2013 Ford E-350 4×4 Timberline Vans Build :: Featured Classified
Ford E-350 Timberline
We’ve featured many drool-worthy E-Series overland rigs over the years but today’s epic Timberline Vans (now Timberline Supply) E-350 4×4 has to be the most impressive to date. This extensively modified vehicle was one of the company’s final builds and is a testament to its many years in the industry (see more of their creations on Youtube). Subsequently, you can consider this vehicle Timberline’s Magnus Opus and to that end, the company was involved with every aspect of the build from the ground up. Ordinarily, 4WD conversion specialists are not as hands-on in the project as a whole but in doing so the same uncompromising mechanical and technical expertise is applied to all elements of the build. This comes at a significant cost with parts and labor alone for this rig exceeding an eye-watering $70,000 (full breakdown of work/receipts are available upon request). The result is jaw-dropping, transforming this legendary commercial workhorse into an around-the-world travel companion (learn more about international travel with this platform by referencing the adventures of Daniela Wagner). Unlike much larger expedition trucks or LWB vans the E-350 finds a sweet spot between exterior size and interior living space. A modest footprint makes driving around town and accessing trails a breeze while the boxy design offers generous interior living space (today’s example has been further enhanced with the addition of a Fiberine 30-inch high-top). If you’re in the market for the ultimate turnkey low-mileage (37,222 miles) E-350 overland vehicle then look no further.
E-350 4WD camper
From the Seller:
“One of Tim’s last builds. I’ve only used the van three times. Many of the van’s features have yet to be enjoyed. It’s a true off-road van but I’m going in another direction with my camping set up.”
E-350 camper
Timberline Vans E-350
The E-350 is fitted with a 6.8-liter V10 that produces 362 horsepower and a considerable 457 pound-feet of torque (range provided by a Timberline high-capacity 46-gallon fuel tank). A dependable motor is matched with impressive capability thanks to 4WD, high and low range, lifted and uprated suspension, Warn manual locking hubs, armor, and all-terrain tires. Inside these rugged credentials are balanced with a well-equipped interior with driver comforts that include:
  • Cruise control
  • Power steering, windows, locks, and mirrors
  • Air conditioning
  • Captain chairs
  • Premium aftermarket audio with amplifier and subwoofer
  • Running boards
  • Cupholders
  • USB and 110-volt power outlets
  • Multi-function steering wheel
  • Auxiliary switches
E-350 4x4 solar
Timberline Vans E-Series
Distinguishing Features
  • Timberline aluminum heavy-duty bumpers
  • GFX T16 Matte Black wheels with Nitto Ridge Grappler LT tires
  • Timberline suspension with Ford Standard 5-inch coil spring 4×4 conversion, custom rear leaf springs, and Hellwig sway bar 7718
  • Norcold 12-volt/110-volt refrigerator
  • Fiberine 30-inch high-top with sliding windows
  • Onan 4000 generator
  • Thetford Porta Potti 135 (unused)
  • Aluminium square tubing roof rack
  • Timberline custom side and rear ladders
  • Timberline rear full-size aluminum box and tire carrier
  • Dometic air conditioner and Maxxair fan
  • Overland Vehicle Systems awning and Kickass Shower Curtain Awning
  • LiFePO4 138-amp-hour battery, Renogy solar 200-watts, 12-volt 40-amp DC-to-DC battery charger, Xantrex Freedom 2,000-watt inverter and Freedom Remote Control Display, and various power outlets
  • Freshwater, 13-gallon, and Camplux outdoor tankless water heater
  • Rhino Rack Nautic Kayak Loader and Foldaway-5 Multi-Rack 1-2 kayak, SUP, or Canoe carrier
E-350 overland camper
Overland kitchen
This 2013 Ford E-350 4×4 Timberline Vans camper is listed for $100,000 and is currently located in Flagstaff, Arizona. Check the full vehicle specifications via the original Expedition Portal forum post here.
Contact Information:
Email: James.Rhodes@COCONINO.EDU
E-350 high top camper
Learn more about this Ford E-350 4×4
