Sheep Shagger
I wanted to add a 3rd battery to the frame rail on the drivers side, just like the stock mounting on the passenger side (Diesel E350). I know there are other alternatives out their, but I like using stock parts when I can, and none that I have seen as as good as stock anyway.
I managed to find a battery box on ebay for $25, so when it arrived I made up a template for the hole pattern and when I placed it up the the frame, to my surprise Ford have already drilled the holes in the frame rail to mount another two batteries on the drivers side. Great, as I don't like drilling frame rails.
Only problem is the hand brake cable is in the way, rather than cut off the mounting points on the frame, and relocate the cable either up / down or closer to the frame, I decided to just space out the box.
Machined up some spacers, and threaded the last 5mm of the spacer so it holds the bolt to the frame rail to make installing the box easier.
Then it's just a matter of bolting it all up to the holes Ford so nicely supplied.
Here is it, but no cables installed yet. I also bolted up a jump post like the other side.
Very simple and it took me about 1/2 day to do, but most of that was flaffing about machining up the spacers and getting the size / tolerance just right.
Bolts 7/16 x 2.5 Grade 8 (Nuts & washers)
Spacers were 1 1/4
Spacers were 1 1/4
