Not all of us can spend months or years constructing a custom expedition cabin to mount on a 4x4 chassis. Consider modifying a fiberglass travel trailer instead.
Carl Hunter of Vancouver BC introduced us to the fiberglass travel trailer as an expedition cabin. Carl mounted a Bigfoot fiberglass trailer onto a Fuso FG 4x4 chassis, and proceeded to drive around the world!
Here's a second Fuso carrying a Casita fiberglass trailer.
The Casita rides higher than Carl Hunter's Bigfoot because it's mounted to a subframe that is easily detached from the truck.
The body of trailers like the Bigfoot and Casita is constructed from two molded fiberglass "bathtubs." When the top and bottom halves are glued together, the trailer body becomes a very strong, lightweight, and waterproof shell.
Through the years, the molded fiberglass travel trailer has proven to be very durable. There are plenty of examples of fiberglass trailers from the 1960's and 70's with bodies that are in great shape, something that few other trailer types can claim.
I think the reason that the fiberglass trailer is so long-lasting is that it is less prone to water leaks. The shell usually has only one seam, running horizontally around the trailer's belt line. Plus the trailer shell can bend a little without cracking. These features allow the trailer to survive the twists and bumps of life on the road without developing so many water leaks.
Fiberglass is also easy to repair and modify. Carl Hunter's Bigfoot was patched to remove the trailer wheel wells. It's very difficult to see the repair.
The supplies to repair fiberglass can be found in lots of out-of-the way places, even in third world countries. Good luck finding a sheet of Nida-Core in Timbuktu!
A fiberglass travel trailer can be quickly and inexpensively adapted to mount on a medium duty truck. It took Carl Hunter just 90 days to procure and adapt his Bigfoot trailer to the Fuso FG.
There are several companies making molded fiberglass trailers today that could become good expedition cabins. I'll post information about them in my next messages.
Chip Haven
Chip Haven
