joelweb
With all the discussion lately about Bronco Four Wheel Pop Up campers on this forum, I thought now would be a good time to introduce a project I am just about ready to dive into. My brother in law recently drug this Scout Four Wheel Camper home and it needs some work, but I'm very close to adopting the camper while he scraps the rusty truck…
I have a 1976 International Scout Terra. As some of you probably know, the Terra (and its full top twin sister the Traveler) is like a Scout II, but has a 118” wheelbase instead of the 100” wheelbase found on the Scout II. All of the additional 18” in length can be found in front of the rear wheels in the bed area and other corresponding parts – all other dimensions are the same between the Scout II and Terra. The Terra also has a pickup top and removable bulkhead instead of the full tops found on the Traveler and Scout II.
Four Wheel Campers made pop up campers for both the 100 inch wheelbase Scout II and the 118” Traveler/Terra models. As great as those campers are, they are a very permanent fixture on a Scout. They take the place of the vehicle's cab by bolting to the windshield and they don't have the “slide in” tub like most other pop up campers. They can't be removed and reinstalled with ease and they must be stored indoors to keep dry when not installed. Simply put, they aren't something you take off and you have to dedicate a vehicle to one. A different option must exist.
Because of the Scout Terra's additional length compared to a Scout II, there is the potential to turn a Scout II designed pop up camper into a slide in camper model similar to the ones that folks are running on pickups. The Scout II campers stick out about 8 inches past the back of a Scout II. The Terra pickup cab ends about 10 inches behind the read edge of the door, which is the place where front of the Scout II camper ended. That's about 18 inches – the same length that Terra models are longer than Scout IIs.
Given this information, if the front of the Scout II camper was closed off and if the tub was framed and closed off, the Scout II camper could become a slide in camper that fit a 118” Scout Terra nicely. The camper would need to be raised a couple inches in order for the camper's overhanging bed area to clear the cab and some additional support may be needed to strengthen that area, but this should work…
However, I need to learn how the slide-in camper tubs were originally built in order to construct my own. I have a few specific questions from you camper experts – any help you can provide would be greatly appreciated.
First, how are the tub portions of slide in campers framed? I know the new four wheel campers have aluminum frames, but there appears to be a lot of wood on the older ones. I want this to be strong and light, but I don't have a physical example to reference how this has been done at the factory, which has left me scratching my head – any help is appreciated.
Second, along a similar vein, how is the front wall framed? Anything different?
I know these seem like basic questions, but I don't have anything to reference and a couple photos and some description describing the construction of tubs for slide ins would be extremely helpful.
thanks,
Joel
thanks,
Joel
