TenaciousTJ
Selling my 1964 M416 1/4 Military trailer. This was in near museum quality before a buddy and I disassembled the entire trailer and rebuilt it. It's carried both an ARB RTT and Autohome RTT all over the western US and thousands of miles of road and dirt. Located in Olympia, WA. $4500
- 2x3 .120 wall boxed steel frame w/ custom HD fully boxed spring mounts
- 13' continuous single stick of receive tube running the entire length though the middle
- Receiver tube drilled for bike rack or accessories in the back
- J-box mounted flush to frame under trailer body
- Adventure Trailers LED tail lights with license plate light and license plate mount
- 12 gallon water tank w/ drain
- Rocket hand pump
- 4 gallon rotopax fuel cans (2) lockable
- Lockable tongue box with J-box wired into it
- Aluminum lid made by VMI Offroad
- Thule racks and mounts on lid
- Bracing under lid and foam gasket
- HD gas assist struts inside lid
- Adventure Trailers Max Coupler multi axis hitch
- Wired for 7 pin and 4 pin hookups
- Custom made Dexter axle with 10" electric brakes, upgraded EZ lube bearings, and HD spring perches
- Original M416 tub was sandblasted down to bare and repainted white
- LineX'd tub
- HD custom made fenders w/bracing
- 37" Goodyear MT/R's w/ black JKR wheels
- Adventure Trailers custom made aluminum wheel spacers
- "Jeep" embossed on rear of trailer (cut from a vintage Willys tailgate and molded into trailer body
- JK hood latches used to secure lid (2)
- Offroad tire/caster on modified hydraulic trailer jack to support tongue weight
- M416 tie down repurposed and weld to frame to hold safety chains
- HD safety chain w/ quick release pull pin u-bolt attachment points
-PJ Trailers safety chain mounts
- 20 + body to frame attachment points with rivnuts, all place out of sight (under the trailer)
- HD outdoor rubber traction mat in tub
- Mac's Custom Tie Downs aircraft style tie down tracks running the length of the tub on both sides
- Still have the factory 1964 US Army data plate
- Rocket hand pump
- LineX'd tub
