coastal616
Here we go,
Well the 6.4 slowly started dying a year or so back. It's still driveable, but I can't tow with it. Head gasket has a leak, it over heats under any load and pukes coolant...the usual.
I really like the motor, but the complicated electronics, and ram jammed engine bay aren't appealing to me. I had quotes to fix the head gasket, along with studs and whatever else they recommended and the quotes were from $6500-$10000. And it still has the original bottom end, HPOP, and whatever else might want to fail next.
I picked up a 1993 International 5 ton with a DTA360 for $1500, pulled the motor and have tentatively sold the truck for around $1000.
I didn't want to use an auto that might fail next, or spend $5-7000 building a tranny, so I've decided to stay medium duty. I picked up an International reNEWed Spicer ESO66-7b 7 speed tranny for $1500.
Next step is to divorce the factory T-case, and make this big blue beast fit.
Taking this:
wanted to see how hard it would be to make this motor run out of the truck so I know what I am up against...
Apparently a battery, a Jerry can of diesel, a jump start and one wire.
Dt360 startup on a stand - YouTube
First project hiccup...the input shaft on the new transmission is quite a bit bigger than the original one. I thought I could put a DT466 flywheel on, but it has a different bolt pattern. Sooooo either find a 52mmx30mm bearing, or get the flywheel machined to fit a bearing that works. Not a big deal...
Pic shows a dt466 bearing above and the dt360 bearing below.
Flywheel machined, $100, new bearing $13, flywheel resurfaced $60:
Taking this:
