RepairmanSki
So I bought this fella recently:
The original posting and subsequent purchase are here.
I'm quite pleased with it overall, I've needed to do a bit of general maintenance, chassis greasing and so forth, and am awaiting better weather to tackle some outstanding issues like the leaky pan gaskets and bulkhead coolant leak. Nothing I can't manage, but with 10" of snow on the ground I've opted for patience.
The interior is functional, but quite spartan. I've taken the spate of cold weather as an opportunity to tinker around in SketchUp and work on the future floorplan and layout. I am constrained, in part, due to existing exterior modifications most specifically the refrigerator. Exterior propane storage may interfere enough with the bath layout that it will require relocation, we shall see.
Here is an isomorphic view of the current plan:
The only things fundamentally unchanged from its current form is the dinette, the refrigerator, and the bulkhead about 5 window bays rearward. Water storage is under the bed, above and slightly aft of the rear axle.
Questions and comments appreciated, just note the the cabinetry and some sundry details are just mocked up for volume, not really indicative of exactness.
Also, the pics are linkified for larger versions (where available) and I'm still in need of a name...
Engine: Chevrolet 366/6.0L Gas
Transmission: Allison 545
Transfer: Rockwell T 226 (1.99)
Front: Dana Off-Highway 9000#
Rear: Eaton 19069-S 19,000#
GVW: 15,000# (Downrated for licensing)
Final Drive: 7.17
Wheel/Tire: 11R24.5
Odometer: 112K
Final Drive: 7.17
Wheel/Tire: 11R24.5
Odometer: 112K
