biotect
Designer
Some commercial overlanding trucks also seem to have positively terrible departure angles; for instance, the vehicles used by Odyssey:
See post #978 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page98 . But maybe I am wrong about this; maybe the camera angles in these images are not doing these vehicles sufficient justice?
Sure, I am still aiming for MAN-KAT level approach and departure angles (45 degrees), and I want the vehicle to be 6x6, to cut down on the distance between the first and second axle. But because the standard “two axles clustered in back” arrangement allows for long side-lockers between the first and second axles, I think that's what I will finally choose. Evenly spaced axles pretty much eliminate any possibility of side-lockers. But even with two axles clustered in back, the TerraLiner will probably end up with an inter-axle distance between the first and second axle that is much less than the inter-axle distance in almost all of the commercial overlanding trucks I've covered so far.
A Visual Comparison of Inter-Axle Distance and Breakover Angles
dwh, thjakits, optimusprime, Haf-E, egn, NeverEnough, etc.,
As you know, I've been worried for a while about the "breakover angle", inter-axle distance, and axle placement. For the fullest description of the worry, see post #886 at http://www.expeditionportal.com/for...pedition-RV-w-Rigid-Torsion-Free-Frame/page89 . But one salutary effect of researching commercial overlanding vehicles in depth, is realizing just how long their inter-axle distances tend to be, and how terrible their breakover angles must be as a consequence.
It's rather surprising that they do not constantly turtle:
CONTINUED IN NEXT POST
