deadbeat son
I'm getting the rear leaf packs on my 09 Tacoma DC replaced courtesy of the TSB. :wings: The stock 3 leaf packs were just too soft for my needs.
Herein lies the challenge. I was perfectly happy with the stock stance; it's my understanding that the TSB springs settle out to about .75" higher than the standard springs. I'm interested in gaining .75-1" in the front to balance things out as well as stiffening up the ride on that end, but I feel a set of coilovers aren't necessary for my application. I don't plan to add a bullbar or winch in the near future. If I do, I'll upgrade the front suspension accordingly then.
After exchanging emails with ARB tech support, I called Slee Off Road about possibly picking up a set of 884 springs and N140S shocks. While ARB felt this would provide about 1" of lift for me, Slee felt otherwise. They get 3" of lift on a Double Cab with the 885, and the 884 is the same rate and only 10mm shorter. If this is the case, the 883 also maintains the same rate of the 885, but is 10mm shorter than the 884 (or 20mm shorter than the 885.) I've also noticed that OME recommends the N139S shock instead of the N140S for the 883.
Is anyone on here (or does anyone know of anyone) running the 883/139S on a Tacoma AC or DC? What variables go into the amount of lift/load handling capabilities of a coil other than the spring rate and length of a coil? The diameter of the spring steel the coil is wound from is also the same amongst the three coils. Would the number of coils (and coincidentally the "tightness" of the wind) affect the capacity, all other parameters being equal? I plan on stopping by Slee next week when I get a chance to pick their brains about this as well.
Sorry for the long post, but thanks in advance for the insight!
