Expedition Portal Forum
Go Back   Expedition Portal Forum > Expedition Vehicles > Toyota: Land Cruiser: Sponsored by TLC
Toyota: Land Cruiser: Sponsored by TLC Discussions specific to the modification and service of Toyota Land Cruisers for Expedition Travel. Sponsored by www.tlc4x4.com
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-01-2008, 12:19 PM
Brian894x4's Avatar
Brian894x4 Brian894x4 is offline
Default My HID conversion into IPF driving lights (Total of $250)
This may not be the place to put this thread, but I don't venture much outside the Land Cruiser section, so please feel free to move it, if its better suited to a more general section....
This how I basically made some fairly decent quality HID driving lights, for a grand total of $250 for two lights.
I purchased IPF 968s from Costco for $90, thanks to a thread on here that discussed that deal. Costco IPFs
I then purchased an HID conversion kit from Retro-Solutions for $160.
Retro-Solutions
The IPF 968s are not fancy lights by any means, except that they have a fairly unique and nice reflector that allows the light to function as both a short distance driving light and a long distance spot light. I thought it would be a great light to convert to HID use.
The housing is extremely simple and made of plastic. Definitely not fancy. The lens and reflector are also simple, but appear to be of decent quality. The kit comes with a plug and play wiring harness and 4 bulbs. 2, 55 watt and 2, 100 watt. The wire harness and bulbs are nice, but of course, I didn’t use any of it for this set up.
The HIDs are a little tricky. I searched high and low trying to figure what brand of conversion HIDs I should go with. There are a lot of cheap junk HIDs and there are some really spendy ones out there. Price was still a major concern and it seemed like a lot people were pointing to this Retro-Solutions guy and his kits.
The seller makes lots of claims, like that his kits and bulbs are OEM spec or better and they are not cheap junk made in China. I have no idea if all of that is true, but I couldn’t find anything bad said about him or his products and price was not bad, so I gave it a try.
The things that attracted me to this particular kit was the higher wattage, 55 verses 35 watts, and the supposedly higher light output. The fact that I could order a low temp color (I wanted OEM light color, not blue) and the claim that the kit and bulbs were OEM quality. The ballasts were also supposed to be very durable and water proof. Also, this is supposed to be digitally controlled, which I "believe" means no igniter is used....I could be wrong though.
I chose the 4300K temp light in “short” H3 bulbs with the 55 watt kit.
__________________
Brian McCamish
In Search of History Expeditions
Gresham, Oregon
1995 Toyota Land Cruiser FZJ80 (new expedition rig)
1989 Toyota 4x4 truck w/SAS (retired expedition rig)
www.brian894x4.com (Homepage)
Our Land Cruiser FZJ80 Main Page
In Search of History Page
Abandoned & Active Railroads of the NW Page
  #2
Old 03-01-2008, 12:20 PM
Brian894x4's Avatar
Default
The very first thing I did was look all over the box and kit to see if I could figure out what company made these and what country. No luck. The box and kit has English and some kind of asian script, that appears to be Japanese. Could this be a Japanese made kit? I just don’t know. The only thing resembling a company name was the lettering, Genuine Part. But it doesn’t appear to be Genuine Parts, which is a real company. So, I really don’t know the origin of this kit, other than it’s supposedly not from China.
__________________
Brian McCamish
Gresham, Oregon
  #3
Old 03-01-2008, 12:22 PM
Brian894x4's Avatar
Default
Installing the H3 bulbs into the IPF housing had a few small hitches. The bulb was slightly off center from its base, which mean that it would not fit into the IPF’s square housing without some modification of the base. But after that, the square bulb fit perfectly in the square hole of the IPF reflector almost as if it was made just for that light.
The H3 HID bulb was called a “short” bulb by the seller. I don’t know why, because it was still longer than a standard halogen H3. Maybe other HID H3s are longer. If so, they would probably have a hard time fitting in most lights. These “short” bulbs fit in this light just fine. But I could see issues in lights where the standard H3 is a tight fit.
The only problem is that the HID H3 has large connectors on the wiring that require that you either drill a large hole in the IPF housing to fit them through or you have to cut the wires, fit them through the housing and then resolder them together. I chose to just drill a larger hole.
After that, the lights are ready to be mounted. Easy as pie.
__________________
Brian McCamish
Gresham, Oregon
  #4
Old 03-01-2008, 12:25 PM
Brian894x4's Avatar
Default
The ballasts are a slightly different story. These suckers are big and heavy. But in all fairness they look very beefy and well built. I had to take one apart to see what was in side. I found a larger rubber insulation to keep water out and that the internals were all covered in a rubberized coating to protect it. However, if anything went wrong with the ballast, it’s clearly not repairable.
Where to mount them became a problem, because I have little to no room left. I decided to mount them behind the grill using several wire ties. We’ll see if this holds up.
In this pic, I removed the cover, which is probably a no-no, but I couldn't resist. I had to see what it looked like inside. It's definately made to be weather and shock proof...at least that's the intention.
From what I've read the case is a standard and cheaper metal case, which is similiar to some other types out there, but the internals are completely different.
__________________
Brian McCamish
Gresham, Oregon
  #5
Old 03-01-2008, 12:30 PM
Brian894x4's Avatar
Default
Keep in mind, I have no experience with HIDs, so I have nothing to compare them too. As I turned them on, they fire up with a blast of light, then go dim and within a few seconds, were at full brightness. When cold, it takes about 10 seconds to get up to full brightness as far as I can tell. After that, you can turn them on and off and it turns on just like a normal light, with no delay provided they've only been off a few minutes. In other words, if you want to use them with your brights, they seem to work fine and go to full brightness immediately when warm. However, I don’t know how turning the light on and off repeatedly affects the bulb or ballast.
The lights are bright as heck. Far exceeding my expectations. I did a quick amp draw test and I was getting anywhere from 12-13.5 amp draw with the engine turned off. This was on a cold ballast and at about 12.3 battery voltage, this translates to about 74-83 watts per light, instead of the 55 claimed watts, which was odd.
One possibility for the higher amperage was that the ballast was cold. Also, my multimeter was only designed to test up to 10amps and the wires were providing a huge amount of resistance. The lights were dimmer, when running through my multimeter and my multimeter was about to melt it was getting so hot, so that could be part of the problem.
When the wires were hooked back up to my relay, there was no excess heat or resistence, so I may need to figure another way to test the amp draw.
In any case, I would assume that under normal circumstances, the lights should be using about 55 watts a piece. Assuming around 13.5 volts with the engine running, that’s only about 8-9 amps of power use, compared to almost double that from the 100 watt halogen bulbs I was using before.
On the open road, the lights are just incredible. I can’t describe it. They are far brighter than anything I’ve ever used. Because the color is different than the headlights, you can clearly see the difference. I had 200 watts of halogen power before and I could hardly tell they were turned on with my brights turned on.
I do have John Deer low beam HIR and HIR high beams, so my stock lights work very well by themselves. But even so, it’s very obvious when the HIDs are turned on.
Here are some shots using a little point and shoot and I'm not sure what settings the camera chose for some of these pics.
The first pic show the HID on the left and the IPF with a 100 watt halogen on the right.
The next two shots show the HID and then Halogen turned on and up close, with the camera obviously choosing a very dark shot, which allows you to see the bulbs lit up, but without any glare. Both are too bright to look at directly with the naked eye. These shots sort of give the appearance that both bulbs are same brightness, but trust me, it's a camera/optical illusion.
__________________
Brian McCamish
Gresham, Oregon
  #6
Old 03-01-2008, 12:33 PM
Brian894x4's Avatar
Default
Here's the results.
Picture 1: low beams only.
Picture 2: low beams + yellow halogen IPAA fog lights
Picture 3: low beam + high beam + fog lights
Picture 4: low beam + high beam + fog lights + HID lights
In these pictures, the HIDs were aimed to be the exact same level as the high beams on a wall at about 20 feet, so they may be a bit low. Also, since the IPFs divide light both driving and spot, it would be interesting to see what the results would be a in a dedicated spot light.
__________________
Brian McCamish
Gresham, Oregon
  #7
Old 03-01-2008, 12:34 PM
Brian894x4's Avatar
Default
On the open road, the lights are just incredible. I can’t describe it. They are far brighter than anything I’ve ever used. Because the color is different than the headlights, you can clearly see the difference. I had 200 watts of halogen power before and I could hardly tell they were turned on with my brights turned on. I do have John Deer low beam HIR and HIR high beams, so my stock lights work very well by themselves. But now, it’s very obvious when the HIDs are turned on.
So far, my only complaint is that it’s hard to tell which direction to aim the IPFs. I generally aim them to the same level as the high beam lights.
While the IPFs work great as both a driving and spot light, I think the ultimate set up would be a set of four HID lights. A pair of dedicated driving lights and dedicate spot lights. Especially if controlled independently.
Now, HIDs do have some disadvantages. For one thing, they reflect fog and rain like crazy. The lower the light temp the better, which is why I went with 4300K.
I would never install HIDs in the headlights for reasons mentioned by others, including how they would not work properly in a stock reflector designed for halogen bulbs and would be too bright for on coming traffic in the stock headlight housing. Also, the halogen color is probably much better for general use, including rain and fog and the HIRs that I have work absolutely great.
However, I do have a set of fog lights and I’m considered ordering a set of HID fog bulbs, which are basically 3000K temp, to try them out.
In the end, I hesitate to recommend this set up to anyone else, because I honestly have no idea of the quality of the HID kit and how long it will last. Indications are that it's a decent kit and should last a while, but only time will tell.
__________________
Brian McCamish
Gresham, Oregon
  #8
Old 03-01-2008, 12:44 PM
AFSOC's Avatar
AFSOC AFSOC is online now
Default
Nice write up Brian, your work inspires.
  #9
Old 03-01-2008, 01:52 PM
Carlyle's Avatar
Carlyle Carlyle is offline
Default
Thanks for the write up Brian and and makes me want to get outside and get the HID mounted that I bought on the Checker deal about a month ago. I think I'll put them on my CJ7 though and see how durable they are.
I wonder if a set of these conversions would fit in the housings of my PIAA 520's? I'll just have to email them and ask.
__________________
'04 Ford F350 6.0 diesel slightly modified. 10' custom Alaskan on flat bed with a few add ons.
My camper build: http://www.expeditionportal.com/foru...ead.php?t=9502
KD0ERY
  #10
Old 03-01-2008, 01:59 PM
slosurfer's Avatar
slosurfer slosurfer is offline
Default
nice writeup! I think we will see that HID lights are going to start coming down in price, now that everyone is figuring out how to retrofit their different offroad lights into HID. Do your headlights look really yellow now after you turn the HID's off?
I now want to do a HID projector retrofitt into my stock headlights but I don't think anyone will ever make clear headlights for my 2nd gen., oh well, that's what the aux. lights are for.
It will be interesting to see how these 55watt kits hold up. I really want to put a 55watt HID in my Lightforce 240 and retrosolutions was one of the ones that I was looking at.
__________________
~Chris
7th Annual Pismo Jamboree Sept. 25-27, 2009 (Oceano Dunes, CA)
'93 4runner
'07 Tacoma Dcab 4.0 TRD offroad
M416 trailer
Semper Fi
YAT YAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright, Expedition Portal 2005-2009
