Izzy do you have a IGT setup ? or just the grill box?
I really which SP made the gas grill I had seen in pics
had been thinking of a way to fit one into the IGT nicely and decided I am going to give this one a try (bought it tonight)
http://www.magmaproducts.com/Produc...2/Connoisseur_Series/Trailmate/trailmate.html
I am familiar with Magma being a boater
and the nice thing is you can get parts easy for them any and all parts !
link to the company page
only downside is most of their grills are about 10750 BTU this one is only 7500 ? but still better than the coleman and other cheaper ones ?
has links to the specs and dimensional drawings parts etc.. on that page
but here is a link to dimensions
http://www.magmaproducts.com/A10-801_TrailMate_Dimension.pdf
the body is 12.25 x 9 5/8
since its 12.25 in width it will drop into the frame ? since the frame needs about 12.75
hoping the regulator can kinda swing in first then the rest drop in
I never BBQ with the lid on ? so my plan is unscrew the lid and get some L channel material and make my own rest for the IGT area
drill it and screw it onto the ends and it should be a almost perfect fit
the lid ? hoping I can just drill to holes in the top use the existing handle like a top on and rest it on when/if needed ? again not a big deal for me
and whats nice is it will fit a standard width IGT unit so putting the stainless tray set on each side maybe ? not sure how hot it gets compared to the BBQ box ? but since it is a standard width everything else should fit and besides the small 1 inch or so lip on the 3 sides ? not a big deal figure I will just stick it to the right so the lip is away from me and the valve toward me ? dont think the small lip will be a issue ? if it is can cut it off I guess ?
the regulator should be easy enough to get to since it pivots ? you can also get a true LP kit with new regulator which has a nice end type dial
or get a HP hose adapter for bulk so lots of options to fuel it
I had thought of doing a double wide
http://www.magmaproducts.com/Produc...eries_BBQ/Catalina/A10-1218LS/a10-1218ls.html
and mount it sideways so its facing me again lid off style and taking up two spaces wide but facing me width way ? could be a cool option also
but I like the idea of the above one and since its one wide I could get two of these if need be and have the flexibility over one wider one although the wider one kicks out 12,500 BTU take up two spaces leaving the side open for easy to adjust and ignite the burners ? even though the one below is more BTU not sure the taking up 2.5 spaces would be worth it ? also the price !! but this one could be a super cool 2unit gas grill
this one
http://www.amazon.com/Magma-Product...Stainless/dp/B0049MFVF4/ref=cm_cmu_pg__header
kicks out 18000 BTU
that could be a pretty cool unit
would take up just over 2 units though ? but that in a 4 unit IGT with a gigapower LI stove you would have a monster power house of a cooking setup
one other thought come up with a drop in box and you would not have to mess with the hoods at all on the above ? since it can mount with bolts to the bottom it could be part of the drop in frame ? would be pretty easy and strong to come up with something like this and no drilling into the body etc..
going to look at that idea of mounting also if this way you would take up a extra half space ? not a big deal and have the hood in use if you want
again notice how they have many types of mounts that bolt into the bottom on the web site the boat ones we used to use had rail mounts ! and were very solid !
anyway lots of rambling just got my brain going tonight
the one nice thing about the first one is at $175 ? not a big amount the double wides with infrared are about $400 they also have non infared models but only about 11000 BTU in those
also I like the low nothing sticking up everyone join in from all sides kinda thing and would have a hard time cutting up a $450 grill
but then again would be cool and custom
hope my long winded rambling helps someone
sorry I am bad at grammar
