Price reduced NOW: $600 5-27 $700.
4 tires (4000 miles of use) + 2 super single wheels, no usable front wheels. 285/70R19.5 Wheels are 19.5 by 7.5" wide. Tires are a bit over 35" tall. Pullman, WA
Fit: Ford super duty '05-up F-450/550, F-53, 10 lug x 225mm PCD, 170.1mm Bore. Also fit 2008-up Dodge 4500/5500 and Sterling Bullet and probably others.
Maximum load per tire 6395 lbs (vs stock 3970)
2 Rickson steel rear wheels as super single have a 7' wide track (or can be reversed and be 7' 5" wide)
2 Michelin XDE2+ tires M+S Plus the 2 wheels
2 Michelin XZE2+ tires. no wheels. With the appropriate wheel this tire will fit in the Ford wheel well without modification.
I paid $4500 for the 4 wheels and 4 tires. The front Rickson wheels are no good but the rear wheels are fine.
Photos 4 and 5 are comparisons with factory wheels/tires
$800.00 For all. I'm selling because I went with 22.5 wheels/tires.
Slight damage to tread on one drive tire.
