This is a build thread for my ever evolving rig to keep myself motivated and to share thoughts and ideas related to this hobby.
I purchased this truck in 2007 as a stock 2000 TJ Sahara at around 60,000 miles and presently have around 135,000 miles on the ticker. Through needed maintenance I have begun upgrading the truck and ended up with a reliable vehicle that has taken me many places. Unfortunately, most of the suspension is factory and thousands of miles on fireroads and trails have taken its toll.
The plan is to replace and upgrade the entire suspension to ensure continued reliability, easy maintenance and address some weak points and downsides of the drivetrain while everything is torn apart. Clearly this list of modifications will not happen overnight, but I have built or am building most of the components out of the vehicle. I hope to keep this Jeep low and lightweight, yet have the capability to carry a comfortable load for extended trips for 2 people. Though it currently does that now, much needs to be addressed for what I picture as my ideal Overlanding TJ.
-Gianni
Note: I will do my best to reference locations purchased and part numbers of components I have picked up. If there are issues with these links or they are broken please let me know. I will also do my best to reference other builds and informational resources as I address them in the tread.
2000 Jeep Wrangler TJ - Before
Chassis
Frame / Chassis : Factory
Cage : None
Overall Wheel Base : 93.25”
Overall Length : Front Hitch to Tire ~160.00”, Front Hitch to Rear Hitch ~155.0”
Belly Pan Clearance : ~12.50 “ (lowest point of bottom skid)
Overall Height : ~79.00” (Highest point rear rack unloaded)
Wheel Track Width : ~59.25
Overall Weight : TBD
Front Shock Travel : 8.00"
Rear Shock Travel : 6.75"
Powertrain
Engine : Factory 4.0 Liter, Precision Auto Injectors (99Jeep4Upgrade), Flow Cooler Water Pump (1750)
Batteries : Optima Red (Part Number is faded)
Radiator / Fans : Flex-a-lite Puller (485)
Air Intake : Factory Intake, K&N Filter (33-2114)
Exhaust : Factory
Muffler : Factory
Transmission : TF999 - 32RH
Torque Convertor : Factory
Transfer Case : NP 231 J
Transfer Case Shifter : Factory
Fuel Containment : Factory
Body / Interior
Body / Body Panels : Factory
Body Modifications : Dents & Scratches
Skid plate / Material : Factory
Hood / Grille : Factory
Top : Factory Hardtop
Armor : Factory
Dash / Gauges / Switches : Factory
Steering Column / Wheel : Factory Tilt
Pedal Assembly : Factory
Drivetrain
Front Suspension : Factory Coils, Teraflex 2” Spacer (1245200) - Purchased Used
Front Shocks : Bilstein (24-024426)
Front Sway Bar : Factory, JKS Quicker Disconnects (20301)
Front Bump Stops : Factory w/ Homemade Extensions
Front Axle Housing : Dana 30
Front Locker : None
Front Ring & Pinion : 3.07
Front Differential Cover : Factory
Front Axle Shafts : Factory
Front U-Joints : Factory
Front Brakes : Factory Components, Crown Industrial 5 Layer Hoses (12706.422), EBC Yellow Pads (EBCDP41255R), Centric Premium Front Disc (CE120.67045)
Front Steering Setup : Currie HD Tie Rod System (CE-9701)
Front Driveshaft : Factory
Rear Suspension : Factory Coils, Teraflex 2” Spacer (1245200)- Purchased Used
Rear Sway Bar : Factory
Rear Shocks : Bilstein (24-024433)
Rear Bump Stops : Factory w/ Homemade Extensions
Rear Axle Housing : Dana 35
Rear Locker : Factory LSD (rebuild after blowing up clutches)
Rear Ring & Pinion Ratio : 3.07
Rear Differential Cover : Factory
Rear Axle Shafts : Superior Dana Rear Axle (SAG-PA5947A, SAG-PA5947B)
Rear Brakes : ZJ Disk, Crown industrial 5 Layer (12706.422), EBC Green Truck Pads (E35DP61606),Wilwood Knob Proportioning Valve(260-10922)
Rear Drive Shaft : Factory
Tire Make / Size : Goodyear Wrangler Duratrac 265/75-16 Load Range E
Wheel Make / Size / Bolt Pattern : Factory - Rubicon 16x10 - 5 x 4.5
Body / Interior
Seats / Harnesses : Factory
Electronics : Center Dash Mount Acer Aspire One, Garmin GPS Puck
Lights Interior : Factory
Lights Exterior : 4 x Off-Road Truck Light (3029)
Safety - Fire Extinguisher : None
Winches - Front / Rear : None
Exterior Rack : Garvin Wilderness Rack (34098)
Before Front :
Before Side :
[/SIZE]
________________________________________
2000 Jeep Wrangler TJ -Current (4/4/2012 Update)
Chassis
Cage : Synergy Suspension TJ Cage Kit - Proposed
Overall Wheel Base : 93.5”
[Belly Pan Clearance : 13.75” - Evaluating skid options
Overall Height : ~80.25” (Highest point rear rack unloaded)
Wheel Track Width : ~61” Front , 60.5” Rear
Front Shock Travel : 11.50”
Rear Shock Travel : 10.75”
Powertrain
Engine : Factory 4.0 Liter, Precision Auto Injectors (99Jeep4Upgrade), Flow Cooler Water Pump (1750), Currie 1" Motor Mounts (CE-9200)
Batteries : Optima Red (Part number is faded)
Air Intake : Spectre CAI (9943) (Shock towers now block factory location)
Exhaust : Magnaflow Performance Catalytic Converter (50209)
Muffler : Dynomax Super Turbo (19391)
Transmission : AW4 (Modified Valve Body & Accumulators), RAD Designs Baja II Shifter - TransGo Shift Kit (T97165A)
Transfer Case : NP 231 J w/ Currie Tail Shaft Conversion Kit (CE-9069T)
Transfer Case Shifter : Advanced Adapters Cable Shifter (715543)
Body / Interior
Body Modifications : Factory
Front Bumper : Under Construction
Rear Bumper : Planning
Armor : Evaluating make vs buy skid options
Dash / Gauges / Switches :Compressor, Locker & Transmission Control Switch - In Progress
Drivetrain
Front Suspension : OME 2.0” (2933), Currie Johnny Joint Control Arm Set (9100), Currie Johnny Joint Track Bar (CE-9120TJS)
Front Shocks : FOA 2.0 12" Reservoir Shock - Medium Compression & Light/Medium Rebound (FOA-12), Extending Shock Mounts - TBD
Front Sway Bar : Factory, JKS Quicker Disconnects (2030)
Front Bump Stops : TBD
Front Axle Housing : Dana 30, Superior Front Axle Tube Seals (EV70FSL)
Front Locker : ARB Air Locker ARB (RD100), ARB High Output Compressor (CKMA12)
Front Ring & Pinion : 4.56
Front Differential Cover : ARB Differential Cover (0750002)
Master Cylinder: Factory
Front Brakes : Factory Components, Crown industrial 5 Layer (12706.422), EBC Yellow Pads (EBCDP41255R), Centric Premium Front Disc (CE120.67045)
Rear Suspension : OME 2.0” (2942), Currie Johnny Joint Control Arm Set (9100), Currie Johnny Joint Track Bar (CE-9120R)
Rear Shocks : FOA 2.0 12" Reservoir Shocks - Medium Compression & Medium Rebound (FOA-12), Synergy Suspension Coilover Bracket (PPM-5001)- TBD
Rear Bump Stops : TBD
Rear Axle Housing : Ford 8.8
Rear Ring & Pinion Ratio : 4.56
Rear Differential Cover :TBD
Rear Axle Shafts : Factory
Rear Brakes : Ford 8.8 Explorer Disk, Crown industrial 5 Layer (12706.422), Wilwood Knob Proportioning Valve (260-10922)
Rear Drive Shaft : TBD
Body / Interior
Electronics : Center Dash Mount Acer Aspire One, Garmin GPS Puck, Yaesu (FT-1802M/E)
Lights Exterior : TBD
Winches - Front / Rear : Warn HS9500i w/ Expedition Portal Edition Viking Line
Exterior Rack : Garvin Wilderness Rack (34098) - Possible Change
Parts Laid Out Before Starting (Few Months Ago):
-Gianni
Chassis
Cage : None
Powertrain
Exhaust : Factory
Muffler : Factory
Body / Interior
Armor : Factory
Drivetrain
Front Locker : None
Body / Interior
Before Front :
Before Side :
[/SIZE]
Chassis
Powertrain
Body / Interior
Drivetrain
Body / Interior
