 12-inch display
  • Climate control
Ram 2500 Supertramp camper
Supertramp camper
Distinguishing Features
  • Bowen Customs 6-foot bed with Supertramp Flagship LT camper
  • Kelderman air suspension
  • Method wheels with Toyo Open Country R/T tires (original stock wheels available)
  • 23 Zero Peregrine 180-degree awning
  • Battleborn 200-amp-hour heated lithium batteries, 1,500-watt inverter, Victron MPPT charge controller, 300 watts of solar, and more
  • Freshwater (24 gallons)
  • Isotherm 65-liter fridge
  • Truma Combi Eco Plus
  • Inside shower and portable cassette toilet
  • Air compressor
  • Torklift 30K Superhitch with 24-inch truss extension
  • Two Maxxair fans
  • Two 11-pound propane tanks
  • weBoost
  • Custom rear deck
Ram 2500 Laramie trim
This 2020 Ram 2500 Laramie Crew Cab 4×4 with a Supertramp Flagship LT camper is listed for $170,000 and is currently located in Colorado Springs, Colorado. Check out the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Email: cp_198@icloud.com
Instagram: chris_cp198
Method wheels
Supertramp camper
Ram 2500 overland camper
Ram 2500 Build Sheet
Supertramp build sheet
Learn more about the Ram 2500 here.
