This vehicle is truly an expedition ready truck. Near perfect condition. 23K factory warranty. No dents, no rust, all systems/additions perfect. Truck was built and used with great care. Never raced or abused. No rock-crawling or high speed off road use. You will be hard pressed to find a rig that is this well equipped or in this condition.
-52,000 miles (23,000 miles remaining on 75K transferable Toyota factory extended warranty). Regular, documented dealer service at 5000-mile intervals.Photos below. Detailed additional photos at:
http://s1081.photobucket.com/user/cwvandy/library/2009 Toyota Tacoma TRD?sort=6&page=1
TRD Off-road Extra Value Pkg., towing package (see window sticker, below)
-Invinceshield rock guard clear sheets on all forward facing surfaces
6 Toyo M/T 265/75 R16 (four on the ground nearly new w/ 90%+ tread). Plus two spares; one in stock position, one on swing out rear bumper tire carrier. All tires on matching Toyota alloy rims.
-4 studded snow tires on 4 matching Toyota alloy rims
-Stubbs Rock Sliders (powder coated, frame welded)
Bud Built full-length skid plates
OMEmu rear nitrogen shocks and Dakar HD leaf springs with extra leaf (stock springs and TRD/ Bilstein shocks included)
-Icon Coil-Overs and Total Chaos control arms (w/ skid plate). New SS balls installed in Nov.’12 (stock TRD/Bilstein shocks and stock control arms included)
ARB Front Bumper (original stock bumper included)
-Warn Winch (9.5 XP with remote mounted solenoid box)
-Metal Tech custom:
-Internal Roof Rack support system inside Snug Top with Fourtreks holders for Axe, Shovel, Highlift, fire extinguisher and internal roof brackets for two camp tables (holds Snowpeak iron grill and bamboo Single Action table-not included). Through bolted to roof rack.
-HD steel rear bumper with double swing out gates with spare tire mount, fold-down table, recovery kit (pelican case) and Adventure Trailer dual gas/water can carriers. System is modular and gas/water can carriers can be swapped out for pelican case mount with two bolts.
-4.56 Nitro gearing (stock gears included)
-2 Baja Design HID lights (toggle switches in center console)
-Two Odyssey batteries
-K&N air filter
-Nat’l Luna Intelligent split charging kit (second battery system wired with marine-grade, tinned, oversize wire in wire loom)
-Custom mounted, Blue Seas Waterproof breakers, digital amp/volt meter and 12-volt outlets mounted in side of bed. Breakers tied to 2nd battery for frig, Extreme Air compressor outlet, interior bed cap light, three 12volt accessory outlets, trailer Anderson connector
-2-0 gauge wire w/ 75 amp Anderson connector at rear bumper for trailer (used to connect Adventure trailer with dual 200amp hour batteries). Wired to second battery.
-Yaesu FT-8800R Dual Band Transceiver console mounted with Diamond antennae (mounted on ARB front bumper)
-Adventure Trailer composite box/drawer mounted in truck bed (removable)
-Front Runner fridge slide (mounted on Adventure Trailer drawer)
-Factory rear lockers, ARB front lockers w/ ARB compressor mounted in engine compartment (toggle switches in center console)
-Custom 41-gallon gas tank with internal anti-rust coating, full length aluminum skid plate (stock tank included) See build thread:
http://www.expeditionportal.com/for...-tank-for-09-Tacoma?highlight=gallon+gas+tank
-Eezi Awn Series 3 1600 T Top RRT (willing to sell separately: Excellent condition, $1800, buyer pays shipping)
-Baja Rack on Front Runner roof rack (mounted over cab)
-Front Runner Rack (rear) for RTT. Rack through-bolted to Metal Tech frame inside Snug Supersports top
-Snug top Supersport (model with reinforced roof)
-Mac Custom tie down aircraft grade track and tie downs in truck bed (through bolted with backing plates)
-Recaro matching grey leather Topline front seats on custom brackets, electric adjustment, heat, air vent, adjustable lumbar support, thigh support. Seats work with stock airbag system (Stock seats included)
-Two Frontrunner water tanks (40 liter foot-well water tank, 40 liter upright water tank in bed: both removable).
-Modular Cooler/fridge shelf replaces rear passenger seat. Bolts to seat fold-down brackets and can replace rear seat in 5-minute swap. Folds up to access accessory storage compartment below.
-Over $37K invested in additions, accessories and custom parts alone. Modifications professionally done by Metal Tech, Custom Exhaust Specialties, Columbia Overland. Stock truck $32K+.
-Asking $35K. No trades. Parts not sold separately (Eezi Awn tent accepted).
PM or email me at cwvandy1@mac.com
MANY MORE PHOTOS:
-Metal Tech custom:
-K&N air filter
MANY MORE PHOTOS:
