Shower Shelter
Clutch
<---Pass
Sometimes there is never a good place to hang my shower shelter.
So I made one.
I used 2 half inch square stock tack welded together, it just happens to fit perfectly into my Thule rack. Then I drilled a small hole on the end cap so a bicycle shifter cable slips through, then used epoxy to affix the cable to the 1/2" stock. So, when I pull off the endcap the rod will pull out.
http://outdoors.webshots.com/photo/2617613000093498191TUltxf
Clutch
<---Pass
It came with my solar shower, but, I am now using a stainless steel, bug sprayer can, with a shower head from Zodi. Zodi sells their Extreme Shower for $120. I built mine for $40. $30 for the can and Zodi sells the shower head for $10.
$120 for this!?>>>> http://www.zodi.com/web-content/Consumer/zodiextremeshower.html All it is a bug sprayer with a showerhead. I use my campstove to heat up the water, or lay it in the sun.
I have seen the shelter sold seperately. Under $30.
I don't want to have to worry about batteries or pumps, they just add weight and take up space.
cruiseroutfit
Cool, I will keep my eyes peeled for a curain like that. Cabela's, etc have the stand-alone style enclosures, but I'm looking for something I can hook onto my rollcage or hardtop.
For the shower I'm using a Helton Heat Exchanger setup:
:cool:
Clutch
<---Pass
Have you tried an Army Surplus store? We have one here that sells camping equipment too. I was in there yesterday and saw a shelter for $30.
I was going to go the heat exchanger route...maybe in the future...
whitethaiger
My little 6V shower pump just gave up, so I am looking for a new shower solution. I've heard good things about the Zodi and it seems to be a simple setup, i.e., not many parts to fail.
Do you have any info on what tank/parts you used for your home build version?
I have seen the shelter sold seperately. Under $20.
Clutch
<---Pass
You can buy everything at a hardware store. I already had a camp stove. I can get 3-4 minutes with the current shower head, I may be able to up the time, with a lower flow one.
Stainless Pump sprayer: $30
What is below is what I did to replace the broken Zodi showerhead.
High pressure 3/8" I.D. hose: 8' @ $0.60 a foot
Ball valve: $2.50
Brass garden hose adapter to 3/8" hose: $1.49
Shower head (of your choice) mine was: $3.99
Hose clamps: $3-4.00 (I bought a box of them)
Total $46.78
AZ Tax $3.78
Grand total $50.56
Click for bigger picture
If you look at the Zodi and mine, they are awfully close.
Clutch
<---Pass
Hey, no problem.
Once I had all of the parts it only took 10 minutes (if that) to plumb everything together.
You might be able to use the hose the sprayer came with, I wanted a longer one, so that is why I went the route I did.
Now, if you are really motivated you could plumb in a fitting for an airline from your onboard air compressor (which I am sure you have one ;) ) so you wouldn't have to "hand pump" it... :)
whitethaiger
Nah, I like the idea of keeping things simple. So I'll see first how bad that hand pumping is.
How long have you had your's, i.e., how often have you used/heated it?
Clutch
<---Pass
I just made it last weekend.
It has bean heated 5 times so far, to boiling once. I would also pressurize it after heating.
I have to pump it twice for one shower, testing at home before I use it in the field. Works so much better than my solar, plus I am guaranteed I will have hot water. I have taken enough cold showers in the past to be well over that. :)
Oh, one more thing, mine has a metal siphon tube, I noticed some had plastic siphons, which I would fear those would melt when heating on the stove.
whitethaiger
Looks like I got the same brand tank as yours, only mine was $39 (CA premium?) and the tube siphon tube is plastic. I'm not sure I am too concerned about the plactic part since I don't intent to take too many showers with boiling water. If it becomes a problem I may have to look into mods:rolleyes:
For the first tests (including a first field test) I'll be using the hose and shower head from our 6V shower. The shower has a flow regulator. It does leak when in the closed position, so I may need to add a valve eventually.
From a couple of pumping tests just performed I also think I'll have to pressurize it twice, particularly if I want to stand up and the tank is on the ground. Takes a lot of pressure to pump water up to 7ft:p
My wife is very excited about this. It should make for more convenient warm showers than our existing setup.
Now where can I get one of those little stick on thermometers? I noticed the Zodi I was shown had a little thermometer glued to the side.
kcowyo
ExPo Original
:xxrotflma
Man, you weren't kidding when you said you were "going to look into a shower next weekend." Nice Uwe - so how many gallons do those tanks hold?
Kermit - roughly how long does it take to heat up a full container? Are you heating the water in the container on a stove or are you heating the water in smaller pots and transfering it to the can?
This is such a simple solution for showering that I may have to seriously look into this myself...
Ursidae69
Traveller
I wonder if you could use a terrarium thermomter commonly used in the reptile world.
Where did you pick up your tank Uwe? I have not looked yet at the home improvement stores, I need to do that. Excellent thread Kermit. :victory:
4ROAMER1
