| Expedition Trailers: Sponsored by AT A forum to discuss expedition trailer options, builds, modifications and designs. Sponsored by www.adventuretrailers.com |
Thread Tools | Search this Thread | Display Modes |
#1
NOTE: I just remembered that the newer BLACK poly tanks that AT uses may not work with this pump. Our poly tank is a older clear model with a smaller filler port. The newer style has a larger filler port and therefore the pump may all together just fall right through the opening. Maybe someone with a new style can chime in on the diameter of their filler port.
First off, big thanks to Ed for the help tracking this thing down. So i've noticed that using the manual pump on the Adventure Trailer can really be really slow sometimes. Reliable as all heck, but slow and tiresome for a large pot. I started figuring out what others have used. I wanted something easy and something that didn't need to be wired into the trailer and something that wasn't going to make me lose the manual pump. I wanted to keep the manual pump for back up. Well i looked at DatkariEd's trailer and noticed that he has this little gizmo on his water tank and no manual pump. I PM'd him a few times, and found out what it was. With a little bit more research i found it out on the web. It was a (2) d-cell water pump made for the 5 gallon bottle drinking water. Pretty cool I thought because it was simple, cheap and easy to use. It fits right in the filler port on our Horizon and slides over the neck for a somewhat tight fit. When not in use or flying down fire roads it will be stored inside. No more pumping to fill water buckets, pans washing dishes etc. For $12 you can't beat it. Here's a video clip http://youtube.com/watch?v=Cw2dx8322AQ Shot of it in a 5 gallon water jug ![]() Switch on top ![]() Specs: -Turns any standard 5-gallon water bottle into an instant thirst-quenching water fountain -High-output pump fills 8 oz glass in just 3 seconds! 4-liter per minute flow-rate -2 'D' batteries (not included) last for months (1,000 liters continuous); soft-touch button -Fits standard 5-gallon water bottles (not included); adjustable depth to fit other containers -Great for sporting events, picnics, work crews - dispenses sport drinks & adult beverages, too! Engineered to provide quick efficient water and drink dispensing without effort sturdy ABS construction is lightweight and stands up to constant use. Simple on-off switch allows continuous operation for filling large containers. Dimensions: 28-1/2"-length, maximum container depth 18", tube diameter 3/4" OD, 7" detachable spout with tethered cap; 14 oz. One-year warranty and Jack's Tool Shed worry-free Satisfaction Guarantee. Finding it was the sort of hard part. Had to search the net.. but i finally found it at Jackstoolshed.com. http://www.jackstoolshed.com/product...ater_Pump.html Ordered it and 3 days later it was here. I think for the price, i'll order a second one just in case!! Anyways, nows there's information on Ed's top secret pump. Hope you guys find this info helpful.
__________________
Dave, Yoshi and Dixie [KI6LBB] The Adventure Duo 2004 Jeep Wrangler TJ X Edition 1993 Toyota Landcruiser 80 Series 2004 Adventure Trailer Horizon Outfitted by www.sierraexpeditions.com Tread Lightly! Trainer www.caltape.com Need digital media? www.trasharoo.com Pack it in Pack it out! Last edited by adventureduo; 06-06-2008 at 01:03 AM. |
#2
Neat...so it shares the same thread size as the AT filler cap? One of the benefits, as you surely know, to the manual type pump on the AT's is water conservation ;-).
I replaced the plain threaded water tank plug on the underside of the AT tank with a petcock (lever actuated)...when I need water in a hurry I just fill pots and shower bucket from here...
__________________
Life's too short to go without good espresso... Modded '99 Land Cruiser Hundy for overlanding: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good ear candy, Waeco CF-50, PowerGate with 2nd battery, 9.5XP/Masterpull, VisionX Solstice, OME 864's, Fox 2" remotes with adjustable compression setting at each corner, 12mm body lift, Carl's UCAs, KK SportsRV & KE7NCM. |
#3
Perdy cool. We used to have one years ago to fill our Kerosenne heaters. Same thing different spout. It had a hose to reach the floor besidea 5 gal can.
__________________
Highlandercj-7 "If you don't stand behind our troops, Feel free to stand in front of them" ...There can be no divided allegiance here. Any man who says he is an American, but something else also, isn't an American at all. We have room for but one flag, the American flag... We have room for but one language here, and that is the English language... and we have room for but one sole loyalty and that is a loyalty to the American people.' Theodore Roosevelt 1907 |
#4
Quote:
Water conservation is really not a problem for us. We won't use anymore than normal, this just will help get it faster. Also, we can carry a spare 10-15 gallons in addition to the 19 gallon Horizon tank. Yeah if i ever need a ton of water quick, i just grab the 5 gallon NATO can with water in it off the tongue of the trailer.
__________________
Dave, Yoshi and Dixie [KI6LBB] The Adventure Duo 2004 Jeep Wrangler TJ X Edition 1993 Toyota Landcruiser 80 Series 2004 Adventure Trailer Horizon Outfitted by www.sierraexpeditions.com Tread Lightly! Trainer www.caltape.com Need digital media? www.trasharoo.com Pack it in Pack it out! Last edited by adventureduo; 06-05-2008 at 09:57 PM. |
#5
Quote:
Would you mind sharing a picture and/or further details? For example, do you fill directly from the valve or do you connect a hose to it? One thing that seems to take forever is filling the Zodi Extreme with a couple gallons for showers. But, using your method, I don't think I could get the Zodi to fit under the trailer. Quote:
#6
Dave,
Letting you do all the work , have you also figured out a way to keep the pump clean when not in use, at least the hose end that goes into the water tank? After watching your video, I definitely like this idea; however, I'd want to make sure that dirt/dust doesn't get introduced into the water tank with repeated removals and re-installs. Again, thanks for posting this up. Tony |
#7
Im going to figure out that next, Im going to see if i can find extra long zip lock bags and store it in the kitchen area. I can't see it getting dirty that way. I will post what i come up with.
Tony, to fill our Zodi, we just pour the water in from a 5 gallon NATO can. I wouldn't even think about filling the zodi with the manual pump.. yikes. That would take forever!
__________________
Dave, Yoshi and Dixie [KI6LBB] The Adventure Duo 2004 Jeep Wrangler TJ X Edition 1993 Toyota Landcruiser 80 Series 2004 Adventure Trailer Horizon Outfitted by www.sierraexpeditions.com Tread Lightly! Trainer www.caltape.com Need digital media? www.trasharoo.com Pack it in Pack it out! |
#8
Quote:
Quote:
#9
Quote:
Just substitute one of these (get them at any Hose & Fitting/Hydraulic Fitting store): I think the plug on the bottom of the AT tank is 1/4NPT but verify whether its 1/4" or 3/8"NPT...I can't remember. http://www.anver.com/document/vacuum...bvc-14-mf!.htm I've thought about getting the same with a 90 degree elbow and running hose out to the edge of the trailer. But this is so simple and reliable I've left well enough alone :-). Slip a bucket (a 5-gallon Home Depot/painters bucket fits nicely under mine with 35" tires...) under it...fill your Zodi. Quick. For the AT spigot: Redline took the extended rubber cap that AT puts (or maybe used to put) on the schraeder valves for the air bags...and it fits perfectly over the manual pump spigot keeping it clean and dust free. Gotta ring M&M up for a couple as they're long gone from my air valves now :-o
__________________
#10
On our AT spigot we contacted AT and they sold us a small rubber dust cover that slips over it.
__________________
| Display Modes | |
