FOR SALE: 2000 Ford E-250 Off-road Camper Van
For Sale is a 2000 Ford E250 camper van which was built in Oct. 2014. The van has since been driven to Guatemala, Baja several times, Moab, Death Valley, Yosemite, Glacier, Zion, Vancouver Island, etc. The solar electric system and fridge were installed Jan. 2016. Happy to deliver anywhere in U.S. for cost of fuel.
http://seattle.craigslist.org/see/cto/5722770414.html
Electrical & Interior:
- 200W monocrystalline solar panels
- 20a MPPT charge controller
- Wagan EL2205 Elite 2000W Pure Sine Wave Inverter
- 2x Trojan T-105 6V batteries connected in series
- custom battery box welded to driver frame rails
- Engel MT80-U1 Dual Voltage 84-Quart Fridge/Freezer 12V/24V/110V
- Engel Transit Bag - fits MT80
- Blue Sea Systems SI-ACR Automatc Charging Relay - 12/24V DC / 120A
- Blue Sea Systems 5025 ST Blade Fuse Block
- 1/0 AWG Premium Extra Flexible Welding Cable 600v(battery connections soldered)
- Maxxair 00-075000 MaxxFan Smoke Lid Remote Control
- Ventline V2092SP-28 Birch White New Style Ventadome
- Alpine CDE-W235BT CD/MP3/USB Car Stereo Receiver w/ Bluetooth and Front Aux
- Alpine SPR-60C 6.5" Car Audio Component System (Pair)
- Bedrug VRF92X VanRug Cargo Van Mat
- Dynamat 10455 Thick Self-Adhesive Sound Deadener
- GTMAT 100 sqft Automotive Sound Deadening 50mil PRO
- Serta Perfect Sleeper Gorham Firm Mattress, Queen
- Ford Swivel Seat Base
5.4 Engine & 4R75W Transmission:
- Bosch (4504) HGR9DQI Platinum IR Fusion Spark Plugs
- ACCEL 140032-8 Ignition SuperCoil Set
- Motorcraft BT-62 Belt Tensioner
- Dayco Drive Rite 5060408DR Serpentine Belt
- Gates 38008 Belt Drive Pulley
- Motorcraft FG986B Fuel Filter
- Fel-Pro MS92568 Manifold Gasket Set
- K&N E-0945 High Performance Replacement Air Filter
- Magnaflow 13749 XL Stainless Steel 3" Round Muffler
- Hayden Automotive 679 Transmission Cooler(added inline to stock cooler)
- Mobil 1 112980 Synthetic Automatic Transmission Fluid
- Mobil 1 5w-30 Oil changes every 3-5k miles.
Suspension/steering/brakes/tires/axle:
- 3" variable rate lift coils.
- 2" modified leaf packs
- Bilstein 7000 10"front/12"rear remote reservoir nitrogen charged shocks.
- Prothane 6-603-BL Black Axle Pivot Bushing Kit
- Prothane 6-1207-BL Black Radius Arm Bushing Kit
- 2x Moog K80196 Ball Joint
- 2x Moog K80197 Ball Joint
- Moog ES3203L Tie Rod End
- Moog ES3202R Tie Rod End
- Motorcraft MDOE6 Drag Link
- Motorcraft MDS1289 Drag Link
- Motorcraft BRSD802 Rear Semi Metallic Pad
- Bosch BP655 QuietCast Premium Disc Brake Pad Set
- Motorcraft BRR71 Rear Disc Brake Rotors
- Centric Parts 141.65510 Semi Loaded Friction Caliper(rear)
- Centric Parts 141.65509 Semi Loaded Friction Caliper(rear)
- Centric Parts 121.65046 C-Tek Brake Rotors(front)
- 5x 315/75R16 BFGoodrich All Terrian Tires on black steel wheels (50% tread)
- ARB RD166 Air Locking Differential
- ARB Products 0750001 Competition Differential Cover for DANA 60
- ARB CKMTA12 '12V' On-Board Twin High Performance Air Compressor
- Yukon (YA WFF35-39.5) 4340 Chrome-Moly Replacement Axle for 35-Spline Dana 60
- Yukon (YA WFF35-36.5) 4340 Chrome-Moly Replacement Axle for 35-Spline Dana 60
- Spicer 70907X Ring and Pinion Gear Set(4.56)
- Timken DRK331 Differential Rebuild Kit
- Timken SET38 Bearing Set
- 2x Timken 387AS Bearing
- 2x Timken 382A Wheel Bearing
- 2x Precision 331 Universal Joint
Exterior:
- 8x Yakima 1A Raingutter Towers
- 4x Yakima Round Crossbars 60"
- Yakima LoadWarrior Rooftop Cargo Basket
- Yakima Fairing 50"
- Aluminess Tire Rack
- Front bumper by DC Custom Fab
- 3x 8" LED offroad lights
- 7 gallon ABS solar shower
- ARB 4x4 Accessories ARB4401A Awning
Price: $14,500
Exterior:
Price: $14,500
