ExploringNH
In a continuation of my Build Up thread, we are now on the road and headed for Ushuaia. We will be traveling swiftly through Central America and will be stopping at Panama Passage to hang out for a few days and get the truck shipped into Colombia. After Panama, we intend to slow down a bit, explore, and see the sights. We will still be traveling quicker than most and hope to hit Ushuaia in 5-7 weeks. At this point, we will see where the road takes us.
Once in Ushuaia, my driving partner will be departing and I will then spend 3-6 months touring around Chile, Argentina, and hopefully back up to Colombia.
You can track our progress here: http://time2getlost.com/where-are-we/
The Spot Tracker updates our location every 10 minutes while we are on the road.
Yesterday we stopped at Rausch Creek Off Road Park in PA for a little test run of all the new modifications. The truck worked well overall, despite breaking a u-joint early in the day. The joint itself was fine, but the retaining clip broke off and the driveshaft yoke slipped down, causing a knocking that we noticed right away. Because we noticed it so quickly, we were able to fix it by just popping in a new, heavy duty, snap-type retaining ring. After that, we were good to go for the rest of the day.
The tires performed flawlessly throughout the day in conditions ranging from wet nasty clay to very grippy rocks. The clay turned the tires into slicks, but it did the same to everyone, regardless of tire.
We started out at 18psi since I was unsure of what the tires would do. They were ok at this pressure but they didn't conform to the rocks as well as I liked. Our next stop was 10psi, and that is where we stayed for the day.
There was some water, but nothing major.
So much rock. The truck flexed out ok. I am still hoping that the springs break in a little bit.
Today we are headed to do a final shopping trip for supplies that we either forgot or planned to pick up on the road. Our optimistic target is to hit Mexico at some point on Monday. We are still about 30 hours out and we are starting late today so we will see how far we make it before getting too tired to continue.
We will post updates as we can. :sombrero:
