83 Toyota Pickup with Popup camper
Hazzard
Not mine but a cool find.
http://forums.mtbr.com/showthread.php?t=595983
Platform 83 Toyota pickup longbed:
Final crawl ratio is 215:1
Professional built Chevy V-8 small block 400 Stroked (6.7 Liter 406) estimated 400hp . Rods are longer than stock at 6-inch length. Edelbrock Pro-Flow Multi-Port Sequential Fuel Injection has keypad in cab for adjustments on the fly. Trick Flo aluminum cylinder heads. Custom Erson cam shaft w/steetdampr. Crowler Roller lifters and roller rocker arms. Evans waterless NPG+ coolant with total bypass thermostat. Power Steering. Air Conditioning. R & M heat exchanger hot water shower system. Premier Power welder and power supply with 160 AMP alternator, Tilton High Torque Starter … . Engine temperature runs cool (198 degrees with a 195 bypass T stat). Headman headers tight fit with heat coat,, Knock sensor, Audiovox Electronic Cruise Control. Hand throttle on transmission shifter, power steering,Jacobs electronics headlamp brightners,Dual optima battery w/marine battery switch, dual transfer cases JP eater,Final crawl ratio is 215:1, NV4500 5 speed tranny, Moser 1.5 inch 35 spline axles, arb rear locker, Tru-Trac gear proportional locker, disc brake upgrade with Land Cruiser vented rotors and 4-Runner big caliper disc brakes. Toyota Land Cruiser brake master cylinder and clutch master cylinder,13.5-gallon gravity flow to main tank under the spare tire, carries 30 gallons of gas and gets 15mpg at 75-80 mph, Custom-made National Springs on all 4 corners, Warn 8000-pound winch, four wheel camper ranger model, 6 underbody rock lights, Rancho 9000 5-way adjustable shocks. Front and rear sway bars with quick disconnects, Firestone Ride-Rite air compressor,Hella twin trumpet air horn,solid rock sliders, bomb proof Renuel custom bumpers, dyno mat cab, Tires are BF Goodrich 33x12.5x15
Four Wheel Pop-Up Ranger Model
Camper features
3-Way Refrigerator. 16,000-BTU forced air furnace. 8-foot Fiamma awning. Side awning and back porch lights. Front sliding window. Deadbolt. Arctic Pack insulated liner. 2 roof vents. Front roof vent Fan-Tastic power vent. Shurflo water pump and faucet. 2 burner stove top with cover. 20 lb. LP gas tank with gauge. 12-gallon water tank. Slide out Queen-sized bed. Hella map lights in upper bed. Storage closet. Cable jacks free standing. Camper battery mounted in truck bed. Electronic interior water and battery meter. Wired LED DC volt meter. 300 watt power inverter.
This rig is clean!
haven
The original post to MTBR.com doesn't appear to be a "for sale" listing,
it just shows off an incredibly clean truck. So I'll move this thread to
the Toyota forum.
Chip Haven
I'm pretty sure thats the same truck. Same wheels, color matched bumper, camper looks the same. Very clean truck, not sure how I feel about the huge bumper but would gladly cruise in this thing.
Hazzard
the Toyota forum.
Chip Haven
Woops, thanks for the move.
Your pic does look like the same truck. I doubt there are that many 83's out there with that configuration and a Ruenel front bumper.
Cackalak Han
I'm cringing at the sight of that bike rack up front. Hate to think what a good sized pebble will do to that CF frame.
kcowyo
ExPo Original
It is the same truck and it recently sold to a Toyota hound in Colorado.
:smiley_drive:
WheelTired
That bike will not ride up there very often....did a photoshoot with Trek's Top Fuel flagship race bike with the engine bay in the background....
Drove it back from Texas last week like pictured, set the cruise on 70mph...flawless.
Love the truck !!
Thx,
"The Toyota Hound"
Youngunner
I saw that thing on craigslist a while back for about 15,000. I love that style and I'm looking to get one. Maybe transplant a MOPAR 318 or 340 into it, more power and more bomb-proof than a Chevy!
haven
Nice way to add more headroom to the camper! Reminds me
of Joaquin Suave's Casa Azul
(Just kidding!)
greggarnett
