$450 OBO.
Used for one 4 hour paddle down a calm river. During the course of the journey, we discovered a crack. We hadn't done anything that we can figure out how it was cracked. It was about 1.5 inches. I think it was there when we purchased it. It was where the seat meets the hull, I think it was a weak spot in the mold or however they made it. It was patched using a polyethylene bond from TAP Plastics. It was the only bond I could find that works for HDPE which is what the canoe is made out of. The patch is much bigger than the crack, it looks bad, but it works.
It weighs about 85lbs, I believe the max allowable weight is 750lbs. seats 3 people. has 2 cup holders per seat, 2 seat backs, spots to hold fishing poles.
2 paddles to go with it (Not pictured) They are standard metal/plastic T handle paddles.
Yakima Universal Canoe Carrier Basically foam blocks with a tie down kit.
Would consider trading for a 2 person sit on top kayak, need something that would fit on top of a small CRV or Jeep YJ.
I'm in Modesto CA. zip is 95355
